led_balloon
    WI, River Falls
led_balloon's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. I'm planning and changing all the fluids in the front and rear diff. I will be replacing the gear lube with lucas syn 75w90. I just need to no if i need friction modifier, as i do not no if its a lsd diff. its a 92 eliminator dana 30 and 35. thanks for the help also i found and a better flowing manifold from a newer jeep(xj) for a $100, it has more than 100k miles on it. is this a good price.
  2. i tried a search and didnt get anything so what should i do. aw4 tranny when i switch from d to r i get no lights. but sometimes it works going from p to r wtf! :mad:
  3. thanx for all the posts ill take everything into consideration
  4. lead not follow - the rock it intake your taking about, will it fit my mj? where would be a good place to buy a bored tb? i guessing i can get the manifold on ebay. do you have a thread talking about your stroker? thanx again for help!
  5. lead not follow - so you don't recomend TBS's, thanx for the info. do you recomend cold air intakes, if so what brands and where to get them. also have you ever heard of aero exhaust? http://www.aeroexhaust.com/
  6. lead not follow - do you no this by experience or did you just hear about not trying to sound mean
  7. i just visited the rustys offroad website and noticed this TBS and intake package http://rustysoffroad.com/mm5/merchant.m ... de=PER_AIR it says that it fits a xj so will it work for a mj? and if it does, is the vacuum hose(drivers side hose) neccesary because it dosent supply a hole/nipple for it thanx for taking the time to read!
  8. thax for the info
  9. i know what you meant (front/rear). i was just wondering if it had dana 44s with 4:10 in the rear, because i thought they were standard on the elim.
  10. is there a big visual difference between the two so i can be +
  11. what axle and gears does a 92 eliminator :headpop:
  12. has anyone tried this or any other diesel in a mj
  13. (NUBIE ?) this is proabaly a stupid ? but don't you lose power with your exhaust short like that
  14. thanks for the input
