led_balloon
Everything posted by led_balloon
I'm planning and changing all the fluids in the front and rear diff. I will be replacing the gear lube with lucas syn 75w90. I just need to no if i need friction modifier, as i do not no if its a lsd diff. its a 92 eliminator dana 30 and 35. thanks for the help also i found and a better flowing manifold from a newer jeep(xj) for a $100, it has more than 100k miles on it. is this a good price.
reverse lights not working!
led_balloon replied to led_balloon's topic in MJ Tech: Modification and Repairs
thanks alot -
i tried a search and didnt get anything so what should i do. aw4 tranny when i switch from d to r i get no lights. but sometimes it works going from p to r wtf! :mad:
thanx for all the posts ill take everything into consideration
lead not follow - the rock it intake your taking about, will it fit my mj? where would be a good place to buy a bored tb? i guessing i can get the manifold on ebay. do you have a thread talking about your stroker? thanx again for help!
lead not follow - so you don't recomend TBS's, thanx for the info. do you recomend cold air intakes, if so what brands and where to get them. also have you ever heard of aero exhaust? http://www.aeroexhaust.com/
lead not follow - do you no this by experience or did you just hear about not trying to sound mean
i just visited the rustys offroad website and noticed this TBS and intake package http://rustysoffroad.com/mm5/merchant.m ... de=PER_AIR it says that it fits a xj so will it work for a mj? and if it does, is the vacuum hose(drivers side hose) neccesary because it dosent supply a hole/nipple for it thanx for taking the time to read!
stupid question, but
thax for the info -
i know what you meant (front/rear). i was just wondering if it had dana 44s with 4:10 in the rear, because i thought they were standard on the elim. -
is there a big visual difference between the two so i can be + -
what axle and gears does a 92 eliminator :headpop:
has anyone tried this or any other diesel in a mj
(NUBIE ?) this is proabaly a stupid ? but don't you lose power with your exhaust short like that
thanks for the input
Project "Eliminator"
led_balloon replied to 89eliminator's topic in MJ Hardcore Tech: Epic Journeys to Greatness
what kind of intake is that -
better accel off the line?
colfax, near eau claire WOW, you're only about 30 miles from me. I'm originally from elk mound, but now live in menomonie. I still get to colfax pretty frequently as I have a few friends around that area. Its red with with a roll bar, black willy's rims, and diy black herculiner bedliner whats yours look like -
colfax, near eau claire -
newbee probably wrong, to be honest iam not sure what gearing i have, and i have stock tires -
i beleave it is leaking at the cover
what can i do for better acceleration, i beleave i have a dana35 with 4.10 gearing led zepp
1992 comanche eliminator 4.0l l6 4X4 swb 4sps auto 140,000m is this bad i can't tell if its just the gasket, there are no cracks, oil pan leaks to led zepp
recommended engine performance parts
led_balloon posted a topic in MJ Tech: Modification and Repairs
what are some good performance parts for a 1992 4.0 l6 -
can you use a cherokee 4.0 l6 cold air intake on a MJ? is there a true way to get duel exhaust THANKS! LEDZEP
