neohic
Moderators
    2
Everything posted by neohic
  1. I've tried to contact the guy on this: Factory hidden winch?
  2. Middle of March and they're still going out! One more dropped in the mail today, one sold locally, and two more being worked out. TWO LEFT!!! -Ben
  3. ... will you every reach your goal? Granted, any Comanche will enrich anyone's life!
  4. Hmm... I miss having a family. :(
  5. Kinda... viewtopic.php?f=2&t=27942
  6. I've got a code 24 and 42. The MAP sensor goes into the port between the fuel lines on the throttle body. It still has a GM stamp on it, so I figure it's bad. No knock sensor either but it was worked out of the wiring properly with ECM pin number B7 tied to C14 for the proper 5 volt reference. As far as the ignition module... not sure yet what to look for. Here's the diagram I used for the ignition: Any ideas?
  7. :shake: Don't give the owner anymore ideas! He also has a Liberty that he's been trying to get me to think about a solid axle swap. Maybe...
  8. It's still on!!! Invoice sent.
  9. DONE!!!... pretty much. Everything works and it runs awesome! Problem is the check engine light is on. Checked the codes and it turns out that the MAP sensor is bad and there's something up with the ignition module. Otherwise, lots of power and plenty of pep! Finished the wiring and put the ECM right were it was originally: New underhood... so much better than it was: ... the diamond plate is kind of a running joke... he's already got way more on the Jeep than it needs. Why not some more?
  10. ECM is the stock unit out of the donor vehicle. Part number is 1227747... same ECM that Howell sells with their kit. We thought about that, but the majority of the parts came out of a Blazer that was being scrapped... thus free. Also, the Jeep is used mostly on the trails. With the gears in it, performance gain wasn't too much of a concern. Again, going for reliability. That's what I told him! He bought it already built up and at the time he wasn't thinking about how terrible the carb would be. Slight update today: found out that the starter relay was bad and chased around wiring issues with having the stock computer out of there. I had to figure out the tach and the volt gauge is still not working… maybe bad gauge? I don’t know if it worked before this whole deal started. Gonna throw the multimeter on the alternator tomorrow to see if the gauge reading nothing or if the alt is putting out nothing. :hmm:
  11. For got to post this too... it runs! (Click to see it all!)
  12. Hey, thanks! As far as the shop... :roll: hmm... figure out the shipping costs as we'll see what happens!
  13. This little guy is all done! From one project to the next: viewtopic.php?f=3&t=29102
  14. So... my brother's VW went back to his place for his to finish up which left an open spot in my shop. Granted, I was looking forward to a little more elbow room, but I'm planning on moving this summer and this project has been pushed back for a few years now. What I'm doing now is a little more simple than the VR6 swap: only fuel injection this time. This is my friend's 1990 YJ. Its got the carbureted 4.2 and he hates it! The main problem is the reliability... this thing is terrible and that needs to change. By no means is this project breaking new ground. There is a kit from Howell that does this same thing minus the electronic ignition... and it costs around $1300! All this kit is are the same GM 4.3 components that can be found in any junkyard. Being that I've got around $200 in it, this just seemed to be a much better choice. Lot's more research and time invested, but much, MUCH, less of a gouge in the wallet! Anyhow... pictures! 1990 YJ: And all this stuff: Yup, there is a carburetor under all that! And some stuff needs to go away: Now… you can buy an adapter plate, but I’d rather build one: Oh, good… it fits: Going from a mechanical fuel pump to electric. Again, made my own block off plate: Got all the wiring mocked up so I could get it running before removing all of the original… just in case: Should be fun!
  15. Looks like fun! Thanks for posting the videos... really cool to see this truck in action!
  16. It all depends on how fancy you want to get. Maybe you want to retain the factory size opening on the corners... maybe you want to just cap over them... maybe you want to weld the corners shut and start over? The way I did it on my old pickup consisted of using 16 gauge diamond plate rolled around the corner in between the box and the tailgate. This truck was nothing to write home about so they just got fastened to the outer bed skin with self tapping screws.
  17. 1974... ish VW Dune Buggy in progress: 1972 VW and my dad's old Huffy: Got my basses too... yeah... that's a kilt:
  18. I'd volunteer my shop, supplies, welders... the whole meal deal. Fully equipped with 220! Why not, made the trip once?
  19. neohic
    Before and After
  20. What are those seats out of?
  21. Excellent attention to detail indeed! Thanks for everything that you have posted on an incredible this truck. Congratulations!
  22. Still holding six of them. :thumbsup:
  23. http://duluth.craigslist.org/cto/2218398270.html
  24. http://minneapolis.craigslist.org/hnp/c ... 03109.html
  25. Been a while since I've done anything with this... probably because nothing has happened with the truck. Problem is, I drive 140+ miles everyday so, sadly, the Eliminator has stayed in the garage since its completion back in October. Very happily, I had an excuse to take it out today! The plow went through and the neighbors decided to avoid cleaning out the end of their driveway... in comes the MJ to pull them out! Granted, it wasn't that stuck... still... why not?
