CEThomas
Everything posted by CEThomas
  1. Know what you are talking about. Had to replace my fuel pump on my Ram last year. The Dealer was on $10 more for a OEM pump them Auto Zone. Always check the dealer first, 95% of the time they will be higher but that 5% they can be lower. Back in 82 I needed some trim for my 66 mustang, the JY wanted $20 and it was bent and dented. Went to Ford and ordered it and walked out with a new OEM one for $13. Then there was the time I got a gate rod for my K5 that was $45 and I stopped my MidWest Maf. to see my uncle and he looked at the rod in my pocket and took me back on the floor and made a new on for me and told me they charged GM $2.50 for it and they only had $1.00 in it :nuts: Charles
  2. Did you call them up to see if they have them? I have been watching the e-bay store site but have not seen the ones for a MJ yet. Charles
  3. Thanks for the info. Charles
  4. Will the XJ center console fit the MJ? Need something to go between the new buckets :cheers: Charles
  5. Thanks, Got a lot to look into. Charles
  6. "They are 2" drop shackles from the chevy fullsize truck" Is that a stock shackle I can get off the neighbors 1500 tonight ;) Charles
  7. I thought I had seen where someone was using rear shackles off a GM truck that were around the size of 1.5" drop shackle to get a little lift? Charles
  8. It can be with all springs. The stock springs on our MJ is off 3/4" on the passenger side. I just told my son to always carry a passenger that is 50# less then him and it will ride right :D Charles
  9. Not much work, put the MJ on the lift and pull the axle and slide it under the springs. Take about 2 hrs. Charles
  10. All I need is a set of spring perches ( would leave the ones on top for if/when we would go SOA ) have everything else to go back SUA. Charles
  11. JeepcoMJ Thanks, what I was thinking. Rokhound Also need new uppers and lowers for 8" and most likely drop brackets then need to get the T case lower, and 8" has sharp angles for the DS. Some stuff you can get but finding DB at a good price is not easy as well as the UCA's and LCA's. Charles
  12. Well we got the bed back on and the hope that it would drop the back, and it did not help :oops: Here is the problem, When we got the 8.8 we went SOA and even with 2wd springs to level the MJ out we need a 7.5" block under the front tires :eek: A 7.5" would be great if not for 1) this will be his first truck and what he will learn to drive on. 2) do not have the funds at this time for a 8" lift :cry: So looking for a solution right now. Only think I can think of right now is to go back SUA and build some spring packs and shackles . Anything else I can do? Charles
  13. CEThomas
    need assist
    If it's been a very long time it may not be in the system any longer. I can try at work but LEADS may not work. Best bet is go to the DMV and tell them what is going on and they should be able to help. Charles
  14. Also used the SS nylon lock nuts. Trip to Lowes and it was done :cheers: Charles
  15. When we put the front ones on we just used some SS bolts with 2 large fender warshers on each side and it worked great. Charles
  16. Kind of what I thought :D Charles
  17. Thanks, He told me to get 4.5" lift ZJ springs when I do the front lift. Did not know why unless it was for the winch when we mount it. Charles
  18. Had someone yell me to use ZJ springs on the front of the MJ, what is the difference? Charles
  19. So what would be a good muffler for a 2.5? Right how only have no muffler or cat :nuts: Charles
  20. Had one in my Z-28. Good trans. Charles
  21. OK, JC Whitney Catalog # 718J-03 Page # 53 Item# MH267206 Rough County adjustable track Bar $69.99 Charles
  22. I will check when I get home and see if I can find the sale book and info. I know whne I was looking at it I was wondering what was wrong with it at the low price. Charles
  23. A few years back I was walking by a RV getting fuel at a truck stop and in the car being pulled was a nice SS ram strapped around the drivers seat running down to the the brake peddle. It had a small plate at the peddle and a large plate at the seat back and a line that ran out the window w/ the light wiring to the RV. All I know is it looked like He!! and I wanted out in front him :cheers: Charles
  24. Did not get to check it out, buy I was looking through the JCW book that came in the mail the other day and seen RC adjustable track bars for $69 and shipping is free or cheep on most items. Charles
