11
Depends... Diff covers, I like ruffstuff. http://www.ruffstuffspecialties.com/cat ... s-c-5.html Gears, generally I buy yukon. http://www.ringpinion.com/ Brackets, tabs, rod ends, etc, either ruffstuff or polyperformance http://www.polyperformance.com/ I don't buy anything that I can make, generally.
Oh, do you pay your paypal account via credit card? If you do, you can normally get visa/mastercard to put pressure on paypal to return your money. IE, phone the credit card company and say it wound up not being a legit payment. If you keep money in the paypal account or take it directly from your bank account, I imagine you're screwed for the money.
chrystler 8.5 inch???
DirtyComanche replied to freakjeep93's topic in MJ Tech: Modification and Repairs
I'd second that as being the most correct solution. -
Give me ALL of the information you have on him, and I will make some inquiries. What site did you contact him though?
For what purpose? To change your bolt pattern? It's probably the wrong width, if nothing else... I could be off-base. -
How far away is he? Do you know anyone in the area that owes you a favour? Do you want to destroy his life? Is he registered on Pirate4x4? How much money is in question?
I'm against financing such an item. I'd finance a house, but only if I had 20% as a down payment minimum and reasonable job security. Otherwise, no, I won't finance a damn thing. It'll be $200 cars before financing.
Let's put it this way... If I was that guy I'd be watching the classifieds. After all, I'd need a replacement set of tires/rims.
I'd not heard that before. But generally everything regarding the 8.25 I disregard. Not enough strength to bother or care. -
Project 2drx4. A cherokee.
DirtyComanche replied to DirtyComanche's topic in Member Projects: Your Comanches
Visteon wasn't spun off until 97. Sterling in 98. These axles showed up in the late 80s, IIRC. Visteon also makes no mention of building axles, just interiors and electrical. Whatever, it's largely irrelevant. Referring to is as a 'Ford 10.25' might well be most correct. -
Yup, so he showed up tonight with an 07 A4 w/ the 2.0T, 6spd, Quattro, and some sort of 'winter package' (all seats are heated, and a nifty pass though for skis from the tunk into the cabin area). It was dark by the time he got here, so I couldn't say much other than the interior looks nice. And there's an overwhelming amount of features, it seems. He'll figure it out, eventually. I have some faith in the old fart.
Does Visteon own Sterling? Or, did they? Ford owned it, spun it off, bought it back... Anyways, the 10.25 is probably cast nodular iron. The sparks were more consistent with cast iron, shorter and more orange in colour. Also, it feels soft when grinding, cutting, drilling, etc, which is consistent with cast nodular iron. Cast steel would also be very atypical for an application like this. As to the 8.8, I wouldn't comment, but I'd assume the same. So, I welded this thing on. I pre-heated to about 500*... Welded 1"~ segments, peined the weld, blah blah. Used the MIG, and did it seriously hot... Image Not Found Ground around the edge to smooth it all out. Image Not Found I shouldn't have made the plate as wide as I did, it was slightly counter-productive. Ohwell. Also, I welded the inside but neglected to take a picture. And I hate wire wheels. Image Not Found -
But... To what pressure? Shop air is gonna be 120PSI, you don't want THAT in a tire. And they aren't going to read the manual; how dare anyone suggest such a thing. It's unfortunate, but most people don't have a clue. So the light comes on and they take it in. Or they drive around with the light on forever.
Carfax? Here you can just take a VIN number to the insurance office and have them run it for $10.
How do you change your oil?
DirtyComanche replied to comancheman's topic in MJ Tech: Modification and Repairs
Hey! Who you calling stupid! :D . I've been prefilling oil filters for 30 years I mean the process, not the intention... Fill filter, flip filter over to install, spill all the oil out of the filter and onto the engine and floor, swear. With a remote setup with the filter oriented correctly, I could fill it and stick it on there without spilling it. I'd actually bother then. As it is I just grumble, put some oil on the gasket, and spin the new filter on. -
I like how that cost you $2300, and I was looking at one on the stealership for $8900 CND a couple months ago (a 98, also white). Looks good. Treat 'er well. And umm, I'd avoid financing $2000 vehicles in the future (at least you aren't financing a $30K vehicle that you can't afford).
I often pull the plug cold. I don't really care. I imagine there will be a little sediment on the bottom of the pan, but I have trouble believing there would be a lot that wouldn't have been caught by the filter that could actually be suspended by running it. Maybe I should waste half a quart and flush a little clean oil through it when I do that, just because. Whatever, my oil change interval is way more often than recommended anyways. And pre-filling is stupid on these things. I'm dead set on running a remote mount oil filter on my XJ (when I get that far). -
Actually, it's a brand/trade name, like NiArc or Nickel-99 or such. It's just a rod that has a high nickel content so it welds better to cast iron. It's expensive. I have some, but it will have to go in the oven before I use it (if it is still in decent shape). Also, I haven't used my stick for much more than burning out bolts/stuck stuff recently (now that I think about it, it's probably been 2 years, that rod is probably garbage). To complicate things a little more, I didn't want to just plate it in with regular hot rolled steel. So I tried to buy some A-50 or T-1. Turns out neither are easy to get here. But they had a chunk of .375" AR (Abrasion Resistant), which is brutally hard. It requires to be preheated to 300* minimum before it'll weld nicely. So, there's going to be a fair amount of heat in this process. I'm thinking I might go rent an oxy/acetylene torch to aid in pre-heating. I have a little oxy/mapp torch that take the small torch bottles (1-lb?). I don't know if it'll throw enough heat. Also, I'm going to need some serious heat to get the freaking pinion yoke off. I broke my harmonic balancer puller trying to get it off. Durr. I would have tried my little torch to get it hot first, but I had no oxygen left. -
He just phoned me and said he drove an A4 today (guess he got their early enough). It sounds like he'll be buying one if he can find exactly what he wants (that one was a toupe colour, whatever that is, it's not one of the 16 colours I know, but apparently it didn't look great).
Ugh. Well, if they fry your nuts it's just cheap birth control. Good luck with everything :cheers:
I actually couldn't even tell you if those are available here. I can't say I've seen one. And I haven't randomly gone to the dealership to get the salespeople wet, not in the last year at least.
It's what he wants. Mom has got a WJ that they use if they 'need' a SUV. And he wants something small/short that is easy to park downtown; since the wonder of city planning has produced parking spaces much more suited to smart cars (if you can find one). In this town I drive around all over the place trying to find spots that I can actually fit my stupid 3/4 ton in.
Yeah, he's not exactly the saturday mechanic type. He claims he used to do the oil changes on his VW beetle back in the 70s, I've seen no evidence to support that. :rotf: Anyways, he's going to go test drive some Audis tomorrow, since he has to go to Vancouver anyways (there's a couple Audi dealers there). We'll see.
To use a sawzall you would need a really long blade. With the sterling the area to be removed extends a long ways towards the pinion. A 10" or so disk in the angle grinder would have made shorter work... Might weld it with castarc with the stick... Haven't decided yet. It's that or backtracking with the mig using some preheat and a slow cool. I'm not there yet (the mig would be fine). -
Bonneville Comanche
DirtyComanche replied to Worlds Fastest Comanche's topic in Member Projects: Your Comanches
Any chance we could get more pics of the truck? The gory details, the innards, etc?
