Everything posted by wvzj
Next I connected the the wires from the plug ends and trailer harness together. I didn't use the backup light, so I just connected the 2 wires from the body plug together. Brown: Right turn and brake light Black: Ground Blue: Tail (parking) lights Brown with white tracer: Backup light Grey with black tracer: Left turn and brake light
I made a plug n play 4-way flat trailer wiring harness over the weekend. I started with a spare rear body connector that I got at the pick n pull. And a 3 foot long 4-way flat vehicle end connector that I split the wires, twisted and heat shrinked.
I added a air hook up to the rear of the bed for my OBA setup.
Haven't posted any updates in awhile, been real busy between moving and addition of a little one to the family. Also started working on the ZJ again, 242 swap with SYE, and getting ready to regear my front.
Looking For New Leaf Springs
wvzj replied to GrizzzzBear's topic in MJ Tech: Modification and Repairs
http://www.generalspringkc.com/Leaf_Springs_Jeep_Comanche_s/1954.htm I never dealt with them before, but will probably give them a shot next year when I redo my suspension. -
The best way to get a true measurement for shocks is to go flex your suspension, and get full droop and stuffed measurements. Otherwise you are just guessing.
Here are the part numbers for the Dayco hoses in the Team Cherokee kit 87301 87305 87605
I just ordered the set from there. Two are NOS and the rest are Dayco, but beware it took me 3 weeks to get mine from them.
????Really? Got a source for this information? I have never heard this. The gear oils I buy all state that like Red Line, Royal Purple
High Output
I wouldn't worry about it. Most good gear oils have LS additives in them already
But did they fit without modification? Or do you have a D44 from a TJ? The flange bolt pattern is different between a TJ D44 and an XJ/MJ D44. That's how I ended up with two pair of the TJ axle seal retainers. I bought a new set of alloy shafts and the wrong retainer plates were in the box.I don't think I had to modify the retainers, but that I was done 6 years ago so I can't say for sure. My 44 came out of an XJ. I would look and let you know, but I'm out of town till next week.
Since you want to go with chromo shafts, just get a pair for a Rubicon they come with the correct bearing retainer, at least mine from Alloy USA did.
33S Or 35S? Your Input Appreciated.
wvzj replied to mountainman's topic in MJ Tech: Modification and Repairs
Yes it is 2" of tire but you only gain 1" of ground clearance. For a DD I would go 33's, especially with only 4.10 gears. -
http://www.stu-offroad.com/suspension/d44brake/bc-1.htm Here is the link for Stu's write up. It is the one that I used.
http://www.jeep4x4center.com/backing-plate-assembly-kit-for-dana-35-with-disc-brakes-4762128-29k.html There is a link for a new stock backing plate assembly, you will also need a different axle retainer for disc brakes. Stu's-offroad has a good write up with the retainer part number. If you want to save a few hundred bucks you would be better off going to a pick and pull and grabbing the backing plate and caliper assembly yourself. The swap is pretty easy. ZJ parking brake cables will do the trick for your e-brake.
First Hand Experience, Reviews?
wvzj replied to onlyinajeep726's topic in MJ Tech: Modification and Repairs
I am very pleased with the Rock Krawler LA's on my ZJ. It's been on there 10 years now with no problems other than rebuilding the joints a few years ago. -
I would check the trackbar first. But it could be a number of things torque all suspension bolts, check bushings, alignment, out of balance tire
Maybe paint it with some por-15 and use some seam sealer
Rough Country 6.5 Inch Soa Lift
wvzj replied to Jacob Ochs's topic in MJ Tech: Modification and Repairs
Google rough country and you should get all the answers you need. If you wanted to save some coin and get a good quality lift I would piece my own lift together. -
Tire To Gear Ratio Questions
Good luck with that. I know the 2.8 I had was gutless with 215's. -
My local Airgas will bring in any model you want and let you test it out before you buy. It might be worth your time to check with your local distributor and see if they will do the same for you.
Any news?
Question About Zj Read Coils N Shocks For Dropping
wvzj replied to Burntoast914's topic in MJ Tech: Modification and Repairs
http://www.monroe.com/en-US/catalog/e-Catalog/
