wvzj
Everything posted by wvzj
  1. It has been 5+ years since an update wow!! A lot has changed, c clip eliminator for the 8.8, and 4.56 gears. Durabak in the bed. JCR rear bumper. Warn M8000 that I picked up used. Added an interior guage for my OBA. New RE shocks. Made a mount for a Hi-Lift in the bed.
  2. 5ish front soa rear. 33s
  3. Mobil Delvac or Chevron Delo whichever one has the best price at the time, both in the 15w-40 flavor. And of course a sexy Baldwin filter.
  4. http://www.strokedjeep.com/renix%20t-body.html he does good work
  5. You can change the t-case switch to a newer 2 wire switch if you want the light to work without the vacuum madness. I have the part numbers and some pics on page 2 of my build thread.
  6. The Rear retainer doesn't have any seals, it is RTV'd to the rear case half, then the extension is RTV'd to the retainer. The seal goes on the extension. Are you running it without the extension? Are you sure you aren't damaging it upon installation? Are they giving you p# 15047?
  7. I agree. I might even go 4k. The bottom line is its your money, and if you are comfortable paying what he wants then pull the trigger.
  8. The hardware kit would be used to replace the adjusters and springs on the e-brake, if it were mine I would put all new brakes on it. At least check you adjuster to make sure it is not froze up. The cables can be had cheaper at your local parts store. I used ZJ cables and I paid like 16 or 17 dollars apiece at advance auto
  9. The Google machine says- M8 x 1.25 x 25
  10. Have you thought about sending it off to get repaired? There are still a few shops around that provide this service.
  11. I believe you can you just need the mechanical speedo from a 231. IIRC the 207 and 231 speedo gear housings are quite different.
  12. Looks good! My wife thinks the manche is hers as well. What is it with significant others?
  13. That is the correct sensor for the gaugeNo, it's not. Autozone part #TU108 clearly states that it is a coolant temperature "switch." That's for use with idiot lights. The listing also has a "related parts" area that includes "Coolant temperature sensor"http://www.autozone.com/engine-management/temperature-switch?filterByKeyWord=TU108&fromString=search&isSearchByPartNumber=trueProblem is, if you click the link to the related "coolant temperature sensor," it shows one with a pigtail and it says it fits the thermostat housing. That's not the correct part for a Renix, that would be for an HO. In other words, Autozone (as usual) doesn't have a clue.This one, from Advance, looks to be the right one:http://shop.advanceautoparts.com/p/bwd-engine-coolant-temperature-sender-wt761/5973805-P If you cross TU108 and WT761 they are the exact same, just different manufacturers. They both cross to Napa 6053 which is the one I used and was previously mentioned by Dom. So yes TU108 will work
  14. That is the correct sensor for the gauge
  15. I bought this 17" bar and I am really pleased with it. It is a wide beam that puts out a ton of light. https://www.superbrightleds.com/moreinfo/off-road-lights/17-heavy-duty-off-road-led-light-bar-108w/1942/4595/
  16. Yes MJ and XJ bushings are the same. I prefer rubber bushings as I think they provide a smoother ride and flex better. But since you have no preference I would go with whichever one is cheaper or more readily available to you.
  17. I bypassed mine with no ill effects
  18. I see you live in Texas, you don't happen to work in the patch do ya?
  19. That's one thing I can't complain about, she has never said anything about the money I spend on the Jeeps. What scares her is the snappy tool truck!
  20. Right now it has saggy 3" Rustys coils with 2" spacers all installed by the po with Teraflex lowers and JKS uppers. It has a slight rake. I have some new Rock Krawler coils but I'm gonna wait to put them on when I long arm it hopefully this winter. It's manageable with 3.55 and 33's. I am slowly gathering parts to go 4.56 with a Detroit in the rear and a c-clip eliminator. it's a slow build process for the wifey. It's a toy she drives to work a few times a month but wants her own wheeler and she doesn't want the ZJ on 35s. Trust me I have tried every trick I know to give her the grand and let me wheel the MJ but no dice. She thinks the manche is hers, but the title says otherwise haha
  21. Spend your money once and buy an IR. My first gun was a Campbell hausfeld, it lasted about 2yrs before it started to take a crap. It would struggle to bust loose lug nuts torqued to 85 ft lbs
  22. Here is a pic of the bored TB I stole from cruiser, there is a big difference. Jeff did a great job and was very easy to work with.
  23. I haven't taken her out for a drive yet, but the throttle did seam more responsive just from goosing it in the garage. I might make a splash guard for the filter. I also want to replace the o2 sensor, and I have some pipe laying around so I may attempt to make a new down pipe to eliminate the crush. If not I will just take it to the performance shop up the road and have them mandrel bend a complete new system, the muffler is looking a little rough anyway. I'd like to do Volvo injectors but I may build a Stroker next winter and I don't want to have to buy sticks twice.
