MJDigger-CT
    Connecticut
782 profile views
MJDigger-CT's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Ya know I like the price better. But for the 17s they only have them with the 5 on 5 bolt pattern. I'm looking to keep as close to factory back spacing as I can so do not hit the flares when flexing a bit, not a trail rig would rather avoid triming ya know?
  2. Have a pair of 255/75/17s kicking around , I acquired from a buddy a bit ago back. What do you guys think fitment wise on these wheels. Oh I'm running the RE 3.5 inch lift http://m.summitracing.com/parts/brw-997791250
  3. Hey there so I don't have much experience painting vinyl. It's some kinda of dye right? Kind of wipe it on like a wood stain?
  4. Hey there I suppose this might be a tough one. But if any one has s full sized black center console out of an old MJ or and xj that would do the ticket. Much thanks pm if you have your hands on one. For shipping purposes my zip is 06032
  5. I used the 3.5 inch RE kit with the 3 inch HC 3 inch lift spring in the back. Is curently siting pretty level have only had it on for a few months so not much time for the sag factor. Over all happy with the outcome.
  6. Heyo every one. So I cut out my rockers some time last year , the po filled them with spray foam and bindi. Like a bonehead I forgot to take pictures of them before hand . But I'm just geting to fixing them now. Any one have a close up pick of the body line , where the rear door jamb comes down and meets the cab corner and the rocker. I remember there was some sort of recess there. Want to make it as close to stock as I can. Thanks
  7. Any one have a set kicking around?
  8. Interesting stuff. Thanks for the replies just gonna let it do its thing for now and see what happens.
  9. Alright alright yes stock perches on a Dana 35 . Took a quick measurement with out dropping the axle of the springs got right in the ball park of 31 in the back and 26 in the front . I do remember I had to drill out the center pin whole in the pearch prior to install because the he pack had a bigger pin. Pretty sure it was 5/8s if I remember right. But that wouldn't change anything with alignment. Maybe I missed something during install.
  10. Yes the lift is installed in the picture. Double checked the bushings on the leaf spring the larger bushings is mounted toward the front on the bracket.
  11. Ooo alright thanks for the response , that didn't even cross my mind.
  12. So well I have the 3 inch lift springs in the rear from hell creak. Both sides to appear to be the same. here's a picture of the pass side. Just kinda curious , doesn't seem right to me.
  13. Heyo. So I'm not sure if it's normal or not looked at some other mj pics on the forum here. My back wheel seems pretty off center off the wheel well. It's not causing any problems I can see . Just wondering if any one else's truck is like this. It's about a two inch difference measuring of the flare
  14. Alright alright good looks. Running basically the same lift set up on my truck still tossing around what I'm gunna run for wheels and tires . Thanks
  15. Just leaving it as is for now wrapped the fog light wire up tucked it a way. Every thing is working as it's supposed to and that was the goal so that'll do for now
