Everything posted by comanche12
comanch12s 87 manche *11/30/11*
comanche12 replied to comanche12's topic in Member Projects: Your Comanches
I'm been working on my mj slowly but what did i do so far. finished drill mill and retap the C bracket for the the metal wedges and plates. brake upgrade drilled the rod 5/8" for brake switch finish installed. -
pics tell everything what I'm doing
WJ Booster and Master Cylinder Upgrade
comanche12 replied to Comanche County's topic in MJ Tech: DIY Projects and Write-Ups
i just finish installed booster and m/c no problem. but... I have one issue right now... brake switch. the brake light is stay on while plugged connector on the switch. i drilled 5/8 on rod perfect. no end play, seat perfect and tight. is it might be cause from bolt on switch begin too tight? :dunno: -
ball joint grease seal -- ripped
comanche12 replied to mjtjnj's topic in MJ Tech: Modification and Repairs
normal, most ball joint seals tend to be worn out but ball joint it self is fine. Important, try test the end play by wiggle your wheel. Same method with wheel bearing. :smart: just keep mainteance on it(grease it). don't put too much. Overdose greasing attratch dirts more. My opinion. edit: if no end play as abnormal, then your ball joints r O.K. -
try pressure tester on coolant system and check the leaking again? maybe leak from heater core? do you see any abnormal smokes come out from exhuast while engine running?
preparing to finish two projects on my jeep this weekend zj booster&M/C and metal wedge for front spring. :wrench: pictures will come up later :cheers:
or ddmtuning.com for cheaper and still great quailty :thumbsup:
3.86 for 87 in buffalo grove, IL
uni-bit sound alot easier for me. thanks for help! :wrench: i can't find 5/8 " with small base around me. i can try next time if uni-bit fail. Edit: got uni bit and hopefully it's work when I try it tomorrow :wrench: -
How long does your 4.0 crank before starting?
comanche12 replied to nitroxsteve's topic in MJ Tech: Modification and Repairs
x7 mine cranking for like 3 sec. i checked fuel pressure, its still fine and spark fine. so i agree with you guys. its might be renix thingy :roll: I'm still gotta to get used with it compare with my subaru. started fast -
i have a issue with 5/8" drill bit, none of my drills r able to adapt this 5/8" even air power drill at my work won't able adapt it. is there any way to get it fit in adapter? -
done remove booster and M/c but pause work on it because need vise grip to hold the rod to able drill it with 5/8" drill bit
Starting work on brake booster and master cylinder
I have similar front d44 from your ford. mine is from 78-79' ford bronco. HP d44. pretty sturdy d44 compare other d44 i has seen. here good link to get parts for ford d44 www.broncograveyard.com BTW- awesome pictures of trip. I wish i can join! :cheers: Sean :wrench:
- 897 replies
- dana 44/8.8
- arb lockers
- (and 3 more)
Let the build begin
comanche12 replied to 89comancheowner's topic in Member Projects: Your Comanches
awesome ride! hey is it from IL? i think i saw it on CL somewhere in Chicago list. :dunno: -
check grounds too?
got ZJ booster yesterday. its exactly same with wj but cheaper price :D right now, I'm at lunch break and waiting for guy to come pick my wegde up and hopefully able drill mill it at his engine rebuild shop :cheers: more projects r finally able to start work this week and weekend! :wrench:
i just came back to home from junkyard. i didnt buy the parts,. they charge me 150 for brake parts so i decide to buy it from autozone for only 120 dollars both booster and m/c brand new and lifetime warranty. even they r bendix ;) i can buy sway bar later. there plenty zjs and xjs in junkyard. edit: done bought booster and m/c for 120ish dollars and fuel filter too. :wrench: booster will be here at july 12 (tuesday) :cheers:
otw to junkyard to get wj brake booster/mc and poss. ZJ front sway bar! :wrench:
ok thanks man! :cheers: I'm gonna call near by junkyard to see if they have. i know one little far place has plenty zj and xj tho. found a junkyard same one that i got proportioning valve for good price. 65 dollars for booster, mc and front sway bar -
I'm planning to work on it this weekend! right now during lunch break at work, I'm researching now :wrench: :cheers: edit: wj is '99-'04 grand cherokee, right? if yes, can i get any either those year to pull the parts? -
my mj project. current name "project over"
comanche12 replied to lostissues's topic in Member Projects: Your Comanches
Awesome project! I'm think about do those aux fuse panels. Is it easy? Keep it up man and don't give up! Btw awesome 2.5RS! Is it 01? I'm myself a loyal to Subaru and I have 07 2.5i auto with little modification. Soon it gonna handling better than STi... :brows: -
i would start with master. the master is one with resvior tank of brake fluid in it. its right next the brake master cylinder on firewall
New MJ Owner: Tons of questions
comanche12 replied to MJCrusader's topic in MJ Tech: Modification and Repairs
welcome to jeep world. Just Empty Every Pocket ;)
