4
Everything posted by JMO413
No mine has/had the front door plate and no tow hooks.
1988 MJ Pioneer RWD 4.0/AW4/D35
JMO413 replied to floridaftwman's topic in Member Projects: Your Comanches
Check the ground tab in the socket they like to fall apart. It's on the side not in the bottom. That was why mine wouldn't work. -
Mine pulls nicely to 4000 that's all I've ever pushed it. Glad to have so many responses all worth thinking about. I wish I hadn't spent money rebuilding the original D30.
I believe the second letter is the engine. Up to 88 I believe 87-90 91-92 I believe the parts book is wrong in the engine year somewhat. Does that look right with what your seeing?
I don't plan on towing with it ever. I have a WK for those jobs. Just stuff in the bed. I have a D35 and a D30. That leads me to the next step. Regear or swap out. Either way I only want to do it once.
I agree it was awesome to see all of the trucks in the registry. Glad I could help. 5/2/92 was the youngest. Did you find an oldest? What body codes are you trying to figure out?
1J7FT66S0NL248684 is the youngest MJ in the registry 5/3/92
I have no idea. I just copied and pasted the build sheets. I had to type in the body model and build dates. The only build date I can remember is 8/8/88. I was doing it on dual screens at work during dead time. Was fun to see all the pictures though.
And that is why this site is awesome!
Any one like their VIN decoded? At home with the computer on. Let me know
You can always hope!
Agree with Pete
There's not an option code for the front axle. There bad news is the parts catalog only lists a Dana 30 for a front axle option.
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT -SA CHARCOAL 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount 4AF American Coin Merchandising ALA SE Decor Group ALK Italia Package APA Monotone Paint BAP 75 Amp Alternator BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWX EAGLE/SUMMIT DECALS BL LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAE California Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PB3 Intense Blue Pearl Coat QB3 Intense Blue Pearl Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII
Welcome.
I think that's backwards. 44 ÷ 28 × 3.07 = 4.82 Wait 3.39 would return it to stock. Gotcha now.
33 are a no go on this one maybe the next one lol. Not worth it on a DD. I found a similar equation on here. OTD- original tire diameter NTD- new tire diameter CGR- current great ratio EGR- effective gear ratio OTD÷NTD ×CGR =EGR 28÷30.8 ×3.07 =2.79
So the question of the day is what differential ratio would you run with 31's? I have come to the point that I really need to regear my differentials. 3.07 are worthless with 31's. 5th grear might work on Nebraska interstate.Looking for opinions on what ratio you run or would run. The truck is usually my DD unless it's torn apart again. It sees the highway daily. It is my only truck so it does get to haul everything. Mud/field/snow/level B road is about the extent of of road. 3.55 would put me back to almost stock. But should I go lower? 3.73,4.11? It's allot of work to do twice. I know this is an opinion so all are appreciated.
Long bed gladiator!
Agreed! The sad part is think of the time spent.
