Everything posted by boxyjeep
Guy just posted this up on FB. Probably one of the most rare/low mile MJ’s in existence. Look at the boost gauge on the cluster (I’ve never seen that before). Also some weird bumpers/roll bar parts. https://www.facebook.com/groups/1402616813111625/permalink/9749910355048854/?mibextid=W9rl1R
Long bed Roll Bar
boxyjeep replied to GrandComanche's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
And it’s gone -
There is one for sale in Wallingford CT. Take a look on FB Marketplace.
Project Uncompahgre - 1989/1999 MJ
boxyjeep replied to USN_JeepMJ's topic in MJ Hardcore Tech: Epic Journeys to Greatness
That's awesome. Great to see it getting some solid use. What sliders are those? -
In stock and ready to ship. One full set of replacement brackets for your Jeep Comanche MJ mud flaps including new hardware kit. Typically, the rubber mud flaps are very resilient to wear, however the original steel brackets had a tendency to rust and degrade over time. Includes (2) front brackets and (2) rear brackets for 1986-1992 Jeep Comanche MJ. CNC designed and laser cut using 16 gauge stainless steel. All necessary hardware included (also stainless steel). Rear brackets are an improved 1-peice design over the original 2-peice configuration. These are the brackets found in OE mud flap kit 82200793 (front) and 82200795 (rear). Brackets can be left raw or painted if desired. https://boxyjeep.com/products/jeep-comanche-mj-mud-flap-bracket-kit-1986-1992
Location would help
Good point, I didn’t notice that empty spot. Anyone else know what’s supposed to be there? Perhaps it should say “Upcountry” underneath…?
Take a close up picture and provide the dimensions and I can clone it. I also have the UpCountry stickers available… https://boxyjeep.com/products/upcountry-suspension-decals
Ahhh got it. Yep, definitely need the plastic cap to stick those to...
Looks like someone already makes those center caps:
I think I may be able to get these down to $79 a set with galvanized steel ($99 with hardware kit). How does that sound? Yes, I also played around a bit with the two options. The 2-peice configuration allows each side to be identical. Moving to a single piece requires two configurations based on left vs right side. The ones I make will likely be 1-peice in the rear as that seems a bit better and cleaner.
I'm likely going to reproduce mud flap bracket kits and wanted to gauge interest before I invest in getting a batch run done. The rubber mud flaps themselves can typically be reconditioned pretty easily, but the brackets are known to rust right off. Likely cost for a full MJ set will be around $130 for all 6 stainless steel brackets powder-coated black with all new necessary hardware. Just bring your existing mud flaps and you're good to go. Materials will be all stainless steel, CAD designed to factory specs, CNC laser-cut and bent. LMK!
Thanks, this is helpful. I've been dabbling in metal parts and custom decals, which have a much lower cost of entry.
Interesting. This is a dealer program?
Do you have the ability to make injection molded ABS parts?
How do you generate these @eaglescout526?
Jeep Comanche Tailgate Wall Mount Kit
boxyjeep replied to boxyjeep's topic in Vendors- members making products for MJs
Haha! This kit will bend a bit… my tailgate certainly was not in the best shape. -
Thanks--it uses the tailgate handle holes and threads to attach. -
This kit will allow you to show off that Comanche tailgate you've been hoarding all these years. No better way to flaunt your stash to those without a working tailgate of their own than with this kit. Made of CNC laser-cut and bent 14-gauge mild steel, this two-part bracket system allows for quick and easy hanging on your wall. Width is approximately 20" to allow for attachment between two studs. https://boxyjeep.com/products/jeep-comanche-tailgate-wall-mount-kit
6.5" Rear Speaker Brackets
There is 1.5” from the back of the bracket to B pillar. I’d advise measuring your speakers and getting these types of spacers in 1/2” or 1” thickness. https://amzn.to/3W7pMnu -
Just saw the order come in—thanks! Will get those out early for you. -
DM me--I can reproduce the door sticker.
