Everything posted by SatiricalHen
Customish Clock Panels
SatiricalHen replied to SatiricalHen's topic in MJ Tech: Modification and Repairs
Read the post above yours. Sent from my iPhone using Tapatalk -
My truck came without intermittent wipers and I would like to add them. I need the parts for a fixed column truck, or the part numbers or anything I can get towards the right direction. Sent from my iPhone using Tapatalk
I thought I saw someone saying something about the bulbs in the factory switches burning out or something, well I got a fog light switch in the mail today and it looked pretty close to the same idea as the 97+ switches I’ve taken apart to swap guts before. So I took it apart. I’m sure you can take it apart more and I could’ve taken the switch and bezel out as one if I was just getting to the light, but it’s just a bulb with some leads soldered to it. I know for a fact I have LEDs laying around that would fit it well, and I might even have incandescent bulbs somewhere, but I just thought I’d share this little tid bit. Just in case someone was wondering, but hadn’t gone into tearing their own stuff apart yet. Sent from my iPhone using Tapatalk
I don’t really have a need for it, but figured I had the ability to do it where others do not. I may try to put my REM in the panel possibly, but we’ll see. Sent from my iPhone using Tapatalk -
i haven't really thought out price yet. I was just trying to gauge interest before spending too much time test fitting and designing different layouts. -
well I felt like procrastinating some homework so here’s the blank that I drew up. I can add more fillets or adjust some measurements if need be. I will obviously print one and make sure it will fit correctly in my Comanche before trying to make them for others. Sent from my iPhone using Tapatalk -
College Budget 1987 MJ Build
SatiricalHen replied to SatiricalHen's topic in Member Projects: Your Comanches
So with tax return money coming I think I’m finally going to put a nice exhaust on the truck instead of the hacked together pieces. So here’s some questions. 2.25 or 2.5” pipe, what exhaust manifold, or just go with any eBay special?, and should I leave everything factory location or what? I think I like the factory side exit, but I’m open to idea on how to the the tail section Sent from my iPhone using Tapatalk -
87 AMC Comanche Manuals
SatiricalHen replied to Comanchejeepgal's topic in MJ Tech: Modification and Repairs
Basically a test bank for jeep manuals and diagrams. Sent from my iPhone using Tapatalk -
It would be convenient since the link just needs to be shared and anyone can access it without needed to have it personally emailed to them. Sent from my iPhone using Tapatalk -
Could these big files be put in a google drive possibly? I know we have a google drive test bank that has tons of notes, tests, and book solutions in it. Sent from my iPhone using Tapatalk -
So I have access to a 3D printer, Solidworks, and I have my old clock delete panel. I see people adding things to 91 clocks like the Mercedes temp sensor and stuff. So here’s my question. Would anyone be interested in a slightly customizable switch panel? I plan to make a blank in solid works and then I can cut holes for switches (square, round, or whatever you want), cut a hole for the temp sensors display, or whatever can physically fit in the panel. Would anyone like one of these? Sent from my iPhone using Tapatalk
Gjeep Son of a Stink build thread. He used Chinese regulators for his 1 piece windows. I would love to put some 1 piece windows in my Comanche with a manual crank Sent from my iPhone using Tapatalk
found a list of junkyard upgrades :)
SatiricalHen replied to Pete M's topic in MJ Tech: Modification and Repairs
The first post says that the list is for XJs so keep that in mind. The 8.25 would be a direct swap for them. Sent from my iPhone using Tapatalk -
uh-oh. Negative Camber....
SatiricalHen replied to coolwind57's topic in MJ Tech: Modification and Repairs
If the wheel bearings are bad enough it could cause negative camber Sent from my iPhone using Tapatalk -
A little late to the game, but I’ve always had good luck with craftsman’s warranty. The issue is that I’ve broken a lot of their ratchets and a lot of their sockets. Lately I’ve been using a long handle gear wrench ratchet for everything I can and it’s held up to a lot of abuse. On top of the abuse it can take it’s an 84 tooth ratchet which is a lot finer than any craftsman wrench I’ve used. Sent from my iPhone using Tapatalk
Factory Switch Darkening
I don’t plan on it unless I win the lottery or somehow find it for dirt cheap. Sent from my iPhone using Tapatalk -
Man that NOS switch looks really good. I looked up the price of a new switch and for an autozone one it’s like $45. Not sure if it’s that worth it to me. Sent from my iPhone using Tapatalk -
Maybe next time I go to the junkyard I’ll grab a few random switches out of a Cherokee or two and see if I can try different things and darken them up. Sent from my iPhone using Tapatalk -
I've noticed every factory switch from this era Comanche/Cherokee seems to be light grey and chalky looking. I was wondering if any of you had found a way other than painting to bring back the darker color of the switch. Thanks in advance!
Intermittent Wipers in Fixed Column
SatiricalHen posted a topic in MJ Tech: Modification and Repairs
I was trying to look online for the parts to swap in intermittent wipers on my Comanche, but all of the parts either were listed as tilt column only or didn't list what they fit. I was curious if anyone has added intermittent wipers to a fixed column, if anyone has any part numbers or info on where I can get what parts, and if I can use tilt column parts, but with some small modification or something. Thanks in advance! -
92 MJ Gambler 500 Build
SatiricalHen replied to GFY Racing's topic in Member Projects: Your Comanches
Do you consider those tail lights “usable parts”? Sent from my iPhone using Tapatalk -
I see you swapped in the 3 spoke wheel, what all did you have to grab to do the swap? Also, does your horn work on it? I’ve been wanting to swap a 3 spoke wheel into mine, but want to make sure the horn will work when it’s all said and done. Sent from my iPhone using Tapatalk
Project - One of a kind...
SatiricalHen replied to SteveW155's topic in Member Projects: Your Comanches
I see you mentioned converting it to RHD. Personally I think it adds to the novelty of it to leave it LHD. Over here in the US I’ve been wanting a RHD Cherokee just because it’s different and I think it would be fun once you get used to getting in on the other side and driving on the other side. Sent from my iPhone using Tapatalk -
Just thought the picture looked kind of cool. Still need to get the LED turn signal relay, but haven’t found the right part number yet, and still need to figure out the high idle. It runs and drives still though. Sent from my iPhone using Tapatalk
