Everything posted by PCO6
EDIT --- I basically stated earlier that the cooling systems on my RENIX era MJ & XJ have been trouble free. NOT TRUE. A few years ago I was about to take my MJ in to Krown Rustproofing to be sprayed. I took it through the car wash the day before to clean the underside. It was the first time I did it and I don't plan to do it again. About a km later the block heater fell out. It over heated and when I pulled over it was pretty obvious what had happened. There was a trail of coolant and it was literally dangling by the electrical cord. I doubt the cord caught on anything and I can't imagine that the water pressure knocked it out. I've never had that happen before but I've had enough of car washes.
One of my brothers runs a '68 Mini that he converted to a closed system. I did the same to a '60 MGA many years ago. Not sure why I did it back then (late '70s) other than some of the "cool guys" had it on their race cars. I'll take a closer look at my Dorman cap. it sound like I might want to replace it.
As far as I could tell the pressure bottle in my XJ was the original (30 yrs.) and that's why I replaced it. I'm about to do my MJ for the same reason. I also couldn't see what the coolant level was and got tired of using the wooden dowel dip stick I made for it. I have a NOS closed system radiator in my shed and haven't really paid attention to whether new ones are available. I'm not opposed to converting to an open system and if the rad supply dries up that would be a pretty good reason!
I'm not surprised that some after market parts (Dorman & others) don't last as long or perform as well as OEM parts. The bottle on my XJ has only been on for about 5-6 months and no leaks ...again ... so far. I bought a new XJ back in '90 and never had a cooling problem, all OEM of course. The ABS brakes were another matter. The final straw was a brake job that cost me 10% of the cost of the vehicle. I have TJ and an LJ as well. Both are open systems of course and I admit that I prefer that. They both run fine too. Funny thing, I just replaced the OEM over flow bottle on the LJ. It cracked after 15 years and it just sits there. lol.
I can see where the bottle and cap could become a problem. I replaced one of mine with a Dorman product earlier this year and so far so good. I generally get my parts from NAPA and the dealership when necessary, plus a bit on line. I haven't been stumped so far and everything I've got seems to be decent. Are there some cooling parts that are known to be problems or that are unavailable?
Perhaps a dumb question but I'll ask it anyway. Apart from eliminating the heater control valve, what is the main reason for converting from a closed to open system? I have a '88 MJ and a '89 XJ, both with the original closed systems. I have no cooling issues with either. The XJ has AC (2 fans) and the MJ does not (1 fan). I've driven both all day long in hot weather at highway speeds and at times in stop and go traffic. I maintain both systems (coolant changes, flushing, hoses, belts, pumps, etc.) in stock form. The only thing I don't like is not being able to pressure test them. Both run a bit different. The MJ stays at 100* (212*) and doesn't move. I'll probably be adding a stock Jeep electric fan to this one. The XJ is always a bit below 100* but it fluctuates which I take as the electric fan kicking in or the thermostat (MOPAR) opening and closing. I tow a 1,600 or so pound tear drop trailer with the XJ and all is good. A lot of what I read says "do it" but I can't see making the change when all is good. Maybe I'm living on borrowed time and should move this up on the list of things to do.
Sport Bar Installation Question
PCO6 replied to fiatslug87's topic in MJ Tech: Modification and Repairs
I cut up a piece of rubber BBQ mat for mine and it worked fine. It's a bit thicker than the original gasket material and at 30" x 48" I have plenty for other projects. https://www.canadiantire.ca/en/pdp/master-chef-rubber-grill-pad-30-in-x-48-in-0852146p.html#srp -
Prices are all over the map and like many car parts that aren't plentiful they're worth what a buyer will pay. I saw an MJ tailgate at an auto flea market last Fall and the guy was asking $600 CDN (about $450 US). There's no way I'd pay that unless I desperately needed one. I walked by the same booth a few hours later and it was gone. A few months later a guy from the neighbourhood puled into my driveway, opened the back of his Suburban and said … "do you want this stuff?". He gave me a perfect MJ tailgate plus several other MJ parts at no cost! Auto wreckers around here have set prices for items that often don't make sense. I got a pair of near perfect driving lamps or my LJ for $7 each. To them they were just head lights. Bucket seats go for $35 ea. whether they're leather or ripped up fabric. A friend got a tailgate for a TJ (granted, not nearly the same as an MJ) for $25. If it was for an MJ I'm not sure if would have been much more.
What looked like a decent J-10 was on the block at the Toronto Classic Car Auction this past weekend. I didn't stick around for that part of the auction so I'll be curious to see the results when they post them in 2 or 3 weeks. It's the second time, that I know of, that it's been at this auction. It had a reserve price both times and obviously it wasn't met the first time.
c51a6a4604ae81707d89513f029476ffx.wdp.jxr
Most of the problems with SU carbs can be attributed to worn throttle shafts where they pass through the carb body. The brass shaft (1 per carb) rotates through the aluminum carb body. Both the shaft and the body wear over time and air is sucked in through the sides of the carb body. That basically makes them impossible to balance. If you're doing a rebuild (gaskets, needle & seats, floats etc.) it's best to replace the shafts and install aftermarket bushings at the same time. Any of the British car retailers like Moss Motors will have them. If you have the carbs apart look at the shafts and bodies and it's pretty easy to see how they wear out. Sometimes you can grab the shafts without taking the carbs apart and wiggle them (vs. rotating them) and it will become obvious how air is getting sucked in from where it shouldn't be. I've seen some that are almost comical. You could literally poke a small screw driver through the side of the carb. Replacing the shafts and installing bushings will require a line reamer. It can be done by hand (no machine work) but you need a line reamer to match the O.D. of the bushings. Those look like the original SU's btw. I think they're H4's ... but I'm trying hard to forget everything I can about them. lol
How true! I actually liked the pics. They were the best part ... except for that weird hand drawn nonsense.
I did more studies and wrote more reports than I care to remember (happily retired now). I learned early that clients and politicians won't hire you again if you can't get to the point quickly! That was my way of thinking too ... "I don't waste time with time wasters".
I had the same problem. I found it funny that the author said he's learned how to "communicate economically". I think he needs to reconsider that.
I have an MJ and an XJ (plus a TJ and an LJ). '88 MJ Eliminator ... '89 XJ Limited ...
Mine are the same as the ones posted by fiatslug87 above. I have 2 '88 MJ's and both sets are the same as his pics. One set is the same condition and the other is worn but quite a bit better. Funny story about the one set is that I bought the MJ as a parts car that had been sitting outside for 19 years. The vendor could not find the keys. Arranging for the purchase and pick up went on for about a month. The vendor phoned me all excited one day to say that after turning his house upside down he found the ignition key (it was a recut key - no complaint). When I picked it up, I lifted the driver's floor mat and the original keys had been there for all those years! That "parts car" turned out to be a LOT more than that. It will not be parted out!
Old post but I thought I'd chime in by saying that a lot of the woody restorations you see are actually painted not vinyl. This was a common process on the dash boards and other interior parts of older cars. It's just done on woodies on a bigger scale. One of my brothers has a '66 Ford Country Squire with painted wood grain. I think the only way you can tell is that it looks better! Vinyl covering gets dull over time vs. paint which does not if you maintain it. The real problem is the "wood" trim which is usually a lighter colour. Not sure about Jeeps but a lot of them are made of fibreglass. There are a lot of pieces and if some are missing or broken it can become very expensive.
I prefer stock rims too and it's MOAB's for me. I have them on all of my Jeeps (MJ, XJ, TJ & LJ) plus on my expedition trailer. MOAB's with 245/75/16's & no lift.
My '88 MJ has AMC logo keys and my '89 XJ has Chrysler keys. Both have "Jeep" on them.
Nice find. Those look a lot like a set I have. They were on the sport bar of a parts MJ that I bought a few months ago. They were on the bar but not connected to a wiring harness, switch, relay, etc. The owner said that he got them at a dealership. The covers appear to be the same. The lamps are similar but the housings mount differently. The lamps measure 6" x 3" and have "JF" on them (not sure if that is the brand). My problem is that the rings that retain the lamps are badly rusted - no doubt the covers retained water and caused rust.
'89 Eliminator Near Ottawa
PCO6 posted a topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Asking $2,000 Canadian. https://www.kijiji.ca/v-view-details.html?adId=1366886744&utm_source=alerts&utm_campaign=Kijiji_Alert_LISTACTIVEADS&utm_medium=email -
Cherokee vs Comanche Blower Motor
PCO6 replied to Cali Cruse's topic in MJ Tech: Modification and Repairs
LOL ... very true. BTW - road salt (= rust) is a good thing. It makes us better welders! -
I agree, grounding directly to the block is a good thing but the other wires could have been grounded to a different and more accessible location. The ones I've cleaned up have been an oily and somewhat frayed mess down there. I haven't looked at this carefully but I think that running a 4g cable back up to the fire wall and grounding the secondary wires there might be an option. I replaced the firewall ground strap on the left side with a 4g cable to the manifold. That's a bit far away but a similar thing on the right side might work. -
That's one of the first ones I would have got rid of!
