DansGreyMj
Everything posted by DansGreyMj
  1. i wouldnt buy it unless it comes with that gator sticker
  2. why not put a leveling kit on it?
  3. check out ford-trucks.com or the ford section on pirate
  4. those gorilla bodies look like crap compared to this thing not to mention they're like 8k+
  5. probably the best looking homemade hummer ive ever seen
  6. I'm in Tn now, but I'm broke right now so it wouldn't matter.
  7. i want those black buckets
  8. If you don't have tags on the diffs; put it in neutral, jack up the rear both tires off the ground and spin the driveshaft and however many turns of the driveshaft it takes to make the tire go around once thats what ratio you have.
  9. thats a Ram hood ornament
  10. did your parents send it to the dump?
  11. i like it, it looked almost like a rat rod with those white walls though.
  12. don't u guys remember when conv. pickups were all the rage, i remember seeing a conv. kit for an mj online like a year ago.
  13. for roughly the same price u can get the rough country 4.5
  14. i thought you meant a stang gt, i like this one http://turbofordgt.com/ ( watch the vid)
  15. the part that confuses me is that u were helping a chick than all of a sudden she turned into a guy with a coll car collection, lol, btw is it a regular stang gt or a shelby
  16. Ha Ha "reamed" :D no its bolt on like jackel said, even with the messing up the alignment this my be the smoothest mod that i have done so far. other then fixing the shift knob that kept pulling off (pull of knob remove screw-on spacer, screw knob back on, stoopid PO :D ) are the TRE's any stronger than stock and does the tie connect both knuckles or is it like stock
  17. alignments usually run like 60 bucks, is that steering kit bolt on or does it have to be reamed.
  18. looks good, what brand/size lift and are those 34s
  19. more info on the rails and mounting pics
  20. you sure that those are 97+ doors because if i put them on my mj i would not take the time to swap in the small windows and old mirrors, and btw i think they used those emblems on some pre97 too
  21. these are some of the questions Oj was asked during his interview this week http://www.youtube.com/watch?v=UU0ZSNVv7J8
  22. whats the hub to flare measurement with those coils
  23. don't forget that if u flip the steering you need to raise the sway bar mounts on the axle. and Lead not follow does that kit only flip the drivers side
  24. what size coils are you running up front
  25. what if you did that swap and still ran rear drums?
