Roblesland
Everything posted by Roblesland
Motor mount identification
Roblesland replied to PhilisDiller's topic in MJ Tech: Modification and Repairs
Motor mounts do range from $ to $$$ and you have free ones so... somebody bought them for a reason. Most likely you have the original mounts. I would use them. -
Derf, thanks again. It arrived yesterday.
I wanted to see if anyone had a rear light harness that you could part with shipped for not too much. Let me know Thanks
Bucket Seat Upper Lever Bezel?
Roblesland replied to Wodex's topic in MJ Tech: Modification and Repairs
It's like forging for mushrooms in the forest... jy's will have them on 2 dr XJ's not sure if the 4dr ones have them. -
No, not black. Simply wanted to give an example of price as to what you could pay if you found those same seats at the JY. That would be a good find. Black Is Rare
Making XJ buckets work in a MJ
Roblesland replied to mfpdm's topic in MJ Tech: DIY Projects and Write-Ups
I think these are the rivets that need to be drilled out to make this happen. They seem to keep the wheel on the track from going past them. I bought a pair of '88 2 door seat with the brackets that tilt for $80 at the JY without either measuring my bracket or the XJ I was getting it from thinking its an '88 Loerdo like my MJ if it doesn't fit, how hard could it be? Starting with the passenger seat. Has anyone else tried this? -
I just bought a set of seats with the brackets from the JY and paid $80.00 for the pair. $150.00 ea. seems fair. They look to be in good condition. Good luck
I am going to be doing the exact same thing. Thanks for the picture.
On my way to something else I came across this site which I thought might be of interest. https://leencustoms.com/pages/customs I think they would make great xmas gift or....
Put the marker on the Comanche, looks like there is another MJ in Oxnard. I'm digging the map.
Jeep Turbine 10-Spoke Rims Restoration
Roblesland replied to NEO auto's topic in MJ Tech: DIY Projects and Write-Ups
I've had these turbines for over 10 years and always wanted them black. It was only that I know a guy that did me a solid and sandblasted and powder coated them black for me. I'll be wrapping them with 31's and they look way better then anything I could have ever done. I went the easy route. -
Pictures of Comanches with Toppers.
Roblesland replied to knever3's topic in MJ Tech: Modification and Repairs
Bored throttle bodies
Roblesland replied to MeanLemons's topic in Vendors- members making products for MJs
I just sent Message -
Added Oxnard, Ca.
What did that two door do to become a donor?
Got back from the jy and there was not a corgo light or switch.
I did not notice if it had a cargo light. It had a shell on it. I'm going back to the JY this weekend and I will double check. I'll grab it if it does.
Found this 2.5 2wd at the local jy. Someone had already harvested the tranny and the interior, badges. i took the rear lenses, tailgate and rear flares and I think i'm going to get the spare tire lowering assembly. Haven't seen one at the jy for a while. it's in Santa Paula, Ca.
88 Laredo with a long bed straight six 2wd with dana 44 AX15 I think I've had the truck for about 5 years and it was DD for the first 2. It still drives like a bat out of hell even at 349 and change not sure if the engine or trans are untouched. Crazy plan is to make it 4wd its just begging for it I've learned alot from the forum and thought i'd check in and say good job all.
