Everything posted by Airborne Janitor
HO Dome Light Wiring
Airborne Janitor replied to acfortier's topic in MJ Tech: Modification and Repairs
It doesn't help that you have the wrong size terminals on your wires. You should use RED ones, those yellow ones are for much thicker gauge wire and may not crimp correctly on your wire, leaving a lot of wiggle room on your connections. -
February 2023-The Comanche by the Sea
Airborne Janitor replied to 89 MJ's topic in Comanche of the Month (MJOTM)
I run the same shocks, and was told that Bilsteins are supposed to be mounted with their logo facing upright. I ended up just cutting the boots off so they wouldn't be dirt catchers. -
comanche door decal/emblem
Airborne Janitor replied to huevo83's topic in MJ Tech: Modification and Repairs
https://www.phoenixgraphix.com/jeep.php makes nice decals. I did make some graphics for the new style "Comanche" font, but ultimately I went with the Conthrax SB font instead for cleaner results. https://www.dafont.com/conthrax.font -
Love the look of this truck. BTW your rear shocks are upside down. -
You guys have probably seen pictures of dudes in 3rd world countries welding using beer bottles for lenses, cardboard boxes for welding helmets, etc. Well my friends and I decided to try out some of these methods over the weekend, to disasterous results. Lots of profanity in this one so be forewarned. And my MJ is in the background so technically it's MJ related, right?
Coolant unexplained loss.
Airborne Janitor replied to Classy Comanche's topic in MJ Tech: Modification and Repairs
Mishimoto 3 core aluminum radiators are tough to beat, but they're like $450+. I've scored a couple off ebay that were open box and paid half price with no issues. Otherwise try these guys: https://ffdynamics.com/products/ols/products/cherrad -
upper HVAC cowl seal
Airborne Janitor replied to Pete M's topic in MJ Tech: Modification and Repairs
There's my cutting board! -
I really appreciate that!
I've built a few PVS-14 night vision optics, and decided to document the build process on my last one. I like these for star gazing more than anything else.
Door Jam Switch Replacement/fix?
Airborne Janitor replied to Warren99's topic in MJ Tech: Modification and Repairs
AC Delco D6088 is the part you want. https://amzn.to/3YLbWHx I used to pull these from the junkyard but nowadays most are all rusted and corroded. Super easy fix, just unbolt the old switch, unplug it, install the new one. -
I upgraded almost all my interior...except the bench seat! If I want buckets I have my XJ. Love the bench + column shift combo.
If I had to guess someone sold the 44 from your rig years ago. Even if the 44 needed parts it would've been easier to fix it than to swap in a whole nother axle, unless the housing was toast or it needed new gears.
Front shock recomendation
Airborne Janitor replied to Whitaker717's topic in MJ Tech: Modification and Repairs
2ndedededed. -
The Fey bumper has 2 sets of mounting points, so you should be able to get it to fit. Maybe you'll have to use some spacers? When I added a hitch to my MJ I had to fab some 1/2" spacers because the bumper wouldn't fit on the original brackets in the same position, because of the added width of the hitch plates.
