poopypants
Everything posted by poopypants
  1. we've been the last 3 years and as shelby stated above its a JK bolt-on fest...hardly any old metal to be found i have seen only one other woody down there and it was the wears woody cloths guy...we will be in this that being said its a good time well because its the beach and there are jeeps...the show at the convention center was a cluster last year the beach crawl is pretty cool if you can get signed up before it fills up (250 spaces) and the jeep jam is kind of a donkeyfest mud pit open diff JK recovery show but still fun to watch. took the cj 2 years ago and drove on the small rock pile which was cool. i know i just complained a bit but we are def going again because its kinda hard to mess up a jeep show at the beach. you will have fun. BTW I've seen MAYBE 5 comanches there in 3 years
  2. Not a fan of these refs Good game though 35 secs left
  3. A pink camo jk cruising through jihadistan with Katy perry blasting over some 6x9's would make Isis leaders cloth laden heads explode...so I say order 1000 of them and load up our boys iPods :)
  4. This ... Also when my chain finally stretched enough to start jumping teeth you could hear it dragging along the bottom of the case just driving around in 2wd....just something else maybe to listen for proving a stretched chain
  5. But nothing is worth doing if you can't do it twice...now your twice as experienced ;) I don't think I've ever 'cut once' ha
  6. Reread and I'm following you now... Did you put the tires on and set the truck back on the ground to set the final positioning before tacking it up? That part always seems to take the longest as I measure like 200 times Like the other guys said I would make sure they are the same measurement as the front hangers
  7. The 8.8 is offset a tad to one side...leave it alone You will never notice
  8. If $20 bothers you just reuse them...I've cut them off with an angle grinder and reused them on a couple different soa projects...doesn't really take that long
  9. D. None of the above Save for a winch ;)
  10. I'm not positive but I think you're trying to use the Chewbacca defense on me...I'm on to it Next there will be bees....everywhere
  11. Buy a real warn! Save for a bit longer and spend the money No such thing as a budget winch if you wheel a lot. If it's for random yard work then fine buy whatever but don't ruin your friends day when on the trail with a shiny bumper ornament :) Seriously though when you need a winch that usually means your in a jam...and it's raining...and cold...and you're hungry ...and your wife is mad So while it's not quite the same as life or death, would you buy a gun that might fire? Or one that will definitely fire... Just my .02
  12. poopypants
    MD guys
    This is well worth the ride...get there early on Saturday to hit the swap meet http://pajeeps.org Pa jeep show York pa July 18-19
  13. This is how I learned about boxing... (If bad words offend you don't click) https://m.youtube.com/watch?v=Il9jJObx7FE
  14. I'd tell them to get off the jeep... For reference https://m.youtube.com/watch?v=-NmzN448J7E
  15. ^this^ Bfg white out for proper sweetness
  16. If your just doing some driveways you will be fine I had 5+ inch lift and 35's on mine for a couple years and it worked fine The only problem is you will not be able to use the plow at an angle because the plow will lift one end a foot off the ground because the A frame isn't perpendicular to the groud...so straight on only But for light use I never had an issue and I'm kinda hard on stuff
  17. poopypants
    Got snow?
    Yay finally! Got about 8" plus today so finally got to use Plow Ripken this year for the first time Made some changes (a lot of changes actually) and it seems to work very well Dog had fun [/url]
  18. I like it...if you see a white mj reving next to you it's me being an idiot ha Against my better judgement I sat in the white one they had up at the PA jeep show 2 years ago and just spaced out for about 30 seconds Definately my first choice if/when I ever spring for a newer vehicle
  19. Nice...still jealous as I've gotten only a couple inches We got about 4-5 this week so I got to make a pass over the driveway Went out last night and the plow lifted but froze (need to change the fluid which is fun) since it's -3 outside Barreling down the road and I didn't realize I left it in float Plow hitting the pavement at 55 is interesting Don't do that
  20. I agree with the chain...find a decent incline and in 4wd bump it and it will bang loudly as the chain jumps The rattling is the stretched chain dragging on the bottom of the case Just pull the fill plug and put some sand in there and it will be fine...the sand helps engage the sprocket by decreasing lubrication ;)
  21. Nice! So far we have gotten enough snow to maybe make a snowcone :(
