cruiser54
    14
  1. Got any water pump rebuilders in your area?
  2. Excellent points^^.
  3. Have you gotten the actual number off the existing bearings?
  4. LOL. You'll need body armor. JK. Excellent info!!
  5. You'll get it. Curious. What 2 bolts did you use previously?
  6. Can't get a wrench in there?
  7. Get the 746 Volvo injectors. They use the same o-rings. If you really want to clean your fuel system and combustion chamber, get some BG 44K and add it to a full tank. At half tank, refill with gas and drive to 1/8 tank before refueling again.
  8. Okay. Good point. Starter is still on one side and exhaust on the other though.
  9. Very odd since the starter is on the passenger side and the exhaust is on the driver side. which engine do you have?
  10. Sure you took the correct 2 bolts out? Look again.
  11. Look at the ten pin connector in the link below: http://cruiser54.com/?p=35
  12. She's probably a meter maid.
  13. Sure. Are you an electrical geek?
  14. This swap is easier than some will lead you to believe. And generally Pooh-poohed by those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it as swapping in a long block. XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange. 2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange. YJ and 1997-1999 4.0L TJ blocks will interchange in XJ/ZJ XJ/ZJ blocks, and the 2000+ TJ/WJ blocks do not interchange without significant modifications. TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ. Now that we know which engines we can use, let’s get down to business. The HO and Renix have some differences but none that can’t be overcome very easily. One running change was that the rear of the head was no longer drilled and tapped for the temperature gauge sender beginning in the 96 model year. The sender can be relocated to the threaded hole in the thermostat housing taken from an HO engine. You’ll have to extend the wire to that location. Some brave souls even drill and tap the HO head at the rear for the sender. You will be using the intake and exhaust manifolds from your Renix, along with all your sensors and wiring. Since the intake ports of the HO are slightly different, you use the Renix gasket. Exhaust ports are identical. You will need to use your Renix distributor as it is different than the HO design. See Tips #12 – Setting Your 4.0 to #1 TDC and #13 – Distributor Indexing to be sure you get the distributor installed correctly. The flywheel or flexplate from the Renix must be used so your CPS gets the correct signals. The valve cover from the Renix allows you to keep your CCV system intact and requires no modifications. The HO block will have a plug in the coolant galley on the driver’s side of the block, closest to the front, which needs to be removed so your Coolant Temp Sensor can be installed in it’s place just as it is on the Renix. It requires a 5/16” square drive or a modified 3/8” drive that has been ground down to fit. Do this before installing the engine. As for the knock sensor, which is located just above the oil pan on the driver’s side of the engine about mid way, all the blocks I’ve seen are threaded for it. If not, I’ve heard they may be drilled but not tapped. Tap the hole if that’s the case. XJ: “Regular” (not Grand) Cherokees ’84-’01 ZJ: Grand Cherokee ’93-’98 (Gen1) WJ: Grand Cherokee ’99-’04 (Gen2) YJ: Wrangler ’87-’95 (Gen1) TJ: Wrangler ’97-’06 (Gen2)
  15. I've taken the oil soaked starters apart a few times and cleaned them with brake cleaner. Pretty simple.
  16. It would be a nice way to get this behind you.
  17. As for the ground: http://cruiser54.com/?p=249 My thoughts on the pump: Where did you buy it? Does it have a warranty from a big box auto parts place? If so, could you get a refund or credit towards a Bosch pump?
  18. Understood. Did you replace just the pump or the whole sheebang?
  19. Why wait? Get the Bosch pump in there and be done with it.
  20. Gotta index the distributor. Here's how: http://cruiser54.com/?p=68
  21. This^^. And use only NGK or NTK oxygen sensors. Best preventative maintenance you can do is go to www.cruiser54.com and do Tips 1 through 5.
  22. I have a HV oil pump and run Rotella 15/40 year round. Runs like a SCALDED dog.
