88pioneer
Everything posted by 88pioneer
  1. This should help with the seat conversion :cheers: viewtopic.php?f=9&t=8093
  2. I agree with Eagle, dark dark blue would look really good :yes:
  3. i agree with everyone of your posts CW :USAflag:
  4. My cherokee had that problem when i had it. it was the multi switch
  5. This red enough for ya? I was never a fan of red, but its growing on me
  6. I'm assuming its 2wd by you wanting to do a conversion? If it is, a lot of people say that a 2wd with a locker is more capable then an open 4wd, so that may also be something to look into
  7. I got a currie bar. I like it a lot :yes:
  8. Search is your friend... viewtopic.php?f=2&t=21536&hilit=bed+dimensions And by tops, i'm guessing a fiberglass caps. there was a thread on this, it all depends on whos selling it. NOS caps are hard to find viewtopic.php?f=3&t=22332
  9. If you want to run a side dump you would have to turn it out pretty far up, by the door. When i bought my 92 it had a side dump that was run in between the frame and leaf spring :ack: . Rock magnet for sure. If you don't off road with it, it probably wouldn't be a problem
  10. I currently have a rusty's air tube and a cone filter for my intake. I was looking for ideas to make an intake that pulls air from cooler spots. I was considering running tubing from the intake to the whole behind the headlight (picture 1). Cutting a hole in the engine bay pointing straight down (picture 2). or running it to the DS fender which i don't have a picture of, but i got that idea from my buddies chevy pickup which pulls cool air from the inner fender. I'm leaning towards 3 but looking to see what other things people have done Image Not Found Image Not Found
  11. I like the looks of that thing, all black . And for the front end shake, it was the universals on my front drive shaft, now i have no front end shake at all :banana: . Hopefully thats what yours is too
  12. :agree:
  13. first check all your steering components and make sure they are all tight, and in good working order
  14. Nothing later than 90. I know 86 and earlier won't work, and for some reason i think there is something with 87 that won't work but not sure.
  15. Theres been lots of debate about lift from a spring over. It depends on your axle and how old your springs are. I have heard 7 with new springs and anywhere in between 5 to 7. Mine is only at right around 5 because my springs are old.
  16. :agree: with the lack of power. However, i feel that these are the only true jeeps that are still being built. My buddies mom has a black 4 door rubicon and its nasty . 44 front and rear selectable lockers and BFG mud terrains. I like them :thumbsup:
  17. Yea i was going to post this up but never got around to it. I'll be there most of the day probably. Should be a good time
  18. :cheers: thanks. I knew about the clips, but didn't know about the velcro. Appreciate it
  19. I plan on pulling my headliner backing sometime in the next week and before i get into it, i was wondering how its held in. I don't want to damage it since it is in relatively good shape. My other question was on the rear speakers (b pillar) what size are they? i think 6 x 4 but just making sure, slowly starting to upgrade things now that most mechanical things are fixed :cheers:
  20. Cleaned the throttle body and IAC, wired some reverse lights
  21. could just be a clogged fuel filter, especially since its been sitting, or the fuel pressure regulator
  22. i'll see if i can take a recording today, gotta get something with good sound quality to record it
  23. the other day while driving to school i heard a nice thud and then got a real bad vibration in the front end. Took it home, and went to school. Came home looked at it, looked like a problem with the PS axle shaft. Pulled the whole axle apart, and didn't find anything besides enough sand to build a sandcastle left in the axle tubes :ack: . Then i remembered that my front drive shaft universal was making all kinds of noise a few days before this all happened. Checked and sure enough the universal was totally shot. Got a drive shaft from the junkyard today and put it in. Not only did it fix the shake, it took away all of my front end shake :yes: :clapping: :banana: :chillin: :D . Now all i need is an alignment and the front end should be much better than it has been.
  24. i know a few of us have been talking about going to Rausch Creek over the summer, but i figured i would start this topic to get it out a little more an gain some more interest. The general plan sounds like the 23rd of July, i think jeepskool will be there. I was also planning on heading to the Jersey pines for a little bit of FREE wheeling through the woods. Not sure when, but the more the merrier for both :cheers:
