CobraMarty
Everything posted by CobraMarty
Dyno queen. Maybe in a mud bog buggy. Disappointed. Stock pistons with huge quench, Needed to port the intake runners and cut shorter the carb adapter insert portion. Surprised with that big cam and better flowing head and 4 barrel carb it only reved to 5000. Now do a real world build with factory EFI and ignition control.
I have them in 2 of my XJs and F150. Love em, wouldn't use anything else for the type of use we do.
Alexia's 1987 To 1997 Comanche
CobraMarty replied to Alexia's topic in MJ Hardcore Tech: Epic Journeys to Greatness
6 months later, What is the latest on this build? -
4 link build
CobraMarty replied to Little jeep's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Thanks, I was looking at ProFender 2.0 were like $1540 shipped with springs. I think that I will go with these FOA 2.5 for $1625 shipped. They are USA based and seem to have more offroad experience and advice. -
4 link build
WOW those are some big tires and wheels, 46s. What coilover brand are those? What spring rating did you use? Price? We need to come by and check out your build. My son is in your area on a regular basis visiting friends. -
Look at the Eastwood MIG 250. Bought one recently and it welds better than anything else we have used. $899, you get more than you pay for. http://www.eastwood.com/mig-250.html
Mnkyboys 89 Comanche project
CobraMarty replied to mnkyboy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
More details on the 2500/3500 master cylinder upgrade. What year? What do you have to do to the actuator rod?- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Had a bad running and stalling issue and found that when we redid the fuel tank pickup, you really do need the sock filter. We sucked up some fuel tank debris and clogged the fuel filter/water separator and clogged the fuel line from the tank to the fuel filter. Cleaned everyting, blew it out, replaced the filter and added a filter sock to the fuel tank pickup. Back running well. Now for the latest--
Diesel Fuel Only - Factory Diesel Comanche
CobraMarty replied to Automan2164's topic in Member Projects: Your Comanches
Had a bad running and stalling issue and found that when we redid the fuel tank pickup, you really do need the sock filter. We sucked up some fuel tank debris and clogged the fuel filter/water separator and clogged the fuel line from the tank to the fuel filter. Cleaned everyting, blew it out, replaced the filter and added a filter sock to the fuel tank pickup. Back running well. Now for the latest-- -
GE Nighthawk LED Headlamp Eval
CobraMarty replied to HOrnbrod's topic in MJ Tech: DIY Projects and Write-Ups
In my area the 55/100w bulbs are illegal and the GE/Trucklites are legal. -
Is that arm and TRE going to hit the spring on full left turn?
Cummins B3.3 Powered Mj Build!
CobraMarty replied to krustyballer16's topic in MJ Hardcore Tech: Epic Journeys to Greatness
To lubricate it? Vacuum in and out? and oil in and out?- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Thanks, I like that. I thought it was ? oil or water. Vacuum, umm, I got some ideas for that. Second that on the Red Line hood struts. We have a set and they work perfectly. I have looked at all the hood lift clones and keep coming back to the Red Lines.- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
What pump is that off the back of the alternator?- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Yesterday was outside shoveling snow and after was moving cars in the driveway. 20*F. Tried the diesel. Wasn't sure because the cold start mechanism was not hooked up. Glow plug light on, waited, light off and it sputtered, died, sputtered, died. After about 3 tries it caught, sputtered and then cleared up and idled and reved as usual. All this still with summer fuel and additive.
first start up. https://www.youtube.com/watch?v=LoQDxw_vljc
Son drove it like 200 miles today. He went to NJ and met up with some guys from here with 2 Diesel Comanches. He said it was quite a site with 3x 2.1 Diesel Jeeps all in one spot. So hopefully now we can get back to all the other little things that need to be addressed like getting the front drive shaft installed and getting back to 4WD.
Yesterday was warmer, 35* but no wind, snow or rain. My son installed the IP and all the fuel lines. Replaced 1 broken rubber fuel line. Pulled the radiator, crank pulley and re-timed the belt, the crank and cam didn't move, just had to time the IP. He is getting good at that, like the 10th time. Bought a bulb fuel primer and primed the IP. Went to crank and it only clicked. The ground cable pulled out of the cheapo battery cable clamp. Fixed that and it cranked and started. Sputtered and coughed until the IP was all clear of air. Idled fine and took it for a test drive. All is well, worked fine. Now he just has to burn out the 32 gallons of summer diesel fuel and add some winter blend. Knock wood, so far so good.
Driver side motor mount in. New Glow Plugs in. Fixed a few wires and splices. Tomorrow hopefully the Injector pump will go in and retime the timing belt and give it a start. Keep your fingers crossed. :thumbsup:
Keeping that bracket on the rear of the starter which bolts to the block is really important. I think that if it was missing then the weight of the starter plus it's starting torque will halp contribute to breaking the bellhousings which these are prone to have. Friggne snow and cold, no progress.
So in the end, none of the starters were right. Ended up using the old starter front nose and putting it on the RockAuto starter. Had to reclock the motor on the gear reduction to get the brackets in the right position for the rear mount bracket. Returning the ebay FL starter. Pic is correct, the starter they sent is not as in the pic. Installed the starter and glow plugs. The glow plug controller I got from RA was wrong, that's OK as my stock one still works. Went to install the motor mounts and the 2.1L Diesel motor mounts are 4.0 and not 2.5 mounts as I thought. Gotta exchange those today. Then install motor mounts and install the Injector pump and hopefully START!!
Here is some real world Dyno numbers- STOCK 4.0L- 128rwhp/169rwtq corrected*(142rwhp/187rwtq Dynojet) 4.0 Wrangler, stock air intake and filter 133rwhp@4650164rwtq@2650 Dyno-Mite 3rd gear pull '96 177k 5sp 3.73 31" 134rwhp/160rwtq mustang dyno '89 AW4 ported '94 head cam '99+ int Renix header CAI no cat 135rwhp/160rwtq mustang dyno, '99 150k stock 136rwhp/165rwtq corrected*(151rwhp/183rwtq Dynojet) 4.0 Wrangler, NO air intake tube or filter-unrestricted 138rwhp/167rwtq ?dyno '05 Wrangler auto CAI exhaust TB spacer 138rwhp/180rwtq corrected*(153rwhp/200rwtq Dynojet) '00 TJ 5sp MagnumPowers stock 138.3rwhp/172.8rwtq ?dyno stock '00 XJ auto 4wd 138.6rwhp/176.0rwtq ?dyno stock Banks 4.0L '05-04 Wrangler 140rwhp/179rwtq ?dyno '06 Wrangler 6 speed 140rwhp/183rwtq corrected*(156rwhp/202rwtq Dynojet) '00 TJ 31" 144rwhp/175rwtq ?dyno '97 ZJ 4.0 BOLT-ONS 4.0L- 133rwhp/165rwtq corrected*(149RWHP/183rwtq Dynojet) 2000, HAI, Catback, 0630 147rwhp/171rwtq corrected*(163rwhp/190rwtq Dynojet) K+N Factory, '97 XJ AW4 2WD 60k 2nd gear 148rwhp@4700/187rwtq@3100 Land+Sea Dyno, '01 WJ 4.0 106k, K+N FIPK, HF cat 150rwhp/174rwtq mustang dyno, '99 150k CAI, 62mmTB, cat back, ignition 153rwhp/180rwtq corrected*(170rwhp/200rwtq Dynojet) '88 XJ AX15 4WD Renix MegaSquirt3x 'mild' Comp cam 159rwhp/209rwtq corrected*(177rwhp/232rwtq Dynojet) '00 TJ 31" + 62TB, CAI, EDGE Trail Jammer module (+21hp/+30tq) 164rwhp/179rwtq corrected*(171rwhp/199rwtq Dynojet) K+N Factory, +FIPK (+7.9hp/+9.19tq) SUPERCHARGED TURBOCHARGED STROKER NITROUS- 141rwhp/184rwtq Mustang Dyno 4.6L Stroker log intake auto 37"MTR 156rwhp/266rwtq corrected*(173rwhp/295rwtq Dynojet) 4.7L Stroker '98 XJ 176rwhp/226rwtq ?dyno Turbo 6psi '95 AW4 4wd FMU MSD BTM no intercooler 'CSaddict' 182rwhp/239rwtq corected*(202rwhp/265rwtq Dynojet) '95 Wrangler Turbo 6-7 psi 12:1FMU boostapump meth inj 185rwhp/241rwtq 4.6L Stroker 9.56:1 0.043"quench stock head +5-6*timing mod 63mmTB 24lb injectors Hesco474/480 cam ?dyno correction 204rwhp/265rwtq 190rwhp/263rwtq corrected*(211rwhp/292rwtq Dynojet) Boostwerks Turbo 6psi 4.2 MS 4.0head 191rwhp/265rwtq corrected*(212rwhp/295rwtq Dynojet) Boostworks Turbo 6psi 4.2L bored to 4.3L Megasquirt 99+intake 193rwhp/236rwtq ?dyno, 'Gradon's Stroker' from old post, 4.6L, 30cam, ported head 196rwhp/??rwtq ?dyno, 4.6L, auto, Sprintex SC, ?boost, stock cam, stock head, AEM tune 201rwhp/rw263tq ?dyno 240k 4.0 T3/T4 Turbo 6 psi tapering to 3-4 psi by redline(boost leak) 36 lbs injectors 99+ intake 202rwhp/258rwtq Dastek dyno, 'Cheromaniac's' '92 4.6L 'poor man's Stroker' '01 intake 65mmTB 9.25:1 ported head 5sp header 208rwhp/280rwtq Mustang dyno '01 TJ 5speed 5.0L Stroker 212/216 0.488"/0.498"cam stage II 505 head (supercharged below) 210rwhp/249rwtq ?dyno Banks 4.0L Turbo 6psi '05-06 Wrangler +66HP/+84TQ 35lb injectors, AutoMind tune, CAI 211rwhp/268rwtq DynoDynamics dyno '97 XJ M62 Supercharger Kit installed 6psi (crank 300HP/375TQ) 211rwhp/274rwtq mustang dyno '98 XJ auto 4WD160k Sprintex Supercharger 6 psi(crank 300HP/375TQ) 212rwhp/278rwtq ?dyno TurboJeeper '90 Renix 4.0 Auto 60-1 Turbo 1.15a/r 5psi 36lb-5.9L injectors FMU No Intercooler (stock 142rwhp/228rwtq) 220rwhp/260rwtq ?dyno, 'Mountaineer's' 4.0L Nitrous
Higher comp pistons for 2.5 4cyl??
CobraMarty replied to 81Chero's topic in MJ Tech: Modification and Repairs
Who's 2.5L supercharger kit is that?
