dunnc1991
Everything posted by dunnc1991
https://fredericksburg.craigslist.org/cto/6133361783.html
Silver Star 1991 Pioneer Build
dunnc1991 replied to kryptronic's topic in Member Projects: Your Comanches
Any sliders I've had have all been a single pane of glass, so I'd say the one in your truck is aftermarket. -
Unsure on the width. I'd imagine it would definitely be wider, however weren't those 150's 5x5 bolt pattern? That's one of the pluses of the Explorer 8.8 is to be able to keep your current wheels/ match the front.
Welcome. Being a Renix go through as many of these as possible. http://cruiser54.com/
Finally had a day off when the weather was decent. The muffler is shot, so that's been removed along with the tailpipe. Plan to order a new muffler and turn down to go in its place. Pulled the bench out and put one of my biluckets in temporarily. Also pulled up the driver side carpet to see the floor damage. Not as bad as I would have figured with how bad the door is. Looks like it will need one small patch. And threw on the Ecco's I picked up from Warrior Spit. Need to replace 2 of the tires, but I should have enough laying around. Still dealing with the rough running/idle issue, believe it needs an o2 sensor. With warm weather finally here, I'm hoping I can get moving along on this.
Guy said he bought it to put on his tractor. He was told it came off an older Cherokee. The mounting bracket looks to be correct. https://washingtondc.craigslist.org/mld/pts/6041187427.html
Warrior Spit, I pm'd you
So my plan was to get it running before, as it would be much easier to be able to drive it off the trailer rather then drag it with the tractor. Threw a known good CPS in and a new battery and it fired surprisingly easy. Got it off the trailer and let it run for a while. It runs rough, and smokes a bit, but I'm sure the gas is getting quite old now. Planned to pull the carpet, but the rain set in. Took some more pictures as well, mainly the rust. Rockers will be cut out, and sliders will be welded in place. Driver doors needs to be replaced as well. Interior is mostly there. I like the blue interior, and plan to keep it mostly stock. The bench will get pulled for buckets for now. May go a different route in the future.
So about 8 years ago, I was driving a 2000 XJ, my first car and Jeep. I always loved the Jeep "pickups" and started researching them. Found an 88 Pioneer 4.0/4x4/ba10/swb with probably the most rust I've ever seen on a vehicle. I bought thinking I had the skills to fix it. That never happened, and it ended up stripped for parts. I've had several MJ's and XJ's since I including my current 91. I haven't been able to work on it as much as I would like, and it just sits in the garage. The other day I was looking through the classifieds, and found Wesleypipesyo selling an 88 Pioneer 4.0/AW4/4×4/LWB. We talked back and forth a bit, and I ended up dragging the trailer a couple hours away and we made a deal. Plans are to get it back running and on the road first. I have big plans for it in the future, but getting it back to a solid runner is #1 priority, something I haven't done in the past. I'll add to this a little later, but here's my only picture so far for your viewing pleasure.
1988, Jeep Comanche, Pioneer Image Not Found 4.0 / AW4 / NP231 / D30 / D35 / LWB Build date: 07/88 Current Location: Bloomery, WV Status: Will be returning to the road asap Notes: Column shift, Bench seat, Blue on Blue Current owner: Chris Dunn
TJ flares turned out pretty good. My 88 I just picked has the same rust issues, I've got some TJ flares to go on when I get to that point. I pm'd you about that winch.
Where at in Maryland?
Where at in maryland? I may have one laying around.
I agree that maintenance history is more important then mileage when I look at any vehicle. The more records the better, unfortunately a lot of these trucks aren't kept after or sit for a long time. My 91 I'm building shows approx. 280k miles, and with a little tweaking runs pretty good for the condition I found it in. 4.0/2.5's are pretty stout engines, so as long as the truck seems in halfway decent shape I wouldn't be too concerned on the mileage. FWIW, I daily a neon with over 300k miles and I hardly maintain it, so high mileage really doesn't bother me.
Would make a great rat rod.... someone needs slapped
Bunch of Comanche Questions
dunnc1991 replied to TheDirtyJeep401's topic in MJ Tech: Modification and Repairs
Mnkyboy has a supercharger for his 2.5 http://comancheclub.com/topic/16226-mnkyboys-89-comanche-project/page-24 -
I did on my 91. Seemed to help it some. I just pulled the vacuum line off the brake booster. I'd pour some in until it would almost stall, then let it idle back to normal. Worked pretty well. Smoked my neighborhood out as well.
http://www.google.com/search?q=jeep+axle+identification&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjUqdGUptXOAhXJKCYKHZxGCZwQ_AUICCgC&biw=412&bih=604#imgrc=5dzLFabhqaIgiM%3A
GM ditched the manual after the 07 MY for pickups, Ford was after the 10 MY. I feel like Dodge will hold out for a while, seeing as they have that market cornered now. I had planned to swap an auto into the MJ, but reading all this is making me think I'll keep the AX in for a while. Haven't had a manual vehicle on the road in a while.
What rims and what center caps?
dunnc1991 replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
Soft 8's for sure. A couple different brands make them. I got center caps from Summit when I had my XJ, they had a pretty good selection. -
After years of talk and lies, looks like there may be a new Jeep pickup in the future. I'm interested to see what more comes out about it. http://www.roadandtrack.com/new-cars/future-cars/news/a30034/jeep-wrangler-pickup-spy-shot/
Thanks for the input, I've posted on a few other forums I'm on so hopefully something might pop up. I agree, hauling empty for no reason sucks. Figured someone always needs something moved. I'll get a picture of mine up, once it gets back to the house. (Being used by a friend, someone always needs a trailer). Just a 20' Bri Mar bumper pull. It's a little rough, but I have plans to redo a lot of it this summer. Couldn't beat the price for a 14k rated trailer. Sold my deck over gooseneck since it was more of a hassle then it was useful for what I haul. If I ever get this current MJ built, I'd like to do something similar to your big trailer. Small camper on the front with deck space on the back.... maybe one day.
I know people are always buying parts and trucks all over the place. Figured I'd post up if anyone needs something moved. I'll have an empty 20' open trailer and majority of a truck bed from Winchester VA to North Jersey on 6/25. Let me know if anyone needs anything moved. I'll also be coming back the next day with a partial load.
What Front Bumper Is This?
dunnc1991 replied to ScottJeep's topic in MJ Tech: Modification and Repairs
Absolutely correct. You can order them with the d rings or brush guard. One of my favorite light duty bumpers. Agreed, had planned on buying one for my XJ years ago. Honestly kind of forgot about them until now. -
Looks really similar to Warrior's bumpers http://m.quadratec.com/products/product.php?pid=72108+1000+07
