What stage are you at? Unbolting the motor and pulling it is easy after you:
Dis-connect the driveshafts, remove all wiring to fuel injectors/sensors, remove exhaust, easiest to remove front header panel and radiator, and anything else in your way. I pull the trans and motor as one unit. I usually unbolt and remove the crossmember and support the trans with a floor jack, then let the tail down on a creeper. At this point you should have the motor mounts un bolted then lift up and roll out!
