Everything posted by benjy_26
top two transmission bolts
benjy_26 replied to dustyinthedirt's topic in MJ Tech: Modification and Repairs
That's what I've used...- 22 replies
- transmission
- ax15
(and 1 more)
Tagged with:
Guitars, guns, books...
Thanks!
Oh...and I WILL need center pins. Any good places to get em?
Thanks! Forgot about wheel spacers. I gaffled the Explorer spring plates when I got the axle. Those have the shock mounts placed similarly to the MJ ones. I should be ok using those, right?
upgrading the alt for more lights and winch
benjy_26 replied to redwolf624's topic in MJ Tech: Modification and Repairs
This is what I love about the ComancheClub. People just keep coming up with great solutions to different problems. Does this work on the 4.0 as easily? Not sure. I know the 4.0HO in my ZJ used a Denso unit. If the Renix 4.0's used a Delco CS unit, I don't see why the Roadmaster alternator woulddn't work. -
He has a 2.8. Ah...Nevermind, then! -
Thank you, sir! I got a set of new U bolts from my local Ford dealer. :)
Actually, I'm not 100% on that. :-/ I know the BA10 had a 21 spline output as does the AX4/5. I got the t-case locally in VERY good shape for 100 (with a free BA10/5 thrown in the mix), so, if it doesn't mate automtically, I won't feel too bad about buying parts for it to make it mate to my AX5.
Thank you, sir! I have to agree, there's just something about a white MJ!
Hello all. It's been a bit over a year since I took the plunge into MJ-world, and I THINK I'm about ready to perform a 4x4 conversion on my truck. I would really appreciate it if y'all would lend me a hand by letting me know if I'm forgetting something before I start tearing my truck apart. So far, I have collected: A front diff off of a 98 TJ A rear diff off of a 98 Explorer Limited AX5 (to replace AX4) off of a 95 YJ NP231 off of a 88 YJ that was equipped with a 4.2/BA10 Spring perches from Ballistic Fab (keeping it spring under) Tubular LCA's and new UCA's Poly leaf spring bushings Beefy shackles Front brake lines off of a mid 90's C1500 I know I need driveshafts, a new flange for the 8.8, a new trans mount (mine's hashed), as well as having to cobble together some sort of shifter for the T-case. What else do you guys think I'll need? Oh, and I pulled some 4+1 MT springs from a 2wd junkyard MJ. If I use the MT springs, will adding my stock main leaf into the pack give me more lift, or will it just make the truck ride worse? I have a 3" lift in the front right now. I'm looking for around 2-3" of lift in the back and I figured now would be a good time to knock it out.
AC Delco P/N 335-1048. It's off of a 96 Buick Roadmaster. 140 amps and all you have to do to throw it in a 2.5 MJ is a pullet swap and to clock the back (or extend your cables). -
NP242 to 231 swap isn't difficult, btw, and neither is an AW4 swap on the earlier models.
I have a 94 with a mild stroker, a 42RE, and an 8.8 in the back. When I wss DD'ing it, I wss getting 16mpg average. Mine is a 2wd on 32's that gets driven fast off road. I had the trannt rebuilt at around 100,000 miles (PO sucked). I installed a big cooler and follow the service schedule and everything has been fine with the tranny.
Awesome shots!
Some progress: I purchased a Boostwerks Ultimate steering brace kit, as well as a 21 spline input np231 off of an 88 4.2 YJ (anyone need a low mile BA10/5?) and a 97 AX5 with 60,000 miles on it. Those should fit together, right? Anyway, I also need to get some front u joints, have my rear shaft shortened, purchase a front DS, anda drive flange for my 8.8 and I can make my SporTruck a 4x4. Oh, I also purchased (on a whim) a ZJ steering box to begin my p/s conversion. Meanwhile...
Looks slick! Too bad about the tire size. It looked awesome on the old ones.
From Oreilley's: Wheel Cylinders: P/N WC17507 P/N WC17508 Brake Hardware kit: H7064 (if you have a D35) Brake Shoes: 481 (again, assuming you have the D35)
JK's are PIGS. I would NOT jump one. Earlier Jeeps...well, my ZJ has been airborne a few times. No ill effects. All I did was gusset the C's on the front beam and its held up fairly well.
On the subject of wheels/tires
benjy_26 replied to Jeep Driver's topic in MJ Tech: Modification and Repairs
Ranger, Mustang, Crown Vic, and at least up to 2nd gen Explorer wheels fit too. -
New Hummer: i threw up a little in the back of my mouth
benjy_26 replied to Incommando's topic in The Pub
That's an OLD concept vehicle. I remember reading about it years ago. If they can keep it small, it may be fun. -
Nice score!
Brakes fading/over heating
benjy_26 replied to 88eliminator's topic in MJ Tech: Modification and Repairs
Something's definitely dragging. Check the calipers. I have an 87 that I'm daily driving right now and I go up and down a mountain pass pretty much on a daily basis and my bone stock brakes don't cook themselves. -
Thanks.:) I flipped out when I saw it was a 2.5!
Help with Transfercase info!
benjy_26 replied to benjy_26's topic in MJ Tech: Modification and Repairs
Awsome. Thanks!
