Pete M
Administrators
    114
Everything posted by Pete M
  1. Pete M
    1JTHS6414JT075740
    rip little guy.
  2. when I blew up my gears I also bent the axle. I assume they checked for that?
  3. no need. I've still got the engine block in the barn.
  4. yup, definitely some differences, but it was a dude's project after all. but how many white on white on white on white MJs can there really be in Michigan?
  5. too bad it's at a junkyard. Dom found this v8 swapped truck at a michigan junkyard and it bears a striking resemblance to a truck I bought like 20 years ago that had a hideously done white paint job. I didn't need a 3rd rig at the time, but the price was good so I pulled the 4.0 (to swap into my 88) and gave the rest of the truck to someone in need of a body for a project. waiting on some further research to see if it might really be the same truck. some things are the same, some things are different, but dang do those stupid white door handles stand out like a sore thumb. the truck at the yard: my old truck (don't have many pics of it unfortunately)
  6. Pete M
    1JTHS641XJT068548
    what is it that you mean by "cross reference"?
  7. indeed. though they are predicting a whole mess of nights in the 20s for the next couple weeks. that's dang cold for down here.
  8. big ol' pile of oak. should easily last the winter and keep my dad toasty warm.
  9. I should do that. never know what's going on. tank is of course full to the brim. this is going to wait for a bit until the weather improves.
  10. welp, I guess that last blast of gas that almost hit my face when removing the filter was indeed the last blast of gas. absolutely nothing is coming out of the fuel line upstream of the filter. pump makes the right noises and all, but zilch is zilch. guess I'll be pulling the pump next to examine it directly. maybe it's just that silly rubber hose has rotted inside the tank.
  11. ran out and triple checked and "out" is facing the engine. so much for an easy fix. I guess tomorrow I'll see if I can start pulling stuff apart to check for flow rate.
  12. resistor is there, but I've bypassed it with no change. haven't pulled the fuel line off the rail yet to check for flow. I guess that's next. hmmm, I need to get some appropriate rubber line to redirect the flow so I don't make too much of a mess.
  13. pump sounds strong. fuel spews out the filter pretty good. engine cranks strong. was running pretty decent a few weeks ago when I finally got to take it around the block to prove I've fixed the steering. then a long pause of sitting. then wouldn't do anything but idle (any amount of revving made it stall), but it idled perfect. few days later it refused to even idle. swapped out the fuel filter and now it might sputter a couple times while cranking. fuel does NOT come out the fuel rail schraeder valve. just stinky air. has the fuel regulator kicked the bucket?
  14. time to pull the rear window and reglue. they are notorious for separation. be prepared to address any rust on the mating surface.
  15. you can pry the rubber bit off the valve cover if necessary.
  16. is this skinny hose clear of obstructions and sucking the dirty air out of the valve cover?
  17. lol. you win the internet for today
  18. more power = better
  19. so this is the ad I found a while back, and these are all the trucks in the CC registry that share the code "AJS: SUN/SOUND/SHADE PACKAGE" in their printout. I'm thinking there's a connection? (with the code being a reused code) The one truck even has the Fourwheeler sticker in the window.
  20. get a code reader that's bluetooth so you can use an app on your phone
  21. see, that's exactly why I carry a hydraulic floor jack. jacking up the axle seems way safer than jacking up the body and drooping out the suspension just to get the tire off. but a farm jack does have it's uses and so it was still in the truck.
  22. overly complicated death traps...
