I'm sure most of you have already seen this little truck, but I want to make sure it's officially posted up. The best thing to do is lube all the associated mechanisms on a regular basis (like with oil changes).
It happens all too often. An MJ/XJ owner reaches down to pop the hood and the latch release handle comes off in their hand. If it happens to you, don't fret, it's not as bad as it might seem. Crawl under the front of your Jeep and see if you can reach up past the radiator (this can be next-to-impossible for owners with the aux fan or front steel guard). Now feel around and tug on the skinny little bar that connects the two corner latches. It's waaaaay up at the top. Sometimes this works, but usually it only pops the passenger side. See, the bar pulls on the pass side, but PUSHES on the drivers side. If it doesn't pop open, remove the headlight and headlight bucket. You'll see this bolt:
It is one of two bolts that hold the bracket that the hood latch, um, latches to. There's two of them though. The second can be seen here above the first:
I dismantled most of my front end before I discovered these two little gems, hopefully you won't have to. It's a tight fit, but it's been proven that a ratchet can get at both. Then the whole assembly pops up with the hood. Now open the hood, free the bottom half, and reattach it to the Jeep. Replacing the cable is pretty straight forward.
Jeep on!
--Pete
