Pete M
Administrators
    114
Everything posted by Pete M
  1. Yes. Extra bonus points if you get them from a Wrangler. There are differences from the XJ/MJ versions that will have to be worked around (trans mount, t-case shifter linkage, trans shifter tower/stick) but the YJ/TJ trans clocks (rotates) the t-case up a bit which equates to a bit more ground clearance. :brows: And if you're going with leafs, you'll want to strengthen up the front frame.
  2. No quad cabs. Not enough room. Besides, I'm not in the market for one just yet. I've got no money, only a Dak R/T and I'll need to convert it into cash first. 8)
  3. Sand blast, primer and paint. And then very careful assembly. I got some leafs from Florida and called it close enough. :D It'll take years (maybe decades) before they get like my old ones.
  4. Yeah, but who's "they"? That truck makes me want to change my rules a bit. :brows: Too bad it probably would cost too much. Excursions aren't any wider than a regular Ford superduty truck. Duellys are like 2 feet wider than regular pickups. That black Dodge above is a dually. Notice the extra wide stance in the rear. On a weird side note, the pull-your-part near me had a wrecked Centurion conversion in it not too long ago. If I had unlimited funds I might find one of those and pimp it out with a new drivetrain. :D
  5. :eek: Did the hood fly off?
  6. I'd also go with a diesel Excursion if I could afford it.
  7. Problem is those same price increases have hurt the value of my Dakota R/T. :( Not too long ago it was worth almost 9Gs. Dodge did have a 4-door in the late 90s, but they were half-doors. The 7.3L Fords were first on my list until I discovered the 'Burbs and if I was to go with a pickup, I'd go Ford over Chevy. But I don't necessarily need the biggest, baddest engine in existence as much as I need a reliable hauler. Both engines are plenty capable of dragging my MJ around, the tie-breaker will have to be something else. Possibly the conclusions from the truck bed vs. interior bed debate.
  8. Where's your patented camera mount? :brows:
  9. 1. essentially any diesel that meets the "new enough" category would qualify. Early 90s had some non-turboed diesels. 2. absolutely, as long as it has four full doors. None of that half-door crap. 4. yup that's what I thought too. But I saw a couple ads for diesel Burbs that said they were 1500s so I included it for the heck of it. 6. The cummins kinda gets screwed over because of Dodge not having the crew cabs early on. Anyone know what year was the first for the crew cab dodges? Actually I know very little about the 6.5 diesels other than they are supposed to be good for 20+ mpg in the 'Burbs. Still have to do that research.
  10. Pete M
    Fay is on the way
  11. But am still open to suggestions. This is all theoretical at this stage because I'll need to sell the Dakota to fund it. The requirements: -1. Diesel. Turbo diesel at that. And no 6.0L Fords -2. 4 full doors (I want to bring 4 or 5 people long distances in comfort) -3. 4x4 (don't plan on needing it, but I once got a 2wd Durango stuck on the side of the road when flat-towing my MJ. We had to disconnect the MJ to allow the Durango to get back on to pavement. I don't want that to happen again.) -4. No half-tons (I want the upgrade in brakes and axles) -5. No duallys (I'd like to be able to park the dang thing) -6. Needs to be around 5-7k (the general range of worth for my Dakota) and yet still be relatively new (want reliability), under 200k miles, and without needing major work (although I'd take a much newer rig if it had body damage but everything important still worked). The price range would obviously be modified if I have more funds available. Any other details I should be looking at? I'm leaning towards the 94+ 2500 Suburbans with the 6.5L diesel. :brows:
  12. Dang. Beat me to it. :D
  13. POR15 likely won't last on the springs. It's a ceramic that doesn't flex with the steel.
  14. Pete M
    Fay is on the way
    Maybe some of that rain will hit northern Georgia. They could use the aqua.
  15. Do you have covers for these lights? That should satisfy the coppers.
  16. I wonder how well cop lights would adapt. Then they could be aimed. :D
  17. Is it any of these?: http://4x4icon.com/offroad/willys_lettering/index.htm
  18. I know the leaf spring bolts and lower control arm bolts are 14mm with a 2.00 pitch and need to be about 110 mm long.
  19. What's "electronic" about it? Speedo? 4wd light? Those can be worked around. Are you worried about shifting the front CAD axle? That can be worked around too.
  20. Then you should be fine. :thumbsup:
  21. If it was free I still couldn't afford the gas to drive it home. :(
  22. That's a great idea! I'm putting you in charge of it. :D
  23. I just realized that I'm gathering up a collection of parts that would never be used on any of my current MJs, yet I can't seem to part with. I need a new MJ. A nice MJ. I've got a wheeler, a beater, and a hauler. All are rusty piles of crap. I want a nice one now. :brows: Too bad I'm poor as all get out. But the pile continues to grow. :D I love junkyards...
  24. Hahahahahahahahahahahahaha... :rotfl2: ..cough.. I mean, no. We're not that lucky. :(
