Yay! radius arms! :D If you want any flex in the front axle, I suggest avoiding the poly C-bushings. I've been quite happy with my stock Ford rubber ones. :thumbsup:
Oh I've never pay to regear axles. I buy axles with the new gear ratio already in them. I "regeared" my 88 to 4.10s (with Ford axles) for negative money (since I parted out the 78 Bronco for way more than I paid). I bought a pair of 4.88 geared ford axles for it (not yet installed) for about $600. I regeared the 90 to 3.55 for about $300 (99Dana 30 front and Dana 44 rear). It's all about patience and hunting ion the right spots for a good deal. I can spend hundreds on an exhaust/intake and my truck will still suck with 31s on 3.07s.
It's sometimes a hard pill to swallow (depending on the circumstances), but gearing is still the proper cure for big tires. :thumbsup:
What are your lift goals in all this?
No easy way to do it. Unless you use a TJ rubicon front 44, but those are only half-44 anyway and low-pinion too.
What are your end goals for this truck? How much lift? How big of tire? What kind of wheeling would you be doing?
The "vacuum thing" is called the CAD (central axle disconnect) and it's easy to pop off the cover and keep the little fork inside shifted all the time. Search for "CAD" and you'll find some of the options. This would make your truck like any Jeep after '95 and your 4wd would still function completely like normal (and would be more reliable). :thumbsup:
I appreciate all the support guys, :thumbsup: but I promised myself years ago when setting up the forums that I wouldn't incur any costs unless I could cover everything myself (and if donations came in, so be it). I didn't want to have to rely on outside help, just in case it didn't happen. Admittedly we are a lot bigger now though so maybe I should rethink some of that. Plus I just always assumed that employment (something that makes use of my engineering degree, not talking about flipping burgers) was just around the corner. :hmm: stupid Michigan.
Plus I have to take into consideration that I'd have a whole new system to learn. :ack: :hateputers:
Nice. :D
I always liked the more difficult drop contests that involved an egg, 100 toothpicks, a bottle of glue, and a 2 story drop. Crumple zones anyone?
Yup, the tires are the problem and regearing is the solution. :thumbsup: Do it right, and it'll put a smile on your face every time you punch the gas. :D
EFI + 6 cyl engine + solid front axle = greatest little truck ever. :thumbsup:
Not to mention the rugged good looks and plethora easy upgrades.
And once you fall in love, your brain will make excuses for the bad stuff. (like the "cozy" cabin space) :clapping:
I think what Willy's saying is, now that you've found the proper size, be sure to buy one of a better quality. :D I wouldn't use a Fram filter on my lawnmower, let alone a Jeep. :no:
