Pete M
Administrators
    114
Everything posted by Pete M
  1. car-part.com and pullapart.com are my favorite search sites what to search for depends entirely on what parts you need. just about any year MJ/XJ is usable for something. :thumbsup:
  2. I do believe that hell creek makes mt packs.
  3. yes, the 4.56 is a good thing. :D if the tag is there, it'll be attached to the cover with one of the cover's bolts.
  4. hmm. not enough there to tell the gear ratio. the reason I ask is that the 2.5/auto usually came with the rare 4.56 gear ratio. :thumbsup:
  5. I split your questions off into a new thread. :thumbsup:
  6. your trans should be the AW-4 and it is considered a very good trans. :thumbsup: Could you do me a favor and check the gear ratio stamped on the tag on the diff cover on the axle?
  7. 5 hrs is a small price to pay to get your baby back. :clapping:
  8. I've been spending too much time out in the cold garage. :( also, a lot of guys refer to the tube as a 30 so I just wanted to check. :thumbsup:
  9. what size tire? The Dana 30 can be built to handle a decent load and you can mate it to a 44 or Explorer 8.8 in the rear. If you're prepared to take on a big project, my standard suggestion is to look into late 70s Ford 3/4 ton axles. The front axle will be a heavy duty 44 with a drivers side diff, and it will readily accept the MJ suspension brackets (get aftermarket though, it'll be much stronger than stock). you don't necessarily need the rear from the same truck though, as just about any 8 lug dana 60 from any truck will match up in width.
  10. 1988 jeep comanche 4x4 - $750 (Jackson Ga.) http://atlanta.craigslist.org/atl/cto/1499570104.html
  11. I've never done it, only heard of it. do you have inspections or sniffers in your area? still running the stock exhaust?
  12. help with swearing at the truck? don't worry I've got that covered. :yes:
  13. admittedly my 86 has the normal looking leafpack. later years had the funky thick lower leafs thing going on.
  14. only way I know is to pull the cat and shine a flashlight through it. :dunno:
  15. Yup. that's all. floors, rocker and bedsides. oh and the doors. and the front fenders. and the cab corners, and the tailgate, and the bumpers and every single stupid nut, bolt, connector, and wire. So far the roof is just fine. :thumbsup:
  16. I started a new one in Tech and stickied it. Feel free to fill in all that data from the older threads. :thumbsup:
  17. I'd like to compile a table of all the different combinations of MJ driveline and the length of their rear driveshaft. I need bed length, engine, trans, 2wd/4wd, rear axle and then the length of the rear shaft from center of U-joint to center of U-joint. what we have so far:
  18. I'm not sure she could rust any faster if I dropped her in the ocean.
  19. My 86 metric ton never struck me as rough riding, nor was it much if any higher than a regular 4x4 MJ. But individual results will vary as widely as the sag in 20 year old leafs. A shortbed does have slightly less steel back there to hold up. :dunno:
  20. how about a post asking for driveshaft lengths for all the possible MJ configurations?
  21. just follow the instructions in that link and your front end will act like any other Jeep front end since they dumped the system for good. :thumbsup: No need to swap axles just because of the CAD. the only potential downside is if you've got a bad joint in the front driveshaft. That can cause vibrations. But if you've got a bad joint, you really should fix it anyway so finding out can be a good thing. :D If it really truly made a positive mpg difference, wouldn't ya think Jeep would still be doing it? With all the modern CAFE requirements, I would think they'd be looking for any and all real gains.
  22. I would never EVER swap new gears into an existing Dana 35. That axle just isn't worth the money. Swapping in a new 35 with 3.55 gears would be much cheaper. Having said that, I always like to upgrade when something breaks (about a mile from wirk it started spitting out ring gear teeth), and I swapped in an MJ 44 that had 3.55 gears. :thumbsup:
  23. Welcome to the club! :waving: tech questions should really go in the tech forum so more guys will see them. :thumbsup:
  24. moved it to Tech for ya. :thumbsup:
