mjeff87
    8
Everything posted by mjeff87
  1. Didja check the rotor or the dizzy cap first? Start simple, and work your way up.
  2. Nate, your dog has good taste..... For my low buck diff protection (for now), I'm going to snag a couple stock covers from the 'yard tomorrow ($4 each) and cut out the fill plug on one of them. Then I'll get my neighbor to weld the two together as he sees fit, and install the double cover with some longer bolts. It'll work until I get cabbage for aftermarket stuff. Jeff
  3. CW, In reference to the D44 waaaay back on page 6, care to share your source for those? I need a new set of drums for the D44 going under mine (soon, hopefully) Thanks, Jeff
  4. linky no workie....... :cry: Jeff edit: woo-hoo! I broke the 1000 post barrier, and didn't even notice it...
  5. Image Not Found
  6. No, I didn't get it in last weekend....Sunday ran long and I ran out of time. If the weather cooperates this weekend, I'm going to try to get it in. I'm also hitting the junkyards, and I'll grab any of thoses vac switchs I can if there's any there for you guys. Jeff
  7. Same size, they just pop right in. Jeff
  8. #1 is a 242 skid. Wanna sell it? :D I'm picking up a 242 this weekend to throw under the MJ (and I forgot about needing a new skid.....unless the 231 will clear?) Jeff
  9. Remove the cover plate on the inside of the gate, behind the handle area (3 torx screws). There's a scissors-type mechanism, and the two arms attach to to rods that run thru the 'gate to the latches. Squeeze the arms together and it should pop open. Jeff
  10. I have to go to Rhoadesville either sometime this weekend, or on my way back from PA next weekend, to p/u a D30 and a 242 from a guy. If you're gonna be around wrenching on it, I might could stop by and give you a hand. Jeff
  11. You didn't happen to buy that from a guy around Charlottesville, did you? If so, I know who sold it to ya....I was gonna buy it but the boss said no way. I'm right down the road from you :cheers: If you want to build that thing on the cheap (money, not quality) c'mon down and I'll take you to the junkyards. Jeff
  12. Welcome to the club. Beer's in the fridge..... :D Where y'all from? Jeff
  13. If/when I ever decide to flatbed mine (I do still use it as a pickup truck currently :driving: ), this is what I'll be doing: http://www.comancheclub.com/forums/viewtopic.php?t=3890 I've seen a handful of flatbedded MJ's, but that's the best one I've come across IMHO. Jeff
  14. Could you do me a huge favor??? :D Since you put ZJ coils in the front, could I get a center-of-hub to bottom-of-flare measurement off yours? We've got the same driveline, and I'm trying to match my front to the lift I got in the back with new leafpacks (now at 20.5"). I've got a couple different options to lift the front, including a set of ZJ springs, and was going to experiment this weekend. From your pic, it looks like you got about 3" with them, which is eggzachary what I need :D Thanks! Jeff
  15. I just put a ZJ tie rod in the MJ Saturday when I swapped axles. Here's a couple pics that show the difference. Also, the XJ/MJ TR is hollow, and the ZJ one is solid stock I've got an extra one if you're interested, too. Jeff Image Not Found Image Not Found Image Not Found
  16. No pics, but I've had one good stuck and one "accident" with the MJ. The stuck was when it was still 2WD and I buried it up to the framerails on the farm in a very wet field....had to get the 60's era IH tractor out of the barn and chain it out :oops: About 2 years ago I was driving it to work one day, merging onto the interstate in one of those nifty "weave" lanes (onramp and offramp are the same road), and I bumped nasties with a ZJ....she was exiting as I was merging and we hit passenger side to driverside almost dead center. State police came because it was an interstate, found it non-reporatble due to minimal damage and no injuries, but I was faulted because I was in the merge lane :headpop: It popped the mirror off and put a dent in the center of the driverside door, and scuffed the rear flare on the MJ. I popped the mirror back on (didn't even break the glass), pulled the dent out of the door skin with a sink plunger, and didn't even bother with the flare. BUT, I caused $1600 worth of damage to the ZJ :chillin: Jeff
  17. I got it (if we're talking about the same thing) off a website, and it's an EXCELLENT resource. Opened it up on the webpage as a .pdf and saved a local copy to my PC. The site had parts manuals for all years up to 2001 or so. Clicky here: http://www.xjjeeps.com/tech_reference.a ... ion=2&ID=0 Jeff (the 88-90 manual listed is a typo...it actually covers 87-90)
  18. A former NAXJA guy did the rear floor of his XJ with plexi, right over the diff, so he could self-spot over rocks. I'll see if his pics are still up over there and post the thread if so. Jeff edit: pics are gone, but here's the thread- http://www.naxja.org/forum/showthread.p ... ight=plexi
  19. Jerry did a neat trick to get those cables back into the strut. Use a pair of needlenose vise grips to push the spring back on the cable and then clamp down to hold it. Then just slip the exposed cable thru the slot in the strut and release the grips.....works like buttah! And to get the "barrel" end out of the backing plate (or splitter), I use a small hose clamp and some banana juice. Slip the clamp over the tangs that pop out to anchor the cable end, squirt it down, and tighten the clamp just enough to compress all 3 of the tangs (usually you can't get to one of them anyway) but not so tight that the clamp tightens fully up. Then grab the cable and give it a good tug and it should slip right out. Jeff
  20. Most report in the neighborhood of 5-5.5". It's the combined height of the OD of the axletube plus the height of the perch, if you reuse your existing springs. If you replace damaged/sagged springs with new ones, you also have to add in that height difference as well. I just replaced my sagged out 2WD leafpacks with a good set of 4WD packs (still SUA) and all new eye bushings, and got a good 3". If I would SOA, add 5" to that and I'd probably be somewhere around 7.5-8". Jeff
  21. Thanks CW....I've been baby-stepping the build on it for the last umpteen years, doing my research both here and on NAXJA before doing anything (and meeting a helluva lot of nice folks along the way :cheers:). I'm building in stages, as time and $$ allow...it'll be where I want it someday, I suppose ;) I got the graphite paint idea from a bud who redid his XJ packs with it, but he also installed teflon padding inbetween each leaf as well...I'm to poor to do all that at the moment. Dang, I didn't think of doing that, sounds workable to me. Only thing is you'd have to be careful to not snap the hardlines into the wheel cylinders, or else unbolt them and rebleed (which we did anyways....). The biggest PITA with disassembling the drums was the parking brake cable, like you mentioned, and the lower spring. I'm going to discs eventually on the '44 so I won't have to deal with all that crap.
  22. flooring is overrated....my driverside comes to you now courtesy of Lowe's :D Jeff
  23. I've got (what I just found out to be) a piece of the factory towbar bracket from an XJ mounted on mine....got it out of the 'yard for $3 or so. It attaches at the towhook bolts, and basically acts as a frame stiffener for the front of the framehorns. The receivers at either end are where the towbar would have attached. Image Not Found
  24. I just put a ZJ tie rod on my MJ this weekend. FWIW, the drag link is the same as the XJ/MJ one, it's just the TR that's larger. Here's a couple pics: Jeff Image Not Found Image Not Found Image Not Found Image Not Found
  25. If you're sure you got all the bellhousing bolts off, thread one or two of them back in a bit to act as a safety and push up/down on the tailshaft while pulling it backward...the only thing that could be hanging up is the input shaft splines inside the clutch disc. Wait a minute, yours is a 4.0L right? Did you pull the starter? Jeff
