Landoloops
Location
Lynden, Washington
Interests
Jeeps
Landoloops's Achievements
Can Spell Comanche (2/11)
Hey Guys Check out this truck and take a look at the link for a bunch more pictures. All credit goes to some guy on jkboard.com http://forum.jkboard.com/viewtopic.php?t=2966 edit: Sorry, I guess I should have put this in the pub or something. I wasn't thinking. I won't feel bad if somebody moves it or whatever.
CAD fix (Cheap Posi-Loc System)
Landoloops replied to Landoloops's topic in MJ Tech: Modification and Repairs
Carnuck, That's great that you have a couple of switches, would you consider selling one? How much? I really would love to get one. What part of seattle do you live in? I am actually up north of bellingham but am down to visit my sister in Bellevue quite often. Let me know PM me if you prefer Landon -
Removing Paint from TJ wheels
What about paint removers or something like that. I don't have a sandblaster and want to do it as cheap as possible. Anybody? -
Transmission option for a 86 XJ
Landoloops replied to rejeep's topic in MJ Tech: Modification and Repairs
I'm not exactly sure but I have heard that MJ had a different firewall. So all MJ's will fit a 4.0 with a few hammer taps. I only needed like an inch of clearence in one spot when I did the swap. The radiator wasn't that bad either like Jeepco said. However I have also read that 84 to 86 XJ's have a different firewall then the 86 MJ and the 87+ XJ's and MJ's so they will not fit a 4.0 but I have never actually looked myself. Hope this helps -
Hey guys... Does anybody know if there is an "easy" way to remove the paint from a wheel. I have a full set of grizzly wheels from a TJ that I would like to use but I hate the dark grey paint. I would love it if I could just go to a polished aluminum. Any Ideas? They look like these: http://us.st11.yimg.com/us.st.yimg.com/I/collinsbros_1940_42809762 Why don't my pictures work? Regards Landon
Thanks Jeff, You don't have an extra one do you? (wishful thinking) Anyone know where I can find one? Landon -
Has anybody ever found a vacuum control valve/switch that can be used in replacement of the valve inside the transfer case? Here is the background of this question. My '86 now has a transplanted engine, transmission, and transfer case from a '95 cherokee. The '86 has the vacuum disconnect front axle and the '95 did away with this "feature" so there is no vacuum control on the new transfer case. Right now I have slid the fork over to the other side of the C-clip so I have 4wd(thanks girsmj86). Eventually I want to either put in a locker or maybe just weld the front differential; but if I do this I would want to have that central axle disconnect back. If my understanding of this whole system is correct, I just need to find a control valve of some kind that will change the direction off vacuum just like the valve inside the transfer case. What do you guys think? Have any of you done this? Any ideas? I know I can go out and spend $200 to get the posiloc cable activated thing but I was just trying to do it a little cheaper.
Project Red (Big Pictures Dial Up Beware)
Landoloops replied to Duner's topic in Member Projects: Your Comanches
That is a really good looking FC150, I've got a 170 but it's not looking as good as that guys 150. They are fun little vehicles though. -
In regards to your CAD fix, does that cause the front drive shaft to spin regardless of whether or not you are in 4wd?
Well when i'm driving it the speedo is fast, when i'm going about 50 it says i'm going 55 or faster.... So if I understand it right it would mean that the XJ the engine and transmission and speedo came out of was geared higher than the gears in my xj axles.... So I am assuming the XJ had 3.55 gears. Does my logic make sense?
I don't have the AMC20 unfortunately. Well i still have the whole jeep with axles. You think going to 3.55 would be better than 3.73? I thought everyone is always trying to get lower gearing like 4.10 or 4.56. Forgive me for my lack of knowledge I'm new to the gearing thing.
I guess I failed to mention my swap was from a totaled 95 cherokee with a 4.0 aw4 and NV231, and I agree the 2.8 was and is junk and the 4.0 with the aw4 is a huge improvement.
Thank JeepcoMJ, I just finished installing Engine, Transmission, Transfercase, Dash, Steering Column, fuel pump/gauge sending unit, and all the electrical over. It was actually a pretty easy swap, and I have never pulled an engine before. The only things I am still working on is the hood latch (bungy cords in the mean time) and the CAD system. (I want my 4wd back) Any ideas on the CAD system? I would like to keep the feature but I need to find a vacuum switch or something to make it work. I could tell my speedo was off but was trying to figure out how much it was off. Thanks again
What gearing would a 86 2.8l automatics have? 3.55? 4.10 Anybody know?
The legendary 2.8 to 4.0 swap (Help Needed)
Well, I am about 90% done with my swap, I have a few odds and ends to take care of and I'll be done. I still need to -Rewire the plugs that go to the rear of the truck (Fuel Pump/Sender, Brake/Tail/Blinkers/etc) -Move the tranny support back -Shorten the Drive shaft -Connect the brakes (I need new lines to go to the distributor block) -Install a 97+ Front end (the cherokee i bought had front end damage) It seems as if its been going really well but I'll have to wait at least until i get the fuel pump connected so I can see if I did everything right. I pulled the fuel pump/sending unit out of the xj tank and it fit right into the mj tank so hopefully that will work out, hopefully i'll find out tonight. Scott86MJ what did you do for your tranny support bracket, I have some ideas, I was just wondering what you did? Landon
