bigd44889
Everything posted by bigd44889
  1. :agree: with both
  2. u drink a lot of water don't u lol :smart: :D
  3. u are only 45 min from me u will have to come up and do some wheelin :cheers:
  4. iv'e always heard 2 inch pvc pipe
  5. hog that looks perfict to me :cheers:
  6. yes that is both and u would have new gears not used ones and if u want to up grade to an 8.8 he has them laying around to http://onandoffroad4x4.com i'm not affiliated with him but he does good work for a good price
  7. were u located the local 4x4 shop will do the gears for $800 out the door labor and parts as for the 2.5 off road is a 4 low area i can run 4 high if i stay out of deep mud but mine is board 40 over and camed up 2.5 4 speed 31x10.5x15 stock gears been told should be 3:55
  8. u don't want those in there looks like crap u should sell them to me :D if u don't beleve me then it looks good :cheers:
  9. whinch bumper would be nice it looks good the way it is just not strong if u just put it on for looks its fine i just wouldn't try to push any brush with it :cheers:
  10. ya that needs to be hooked up i will reduse the amout of oil but u will still get it and will prob. run better with out that vacum leak
  11. not strong enough to bump that on anything if u run into anything whith any force at all u will have problums need to make new mounts with as many bolt on points along frame rail as u can stock is just bolted to core suport
  12. hope u are not going to mount that to stock mounts
  13. pic of the rest of it would help but that part looks good to me
  14. welcome and run while u can befor u get adicted :eek: :cheers: ready for your build :popcorn:
  15. :agree: ps is down cheeper than up :hmm:
  16. nope thats all that goes there it just lets clean air into valve cover the other line has vacum to it u have nothing wrong when u turn motor off hot oil vapor colects in line and drip into air box
  17. mine does that to you have the valve cover breather hose that goes to the breather box it comes from oil vapors in valve cover nothing to worrie about my motor is 2.5 and have 8000 miles on it and it does the same thing
  18. u still need o2 it controls fuel air mixture you don't need the cat but it helps with back presser on motor for low end torqe
  19. :needpics: sorry had to
  20. not sure but soa and 4.5 up front gives it a nice stance but not leval from what i have been told is to do the rear then see how much u need in the front thay are all diff depending on what shape rear springs are in if u do a soa i have been told u can get anywere from 4 to 6 inchs of lift i git 5.5 when i did mine
  21. any 4X4 i have hauled on a doly or by wrecker we allways put trans case in nutral we have never took drive shaft out longest haul was about 800 miles
  22. just get new shock mounts weld them to the axle tube but the stock shocks on drive it home take shocks off twist it up mesure for new shocks
  23. hay pete how does that ride on the street mounted like that been thinking of setting mine up simaler to what u have
