bigd44889
Everything posted by bigd44889
  1. :bowdown: 440 :yes:
  2. hay pete i don't travle lol bring it on over we will throw it in there its -3 here right now lol
  3. i paid like 38 or 40 bucks for a new one at 4X4 shop up the road
  4. me signed to
  5. why i like to freeze my a@@ off to work on other peoples stuff :cheers:
  6. ya i agree if u had the motor to turn those gears and boght the pair it would be a good deal but those gears are to highfor your motor
  7. did u get it started yet if not does it turn over
  8. bring it up here i will gladly help you lol :smart: :cheers:
  9. if not let me know i have one on my spare motor i can part with don't laugh at me i was tyird lol and typeing in the dark and i can't type or spell :smart:
  10. ya that will work tires will look a little small but not bad
  11. sorry to say but kinda sounds like head or head gasket if eather of the go it can fill a cylinder with antifreeze starter not stronge enough to push it back out that is if it won't turn over if it does turn over the spray from over heating may have gotin something wet in the eletical sys
  12. i think it is called the idol contol something or other it controls your idol
  13. well the easyist way is take it to some one and pick it back up but if u want to be like most of us u got to do it your self so when i did mine i unboted the contol arms ,steering link and drag link oh jack truck way up and put jack stands under rails use floor jack for the axle lower axle till u can pull springs put new ones in and jack back up reconect everything if u have a spring compesor u can use it and not have to diconect everything for the axle to drop so far oh take out retaining bolt at the bottum of spring rear is easy jack up body and suport it use floor jack under diff put a little pressure on axle take off u bolts lower axle use clamp to hold spring together take out centering pin losen clamps add your leaf clamp back together put in new centering pin move clamps jack axle back up to springs but a little presser on springs put on new u bolts iff i missed anything i'm sure some one will tell us have fun now :cheers:
  14. mine was a deal he had all the parts i will explain his son had a mj bored motor out 40 over and put it together started it up and head was puking water pulled it apart cleaned all the parts and put them on shelf oh his dad owens a machen shop my motor blew i bought block he did machen work and all the new parts for $400 my head was cracked so i boght a remand one and had it machend and decked i have 126 psi compreson just pulled a ford f150 out of dich on way to work today didn't even grunt lol
  15. the secound pic he posted the top of the altinator is bolted to it with air the bracket is flat with bolt holes
  16. i would say rebild i would sell u my spare a little cheeper but it would cost a bit to come get so ya rebild idea for u do like i did spend a little more and have it bored out mine os 40 over makes a whole new motor out of it major diff i have no problom spining 31's on blacktop in 2wd i just pulled a full size chev truck out of a ditch whith no efert he was buried to the body in mud and snow
  17. i depends on what u are paying for the motor i think it was $400 to rebild the short block $100 to do the head
  18. on the 2.5 from what i remember the alt. brackets are the same except the top one is flat with bolt holes in it for the ac to bolt to
  19. wobble could be many things check all bushings control arms see if you axle is offset (track bar adjustment) tie rod end are tight ball joint wheel bearings alinghnment mine was a bent rim on the rear right good luck with it :cheers:
  20. :cheers: nice :rotf:
  21. pulled full size chevy out of a ditch in a snow storm 2.5 31 m/t never sliped a tire drug it right out
  22. u can go eletric fan or replace the clutch for the fan
  23. uuuum no
  24. u married a Ky girl. aew you trying to weed out the in breeding :rotf: :cheers:
  25. most normal people are cofused :ack: by our truck any way right after thay see it sez jeep on it
