Everything posted by comanche87
The messed up thing is where it broke i don't see rust. In the past i replaced the bushings with poly ones. I bet thats what happened. From all the twisting. Never put polys in with stock arms! They are on the way. Hope to seethem mond or tues. Luckly I'm able to use another truck for the time being.
when i got home and went to change the oil on my truck and found my pass side upper control arm had snapped! the funny part was on tuesday i had replaced the lowers with much beefier ones that i got from maddzz1 and never noticed the pass upper was bout to go. I'm soo pissed and now waiting for the second time around for a set of 99 to 01 wj front upper control arms to come in! please arms get here soon!! i need my truck!!!
Wade's Kids like the "Smiley" faces
comanche87 replied to SuperWade2's topic in Forum Issues, Ideas, Testing
hey. i finally getting to see it on tlc! watching it right now!
question on swaybar links
comanche87 replied to comanche87's topic in MJ Tech: Modification and Repairs
hey. thanks. its too cold to weld right now but i do like that the newer xj's had longer ones. ill have to wait to get money unless i can find a used pair for now. -
hey. wanted to know what factory sway bar links can i use that is longer than stock? have 2 inch lift in front and running stock links in my 87 4x4 mj. thanks.
random informative picture thread
comanche87 replied to maddzz1's topic in MJ Tech: DIY Projects and Write-Ups
good thinking man!! i like pictures!! :D :D :D -
are u looking for one with or with out a tach? if without wbkrazy has one!!
is it worth changing a renix head to a ho head?
hmm. ill think on that. the head has no intake or exhaust manifold. there is what i have done to the motor. k&n air filter, rustys throttle body spacer and upgraded injectors same psi but has the better spray pattern. exhaust has magnaflow cat and flowsound 2.5 inlet and 2.5 dual outlet muffler.i have felt a big emprovement but thought that might help more. i get 200 to a tank. which seems ok but would like to get more if possible. -
i had the column shift in my 2wd mj. u have to change the trans only if u are going from 2wd to 4wd. u only have to change is the column, and put in the floor shifter and a shift cable.
what should i pull off a 96 gc
comanche87 replied to mopwrd340's topic in MJ Tech: Modification and Repairs
i didnt know the zj front axle was the same. hmm thats an idea if need to replace at one point. -
Feeler for rear tail light seals - now with pics
comanche87 replied to Akula69's topic in MJ Tech: Modification and Repairs
me 5 i think. lol i can give money to wbkrazy and have him send the green to ya! -
e-bay tailights
comanche87 replied to KYMJ's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
DAM!!!! time for me to try to find another set or 2 for cheap if possible and then keep the best 2 and sell the rest. -
$500MJ's Front Tow Points
comanche87 replied to 500 MJ's topic in MJ Tech: DIY Projects and Write-Ups
i hear ya. i have a welder but can't weld that good. maybe when i get back to work and it gets warmer out ill try to practis on welding better. -
Closed to Open Cooling System Conversion
comanche87 replied to LEAD_NOT_FOLLOW's topic in MJ Tech: DIY Projects and Write-Ups
not yet but thought id ask if when i need to replace my radiator. its not looking as good as it used to. -
lol. nice! i can't weld worth crap.nor drill holes good. id rather pay u to do that lol. i would seriously pay u to make one for me. when i get a job again. i bet u could make some extra money from doing that. -
what would be the cheapest way of doing the conversion. i know i can't really spend money but that seems alot for the conversion. what stuff can u leave alone but still convert it? -
oh man! i like this!! but got no money and no idea how to make it. u should make a bunch and see if anyone in the club would buy it. thats awsome!! if i was working id be like how much to build one? lol. i like it alot!!!! -
WJ UPPER Control Arms INSTALLED!
comanche87 replied to comanche09's topic in MJ Tech: DIY Projects and Write-Ups
where be the easiest to get those bolts? i got a set of uppers coming and need the bolts. do u think the dealer be cheap enough? -
Cherry Bomb/Glasspack OR Flowmaster
comanche87 replied to jeeplover88's topic in MJ Tech: Modification and Repairs
don't get the cherry bomb muffler. it wil last maybe a year then explode there only made from thin metal. i had one and it was junk. glasspack is kool but just doesnt last that long. id rather go with flowmaster just because its made from a thick metal and welded very good. it also sounds mean and loud!. -
http://www.facebook.com/home.php?#/grou ... 5035720180 this one has a few members in it.
:rotf: :rotf: :rotf: :rotf: :rotf: :rotf:
