comanche87
Everything posted by comanche87
  1. Hi. Up for sale is my 87 comanche that runs and drives but needs work. I have extra parts. Great for an offroad truck build. Price is best offer http://boston.craigslist.org/sob/cto/5216770742.html If any questions please ask. My email is jeepcomanche87@yahoo.com. Thanks mike
  2. I'm not much fond of low pinion but Unfortunatly I'm on a very tight budget and trying to maKe it last a bit longer.
  3. I took a look at it. It has a ujoint style yoke. I didnt think to look at the axle to see if it had adjusters. Thanks for the info. If i can just change the axle itself do i need to change some of the ujoint caps? Thanks
  4. Thanks for the info. I will keep an eye on it.
  5. Welcome! I used to live in east prov ri now in rockland mass You will definatly learn alot from this site. I knew nothing bout comanche till i joined this group. I learned alot bout these unique trucks
  6. Does any one know if a dana30 from a 98 zj with steering andtrack bad with bracket and front drive shaft would fit my 87 mj? Theres one at work that might be getting junked soon and looking to make the truck last just lil bit longer and would the steering shaft fit also. Thanks. The both have 3:55 gears
  7. Is there a chance might be able to find out what he did to make it fit? I might be looking at a fleet side ranger bed for the right price. Thanks
  8. Is there any details on what needs to be modified to a late 90's to possible early 2000's ranger bed fleet side. I'm might have found one but am looking for info on what needs to be done in order for it to fit. I'm not a ford person but might get it for the right price and i need one bad.
  9. Thats a nice looking bed. But unfortunatly its way too far. Hopefully one day i can find one. My truck is limited to how far i can drive it. Thanks though.
  10. Hey. Sorry I used to get notifications by email but haven't gotten any in a while. Unfortunately it's way too far and plus my truck can't go too far.
  11. Kool. I will try to shoot u a pm hopfully tonight or tomorrow. I'm trying to decide wich one i want.
  12. Awsome! Thanks for helpin my friend/ neighbor!
  13. Hey Pete do u still have any 10 inch or 12 inh decals left. I need a new one cuz a cone hit my back window and shattered it. Let me know. Thanks
  14. Please anyone able to help my neighbor/friend?
  15. Bumping it again
  16. Hey thought I'd see what was out there. I'm starting to look for a bed for my truck. Mine has a lot of cancer and I know it will be in near future I will need to replace it. The bottoms of both sides and below the tail lights are getting real bad. I am now starting to see cancer coming through the upper right rear wheel well. I don't have much but if I do come across one I can try to get it. Thanks. Mike.
  17. That's a good idea. Here's a thought. Put studs at the bottom so it can be removable if need to by using 2sets of nuts.
  18. I don't have much money but don't care if its used. I have a 90 Xj column In my mj I broke the lever and part was still stuck inside. So I drilled the broken part out and must have drilled too far hitting the internals of the switch. If anyone has one let me know and hope I can buy it from u. I do have Paypal. Thanks. Mike.
  19. Is this a kit u can buy or need to make it?
  20. I topped it off. The noise went away. So far it sounds back to normal. I don't see anything coming out the exhaust and the coolant looked ok.
  21. I usually check it here and there. I usually change the oil when its due. But I use free good oil I get. I've been soo low on money I skipped changing the filter I think 2 times. I saw it leaking a week ago. So I had to change it. It's not easy when ur very low on money. I haven't had a chance to do major repairs for a while.
  22. Hey. On sat on my way home from work my truck bucked and then the lifters were ticking very loud. Luckily I was only a few minutes away from home. I checked the oil and found it down 4qts. I did change the filter a couple of weeks ago. But know I didn't loose much. I can't remember if I had checked it then. Does anyone have an idea how it happened. Any help be great. Thanks. Mike.
