james750
Everything posted by james750
  1. On the left side in this pic (passenger side), you can see the vac bottle, he doesnt have cruise control b/c it is round and cruise control models have oval bottles. on the right side is the horn.
  2. yeah, i used some thinner and it worked some, I'm a little worried about a putty knife though b/c i don't want to scratch the original paint underneath.
  3. As seen in my most recent thread, DO NOT USE PLASTIKOTE :mad:
  4. Today i decided to line the rocker panels on my truck. first i washed it off and prepped the surface. then i went and grabbed the first can of tbl to do a few test sprays and then spray the truck. on the first can, i pushed the nozzle down and it stuck in the spray position :headpop: $5 down the tubes. second can = same thing :headpop: $10 down the tubes 3rd can = worked at first and then began to stick about half the time. once i had sprayed the truck and it dried I realized that although on the test sprays it looked alright, on the truck it looked like $#!&. now i want to get it off. any suggestions :(
  5. just remove the torx bolts on the bumper itself, that will pull it off. then remove the 3 bolts holding the brackets on, then (if u have tow hooks) remove the torx bolts at the frame tie ins. ;)
  6. i was curious as well. do you know what kind of other fittings i would need to get it to fill tires.
  7. 1st time ive heard of it. mind explaining a little more, sounds ...interesting.
  8. don't forget to switch over odometers ;)
  9. ok. not meaning to hijack but this seams relevant. my horn hasnt worked since i got the truck and after almost getting into an accident yesterday i decided it was time to fix it. q1: is a wire supposed to run from the horn button (post comes out of buttion and goes nowhere)? q2: what is the first step in fixing this (keep in mind i have no clue when it comes to electrical)?
  10. It looks like it is a combo new, old, and different xj. I saw it had old size and shape rear hatch and taillights. If I had my old xj still i would get one of the taillight sets seen here look up JEEP-2500-BODY PARTS
  11. Am I mistaken or is this Slaughterhouse? One of my favorite colo trails, and good for testing flex (and its only 10 mins away from the house).
  12. I am guessing it will be on June 5 th, 2008[/quote (tomorrow) :typing:
  13. I am guessing it will be on June 5 th, 2008[/quote (tomorrow)
  14. I am guessing it will be on June 5 th, 2008
  15. I am guessing it will be on June 5 th,
  16. I am guessing it will be on June 5
  17. I am guessing it will be on June
  18. I am guessing it will be on
  19. I am guessing it will be
  20. I am guessing it will
  21. I am guessing it
  22. I am guessing
