Goose
Everything posted by Goose
  1. Gas fireplace here :-\
  2. Hankook dynapro at-m Yokohama geolander a/t-s Procomp xtreme a/t
  3. Bfg a/t is hard to beat. The hankook dynapro a/t's are good, so are the Yokohama geolander at/s. My next set of tires will be procomps extreme a/t.
  4. Mine is an 88 pioneer longbed. 4.0, 5 speed, 4x4, sliding rear window, no tilt, no cruise, idiot lights, vinyl bench, manual locks/windows, 10 spoke wheels, a/c, no tech. Original owners manual came with it, as well as a bunch of service manuals. Originally a Kansas truck.
  5. Read this article. http://kontradictions.wordpress.com/2012/08/09/why-not-renew-the-assault-weapons-ban-well-ill-tell-you/
  6. Motor mounts are good. So what did you do to fix the issue?
  7. FUUUUUUUUU#K!!!!!!!!!!!!
  8. After I changed my clutch master cylinder, I've had a rattle at the same rpm in every gear, around 3-3500rpm. I cannot for the life of me, find the rattle. It's loud, and only does it when in gear. Won't do it while parked. Sounds like a f#*@ing woodpecker.
  9. Ok, thanks a lot.
  10. 12k? No thanks.
  11. It's an 88 4.0 longbed if that helps. Do i just drop the tank or what?
  12. Sorry to hear that :-( hate to see you lose a friend.
  13. Nothing?
  14. Ok, so when I fill my tank up, it shows it at about 3/4 tank. So obviously my sending unit is off. Is there a way to adjust it? Or do I need a new one. How hard are they to replace.
  15. Ok, I've found a guy here on Craigslist who has an 8.8 with 4.56 and an arb air locker as well as a Dana 30 with matching gears and a trutrac. He's asking $700. Good deal or not?
  16. *pinion Smart phone out smarted me.
  17. I belong to a great jeep club with many skilled individuals whom I could call on for help. I should've been more specific and said what other ring and opinion will work in my current diffs, what axles are easiest to swap, and which supermarket companies have you had the best luck with.
  18. I've got the Dana 30 up front, Dana 35 in the rear, 4.0, 5speed. 31" tires. I want to go to 4.10, but I need to know where to look, and what gear companies you recommend.
  19. SR1911, weatherby .270. Ruger superedhawk 10" barrel .44mag, Henry big boy .357, ruger blackhawk 6" .357, bersa .380, Winchester 1100 12ga, Winchester model 94 30.30
  20. Have you tried applying bfh?
  21. Today I used my mj to paint a few trees....by rubbing it against them.
  22. Check thoroughly for rust, if It's clean, the interior is good, and everything works Id go to $4500 maybe.
  23. I'm gonna have to mount mine on the top of the dash or passenger side. No room with my legs in the way.
  24. Photobucket, or any image sharing site. Use the IMG code.
