robfg67
Everything posted by robfg67
  1. Where in MA? I'm from Walpole. We should take the Jeeps out cruising some time.
  2. How did you connect the wires to TP371 and TP471?
  3. Cruiser, after the new TB is installed are we going to use a meter to adjust the output voltage to 17% of the reference voltage as instructed in your Renix TPS adjustment tip or is it a different adjustment?
  4. That makes sense. I'm guessing that the XJ's with the gold rims also got the gold colored emblems too.
  5. Were those gold rims a factory option?
  6. I used this write up and I was very happy with the results. Take your time and it will go fine.
  7. Thanks, do you recommend any particular brand?
  8. I have a '90 MJ with the 4.0L & the Automatic AW4 transmission. I want to add a used factory cooler that I found on eBay: https://www.ebay.com/itm/124425121514?fits=Model%3ACherokee|Make%3AJeep&hash=item1cf850aeea:g:0eYAAOSwW8Vfo03D&amdata=enc%3AAQAIAAAA0PA3CX03upB0Pv7ImUGBkIKFnaiDNtEvqqfTmsaOomo8hFb6vBB13%2FYr3YDC6bJos%2FgoG2qeBme3UfMTxpgLSr49T0X0Eyod%2FaBht1ByJJ0N4fWpwqnMLY7stv%2BLkGa5dZNidOTYrEC3L9O8zT7bwhpnTFr7XCB57OuGtdg8cqHwUdHrlOjh1zoLYS2L60HXSbSd8UQpZ3vtjIAicuRzA4gYCTX8IcDTvWR7kXWI0s4RrwN36GLY%2FLbeiIlKd9ShPketV6ZqhMxUY9%2F3gnu%2BA1Q%3D|tkp%3ABk9SR6zimPKkYw Can someone tell me how I add the lines from the radiator/transmission. Note, I live in the northeast, so warming the transmission fluid in the winter time is required as well. Here is a picture of how the lines run now:
  9. Do you guys know the difficulty level of getting all the sensors?
  10. Was this hide a winch from Toledo, or was it a dealer accessory?
  11. This diagram should be put in an electrical 101 book. I followed it exactly and the fog lights lit up the first try with no debugging. I cut the green with black tracer wire that comes from the fog light switch in the dash at the 10 pin connector and connected it to 86 on the relay. Thanks
  12. The connector has an orange with green tracer wire and a light brown with a blue tracer wire.
  13. Very happy with how they look. Very tight clearance to the grill.
  14. Yeah, my '90 didn't have the wires for the cargo lamp, but did have the dash wires for the fog, even though the truck wasn't ordered with either.
  15. I'll have the bumper off tomorrow to add fog lights, so I can report back the colors of the wire.
  16. If, in fact, that is a temperature sensor for an XJ-something never offered in an MJ, I wonder if it was a mistake on the assembly line.
  17. Is there a factory diagram that shows it?
  18. If so, wouldn't there be two pigtails?
  19. I have the factory fog light switc and wiring in the cab. Are they fairly easy to connect to the factory set up?
  20. Just ordered a pair of these Hella 450's after seeing them on your truck. Definitely have an 80's vibe.
  21. Yes, no response at all.
  22. Still Need one.
  23. PM sent
