robfg67
Everything posted by robfg67
Are these Turbines worth it?
robfg67 replied to robfg67's topic in MJ Tech: Modification and Repairs
Ok, Salvagedcircuit, you already got yours, so how did you find them? Craigslist and eBay are very thin on decent rims for a decent price. -
I've read though the posts on restoring them and it seems like each wheel would take many. many hours. fiatslug87, what would be a more fair price? -
Got a lead on 5 Turbine rims with 4 center caps for $550. I haven't seen them in person yet, but the picture attached is a fair representation. Thought?
Does anyone make a front tow hook kit for the MJ?
From the Quadratec site, it says that it will not fit the MJ. -
Rylee, Are these parts that were sourced from MOPAR? I thought MJ's from the factory had the tow hooks welded on. Thanks
I thought that was true, but just needed confirmation. Thanks -
SporTruck w/Plow - Bantam, CT $2500
robfg67 replied to NHMJXJ's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Does anyone know the guy in CT who is selling this MJ? I've sent a couple of emails and no response. -
Thoughts on upgrading to this auxiliary fan...
What years had the 9 blades? I'm assuming they come from XJ's. -
Hey, I recognize that truck! I replaced the upper control arms just after I got her, but otherwise the front end is fine. -
All good info, thanks. I saw a the exact tire size that I need recently on C/L, but the date code on the tire was 11 years old, so I passed. Not sure if it's a DOT law or regulation, but tire shops won't mount a tire older than 10 years.
Putco Headlight Wiring Harness In-Line Fuse Size?
Makes perfect sense, thanks. I'll check the gauge of the wire and go by that. I still have the stock 60W headlights. -
Thanks Pete. Back to the drawing board.
Good advise, thanks. I think I'll buy the C/L wheel and replace the tire with the correct size down the road. The rim itself is worth it.
I have 4 Jeep Wrangler Moab rims (16x8) with LT265/75R16 tires without a spare. I found a C/L wheel from a 2017 Jeep Wrangler Sport with the Moab rim, but with a P255/70R17 tire. https://boston.craigslist.org/bmw/wto/d/foxboro-2017-jeep-wrangler-spare-wheel/7639219913.html Could I use this wheel as a spare? On an aside, yes, I would love to get a set of Turbines, but they're not easy to find in decent shape (or inexpensive).
Where to source the 940 Volvo Turbo Cap?
I'm not arguing. "Money trap" encompasses all the things that I've spent money on-not just the cooling system. I'll do the full conversion. Can anyone recommend a good DIY write-up? -
Cruiser54, This truck is a money trap!!! Is this a direct replacement or does it have a radiator cap? -
Would using the Prestone Flush Kit clear up most radiator clogs? -
Looks original. Why do you ask? -
Full of (easy) questions this morning... I added the Putco headlight wiring harness toi the MJ recently and want to add an in-line fuse to protect the harness. 1. What size fuse should I use? 2. Should I add a fuse to each red wire going back to the positive battery cable? And, yes, I ordered "better" relays to replace the crappy ones that come with the kit.
robfg67 posted a topic in MJ Tech: Modification and Repairs
I ran the MJ on a 50 mile highway trip yesterday on 88 degree heat, high humidity day and the temperature gauge increased slowly but hung around 230. It never got above that, but it was a little too close to the red for my liking. I've done my research and discovered that replacing the bottle with the 940 Volvo Turbo cap should help seal the system better, so I'll start there. Previous posts from many years ago say that the cap costs about $40. A Google search shows many caps for under $10. I found one on Amazon for $7.98; but want to be sure that I buy a good quality one. Any recommendations for where to get a good one? -
Help with Dark Factory Radio Display
How much shipped to 02081 in Massachusetts? -
Difficult, but not impossible task. I replaced both bulbs and they work!!! Minuit, can anything be done to remove the black framing at the bottom of the display glass?
