27
Everything posted by Eagle
cant find a speedo cable!!
Eagle replied to Huntingman2706217's topic in MJ Tech: Modification and Repairs
Well, the '94 had an electronic speedometer, so it didn't use any cable. Try a different store, with a smarter computer. -
would a ZJ grand cherokee be a good donor
Eagle replied to teckman02's topic in MJ Tech: Modification and Repairs
No. Different (inferior) transmission. -
Had to solder the radiator up today
Eagle replied to Jerry's topic in MJ Tech: Modification and Repairs
The boiling point of water at sea level is 212 degrees F. That's about where the Jeep engines run. The boiling point for 50/50 glycol mix is up around 250 or 260 degrees. Plus, plain water in the engine will start things rusting inside your block before you can blink. Save your coolant when you drain it, strain it through cheesecloth, and re-use it. -
There is no difference between the 4-cylinder and 6-cylinder speedometers. There IS, however, a difference between the early (thru 86, and maybe part-way into '87) speedo and the '87 thru '90 speedo. The early type has a metal end on the cable that attaches to the speedo head with a screw. The later type has a white nylon end on the cable and it just snaps over the fitting on the speedo head. -
You need a subscription to read what this TSB is. But ... although it is titled "Recall - Replace catalytic converter" it is listed as a TSB and the number is NOT an NHTSA recall number, so I am still of the opinion that this is a TSB rather than a recall.
In my view, if it isn't listed on the government's official recall site, it isn't a recall. It may be a TSB, bt the difference between a TSB and a recall is that recalls are mandatory -- they HAVE to do them, and the manufacturer pays. TSBs are recommended but optional, and YOU get to pay if you have them done.
http://www-odi.nhtsa.dot.gov/recalls/ I tried a search, for both 1989 and 1990 Comanches, and I didn't come up with anything for the catalytic converter. And the number you gave is not in the right format for an official recall. http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm Are you sure it was a recall, and not a TSB (technical service bulletin)?
Cranks, fires, but won't start...
Eagle replied to crooner's topic in MJ Tech: Modification and Repairs
That's good news. As Colonel Hannibal Smith liked to say, "I love it when a plan comes together." -
Hey guys, I need some information
Eagle replied to MjPioneer's topic in MJ Tech: Modification and Repairs
So what happened in court? -
If the neutral safety switch were bad, (a) it wouldn't crank at all, and (B) you wouldn't have spark. -
And base 15 x 6" rims. But it's only 75,000 miles. I know we're Jeep guys and we expect people to pay us to take their old vehicles away, but realistically ... what does a new Ranger sell for these days? What does a clean, 5-year old Ranger with 75,000 miles on it sell for these days? We're spoiled. In reality, that's not a bad price.
How do you know it's broken?
Either type
The fuse box is not the PCM. PCM is the acronym for Powertrain Control Module -- i.e. the computer. Did you read the diagnostic codes or not? -
Did you check for fault codes as described by Hornbrod? -
Do you have a long bed or a shortbed? If the wheelbase is used, obviously that matters. The track is different depending on the factory wheels. With the base 15 x 6 rims track is 57". With any of the 15 x 7 rims track is 58". Wheelbase for the longbed is 119.9". So using a longbed with 7" factory rims as the base I get 58 x 119.9 / 2200 = 3.16 I believe the shortbed wheelbase was 112.9". If you use the narrow track and the shortbed, you get a worst case of 57 x 112.9 / 2200 = 2.93 -
I used to own a 1971 CB350. It was a great bike ... my first ... but a little on the small side for my 6'-2" height. But it got great gas mileage, and since I was living in West Philadelphia at the time (graduate school) it was perfect urban transportation. However, I long ago moved up to a Honda Nighthawk, and even that has been gone for many years. I never had any mechanical issues at all with the 350 so I couldn't begin to help you diagnose what the problem might be.
Let's go back to basics. Your opening post says it cranks and it starts, then it dies. That's saying it starts. Now you are saying that it is not starting at all, which would mean it is NOT starting. I don't mean to sound insulting, but do you know the difference between "cranking" or "turning over" and "firing"? It's difficult enough to diagnose problems by remote control with an accurate description of the symptoms. When the description of the symptoms is self-contradictory, it's impossible. Do you have spark, or not? Also, your opening post says you can hear the fuel pump. Is that with the key in the RUN position or in the START position? Because if it's with the key in the RUN position, then the fuel pump IS getting power and the problem is not with the ballast resistor. However, it could be that the fuel pump isn't pushing enough fuel to keep the engine running. If you can hear the fuel pump running when you first turn the key to RUN (not START), does it run for 5 or 10 seconds and then stop, or does it keep running? It should shut off after a few seconds because the fuel rail has pressure. If it doesn't shut off, either the pump is bad or the fuel pressure regulator is bad. According to the '94 XJ FSM, as of 1994 the ballast resistor was no longer used, so that was a bad call on my part. You can stop looking for it. -
Whacked out Alignment....?
Eagle replied to ComancheKid45's topic in MJ Tech: Modification and Repairs
??? Toe-in (or toe-out) is the difference in track between the front of the tire and the back of the tire. You can't have ONE wheel toed in or out. If you unbolted the steering box, did you mount something between it and the frame? If so, you moved the box and changed the effective length of the drag link. That doesn't change the toe-in, it just changes the centering of the steering wheel. {EDIT] Wait -- you unbolted the power steering PUMP? The pump isn't in any way connected to the steering or suspension. Unbolting the pump could not possibly affect your alignment. -
Your signature indicates that you HAVE a new clutch. So before you replace a new clutch with another new clutch, how about seeing what went bad? I would suggest first looking at the hose between the master cylinder and the slave cylinder.
The CPS controls the ignition, and the injection pulse. If the CPS were the problem, it would not start. Not at all. If you have spark, the problem is not the CPS. Assuming you have fuel because you have spark is a VERY bad assumption. The CPS does not in any way control or affect the fuel pump. But the ballast resistor does. The ballast resistor reduces voltage to the fuel pump during running. For starting, the start circuit bypasses the ballast resistor so you get the full 12 volts to the fuel pump. Which means the fuel pump will pump as long as the key is in START because the circuit bypasses the ballast resistor, but when the key is released to the RUN position the bypass circuit goes away and the power to the fuel pump goes through the ballast resistor. If that's bad, the fuel pump stops pumping as soon as the key goes to RUN, and the engine dies as soon as the residual fuel in the system has been used up. -
If the problem was the CPS it wouldn't fire at all. If you are certain the fuel pump runs when the key is in the RUN position, that should eliminate the ballast resistor as the problem. I would look next at the ignition switch. However, I think first, just to be certain, I would jumper the ballast resistor to make absolutely sure that's not the problem. A '95 has OBD. Do you know anyone with a scanner that can read '95 Chrysler codes? -
So I spun a rod bearing... now what?
Eagle replied to Philistine's topic in MJ Tech: Modification and Repairs
I definitely plan on keeping the truck. Its in great shape for its age (other than the engine). That's one of the options I'm considering. I don't want to dump money into fixing a 24 year old engine if it isn't prohibitively expensive to swap in a new or rebuilt engine. I'm just trying to find out what my options are and what the costs could be. The trouble is that it IS prohibitively expensive to swap in a 4.0L if you are not set up to do it yourself. You basically have to gut the truck and replace everything. It isn't just the engine. The 4.0L will immediately require a different transmission and transfer case. You'll need a different radiator, and the radiator supports have to be ripped out and replaced to accept the 4.0L radiator. Hammering the firewall is the least of the issues. To use a 4.0L, you will have to rip out the entire engine room wiring harness and replace it with the correct one for the engine you'll be installing. Easiest would be a Renix 4.0L, but even then the donor harness will probably come from a Cherokee and that harness won't mate up to a Comanche body harness without some customization. And the newest Renix 4.0L will be a 1990, so that's 20+ years old already. For the work involved, it would make more sense to swap in an HO, but then you have even more wiring issues to deal with. -
Inspection FAILED! Noob needs help :)
Eagle replied to jbilly's topic in MJ Tech: Modification and Repairs
Before you start throwing money at it ... please read this: http://www.auto-repair-help.com/auto_di ... ailure.php You have high CO (carbon monoxide) AND high HC (unburned hydrocarbons). That's not very usual. Look for things in the lists that occur under both categories and start there. -
No. The spacing of the spring perches (the distance between them) is different for the XJ than for the MJ. Even if you want to go to a spring-over in the MJ you still have to remove the XJ perches and re-weld them in the correct locations.
