Drahcir495
    3
Everything posted by Drahcir495
  1. Got mine in and it looks awesome. Going to be a little while before I can get it installed though ->
  2. Is he a member of CC or a business?
  3. I’m going to have to check if it can be repaired when I get it pulled out. It might be past the point of repairing it??
  4. Haven’t taken it down yet but
  5. I did a search before I asked and saw the group buy thread. I think $350 is too much but mine has been destroyed by mice so not sure what to do?
  6. Is there anyone making the headliner boards? I don’t need one with fabric. Just need the board the fabric goes onto.
  7. Got the REM in from NickinTime . Switches in and it’s ready to install ->
  8. Drahcir495
    Finally
    Great choice on the rims and tires. Looks good
  9. **Start of Rebuild** I hated how I butchered up the center console with the idiotic Eaton E-locker switches and then cutting the front of the console insert to fit the CB in -> I didn't know enough about switches back then to realize I could use regular rocker switches instead of the ones that came with the lockers . I think I got the Idea from NickinTime to get a three rocker switch plate to put in the coin holder of the console insert. I already did this to the Cherokee and very happy with it. I grabbed a insert from an XJ and replaced the parking brake slot with a block off plate from a factory MJ. I cut out the bottom of the coin slot to get the three switches to drop into place -> Test fitting the switch panel -> Lined it up, drilled the holes for the four screws and secured it with 4 stainless bolts -> Painted the bolts black which looks a lot better
  10. But not because I care about some guy’s opinion i didn’t ask for
  11. Never heard of that? I will look into it
  12. This may help you -> https://tiresize.com/gear-ratio-calculator/
  13. I think I found it but it’s rusted and seized up. I forgot it was left outside . Working on getting it freed up and then to work to remove the rust, replacing the U-joints and then painting it.
  14. That was very helpful. Ant tips on taking the cover off the board? I assume it also has adhesive inside towards the center?
  15. The door panel backing board ?? is pretty much toast for the lower clips to hold in. Is there any recommendation on how to fix this?
  16. Here is where I put mine following cwlongshots example
  17. Oh boy, I will be looking for more
  18. I agree, cool looking truck! Great to see something different in a build. Congratulations on Comanche of the month.
  19. I like that a lot. They are sold out in my size though
  20. There is a really nice MJ t-shirt on Etsy. I can’t take credit for what my wife found
  21. Yep, when I used the 3M super 77 on the XJ it sagged too. You really need to post this in the DIY section too. I would be very helpful to others
  22. Yeah, I was thinking the blue to match the radio and switches. I like the green though, so that would be fine.
