Drahcir495
    3
Everything posted by Drahcir495
  1. I was going to ask if you were able to change the display color! I think I am going to do the LED lights, so thanks for the link to that.
  2. Well Done! I had a good time redoing mine too. I would have used a dremel wheel on mine if I had seen someone do this before. Thank you for sharing
  3. I think you are doing the right thing!
  4. The Cherokee will be going up for sale after I get a few things fixed. I am going to keep my Comanche and this would have to be stored on the property rotting away like the MJ unfortunately did. Here will be the ad I place on BaT or something similar. I haven’t taken pictures yet because I’m presently out of town. I started to get the ad written up, so I will prep it here so when I am ready I can cut and paste it where I decide to list it. I have to research what to list it at. I can't total what I have in it to compare to what it is worth. Just a bad idea to do. For Sale an 1990 Two Door Jeep Cherokee (XJ) 4x4 Laredo This is my daily driver. Only been taken out a few times on sandy trails – no mud since I’ve owned it. Never intended to sell it, so I put everything in to it. DRIVETRAIN o 4.0 inline six motor with ?? miles on it o Brown Dog rubber motor mounts o Upgraded to 4 hole injectors from Precision Injectors o Hesco cold air intake o AW4 transmission (rebuilt by AAMCO with 300 miles on it) o NP242 transfer case (rebuilt) with Azzy shifter linkage (not adjusted) o Rubicon Express 3.5” lift kit with 4” front coil springs o Blistein shocks o Adjustable Rubicon Express upper and lower control arms o Rubicon Express sway bar relocation brackets o Front 3/4” coils spacers o Rubicon Express leaf springs o JKS rear shackles o Cherokee Up-Country sway bar o Five (5) Toyo Open Country tires (33x13.5x15) o Mickey Thompson black simulated bead lock rims o New open system radiator o New Crown factory coolant over flow bottle o Grand Cherokee mechanical fan with fan shroud o New electric fan wired to always stay on o New water pump o New thermostat o New alternator o New cap and rotor o New spark plugs an wires o New water pump o New CPS o New electric fan o New blower motor o New TPS o New AIC o Horn Blasters nautical horn o K suspension ultimate wire upgrade kit – not fully installed o New exhaust system with catalytic converter o Brake booster o Brakes o JCR Off-road battery tray o Fairly new ??? battery o New A/C runs cold o Front high pinion D30 front high pinion axle with Eaton E-lockers and 4:56 gears o Rear D44 axle with Eaton E-lockers and 4:56 gears o Front and rear OX locker differential covers EXTERIOR o Upgraded to 3 piece grill o Door seals from an 1998 Cherokee o Partsram LED headlights o RCL Welding and Fabrication custom front winch bumper with 2 mounted D-ring shackles o Two Nilight LED spots lights on RCL bumper o Protofab protective side rails o JCR Off-road rear bumper with swing out spare tire carrier o JCR Off-road with Rotax gas can mounting system on swing out tire carrier o Two Rotax gas cans o JCR Off-road High-Lift jack mount on swing out tire carrier o Hi-lift jack???? Want to keep? o JCR Off-road antenna mount on swing out tire carrier o KC Highlights LED lights mounted in the JCR Off-road rear bumper wired to come on when in reverse and manually controlled o Two D-rings mounted on the JCR Off-road rear bumper o Off-road gas tank protection not installed o Rugged Ridge LED 3rd brake light ring in mounted spare tire o Back up camera mounted spare tire o ??? steel lower quarter body panel guards – not installed o JCR Off-road rear quarter protection panels not installed o Bushwacker fender flares o Roof rack with two rear facing Nilight LED lights o Two black five gallon jugs mounted inside roof rack????Want to keep??? o Side windows with the vented swing out windows o Windows tinted o Functioning 97 Jeep Cherokee side view mirrors INTERIOR o Crack free dash o Interior in excellent condition o LED interior lights ???want to keep??? o New headliner o Full overhead console o Vanity sun visors o Working clock o Crack free dash o Voxx full replacement rear view mirror with front and rear back-up camera’s o Ice cold A/C o Mounted Maglight 2 D-cell LED flashlight o Rugged Ridge front floor liners o Quadratec Ultimate rear and cargo area floor liners o Sony CD stereo with phone mic mounted up to sun visor o 2 Rockford Fosgate speakers mounted in doors o 2 Rockford Fosgate speakers mounted in hatch o 2 Rockford Fosgate speakers mounted in the rear factory overhead sound bar o Kenwood KAC –M1814 compact amp o Kenwood KAC –M3001 compact subwoofer amp o Kicker 8” subwoofer mounted in the Select Increments subwoofer enclosure o Select Increments subwoofer enclosure designed to fit in the cargo cubby hole o Aluminum 3 rocker switch plate mounted in center console coin slot with two rocker switches control the Eaton E-lockers and one for the Whelen strobe lights o Factory console cup holder o Electric side view mirror control in factor cup holder location o Switch for the rear KC bumper lights mounted on cup holder o Two rocker switches that control both power and line in/out winch mounted in shifter panel o Whelen CPS660 strobe light system NEED’s o Paint o Body damage in quarter panels behind door in front of tires need to be fixed when painted o Needs floor boards repaired – rear floorboard in passenger side patched and sealed o Some tears in Drivers side seat where material meets piping o Speedometer cable ??fix?? o 2 Tires ?? getting o Headliner fixed o Problem with stereo ??getting fixed o Azzy transfer case shifter adjusted o Issues with Voxx rear view camera – turns off on occasion, haven’t figured out how to get to record properly o Drivers side seat control assembly o Needs electric door locks fixed o Electric windows replaced with manual crank ups Miscellaneous o Big binder of receipts o Extra used replacement carpet o Another set of side windows without the swing out vent windows o Second set of side windows with swing out vent windows o One extra front Bushwacker fender flare o Extra new style door seals o Electric window assemblies Probably more that I'm forgetting
  5. Thank you for the information. I was wondering if they wrote out the ad. I don't like that it takes that long to get listed. I have just spent a few hours yesterday highlighting everything that has been done to it, what it needs, and any extras that go with it. I will really have to figure out what I should price it at. I will not be totaling up what I have in it - it is an obscene amount that I will never get back. I built it intending for it to be my last Jeep. I want to put a reserve price for sure, but I have to realistic which is going to hurt
  6. I thought I would just park the Cherokee on the parents property (just what they love to hear ) so I can hang on to it . After seeing what happened to the Comanche after sitting, I won't be keeping it just to watch it waste away. My question is where would be a good place, in addition to the for sale section of a Cherokee forum, to list the Jeep? I have seen the Bring a Trailer auction site as an option. Anyone have any feedback on going this route? The reason I want to sell it this way because I don't know where to start with pricing it? I don't want to start another "what is it worth" tread and just let the bidders set the selling price. Ideally, I would sell it for what I have in it, but I can't imagine totaling it up . Question - a good place to sell the Cherokee??
  7. How can you not like that body style .
  8. I'm in Wisconsin right now so I will have to check that when I get home.I do know it has a cold air intake and throttle body spacer if that can tell you anything?
  9. Definitely puts all things in perspective. I think I have the HO head, intake and throttle body on it from the swap IIRC? Don't remember all the details since its been at least 10 years since I did it. You are a wealth of knowledge for sure - thank you. You saved me close to 2k.
  10. Thanks for the advice Cruiser Really went down a rabbit hole with the YouTube video's
  11. Good point! I have another Renix computer in my spare parts bin that I have no idea where it got it?? I will be grabbing them out of the junk yards when I find them. I'm so glad that I come here for advice . . . backing slowly from the edge
  12. Yep, I had to keep a lot to get the new motor to work in the jeep
  13. I love the harmonica prank. We have been known to put Pride stickers on our friends bumpers. Its all in good fun
  14. I thought the same thing if it ain't broke . . . he is saying the Renix computers are becoming harder to find when they fail and they are over 30 years old now. Also I should be utilizing the benefits of the newer motor and technology. He has a donor jeep there that he can scavenge from. And I just bought the REM from Nick last night before I got his call this morning ugh. I am way past wanting to do this myself. There was a time before starting a family that I would have taken this head on myself. Now, I just want it reliable and simple.
  15. I should have already done a search but I need some input on switching to the HO computer etc away from the Renix system. I have the Jeep at a Jeeps only mechanics shop. I have an 1998 XJ motor in my MJ now. I have the renix system running it. He suggested that I switch it over to the newer engine management system - computer and all that goes with it. Has anyone done this before? He makes it sound likes its no big deal to convert. I am not sure about this? It was running fine with the way its set up now. The guy really knows his stuff but what happens if something goes wrong and I have to explain the Frankenstein set up to someone else? I have a lot of questions but I just want to get the advice rolling.
  16. Just talked to Nick via Messenger. No coupon codes available. Just ordered the one with the switch cut outs
  17. Great tips. i love how bright the clock is. Anybody have a coupon code for this? I noticed when I went to order one they had an apply code box .
  18. That is perfect about the print out with the normal ranges. I would not be able to figure it out other wise
  19. Great pictures I appreciate it. I will be getting one
