mknherhappy Posted June 9, 2008 Share Posted June 9, 2008 Going to Herculine the box on my MJ, was thinking about doing the rockers and lower fenders, anyone ever do this? Any advise? Are the brands about all the same or is Herculiner better? Thanks again for all of your help Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 9, 2008 Share Posted June 9, 2008 I tried Herculiner on the interior of a shell; I had problems getting a homogeneous mixture in the can (large chunks that wouldn't dissolve). It also balled up during application, but it was 104° when I was doing it :dunce: . The other problem I had was the foam roller they provided disintegrated during use. So I decided to get the truck box professionally done. Link to comment Share on other sites More sharing options...
djag12 Posted June 9, 2008 Share Posted June 9, 2008 I had a F150 with LineX- it was great. I leased a Sierra and put Hurculiner in it - no comparison but did a good job. In my Comanche I am going to use Raptor(ebay) - have only read good things about it when surfing the net. Link to comment Share on other sites More sharing options...
500 MJ Posted June 9, 2008 Share Posted June 9, 2008 I got the rockers on mine sprayed at the body shop before I shot paint last summer. I don't know the name of the stuff but he told me that it was a rocker panel product. I got it color matched to the paint so that if I ever chipped the paint (I painted over it) it would be disguised... I'm VERY happy with it so far! Link to comment Share on other sites More sharing options...
bobweiser Posted June 9, 2008 Share Posted June 9, 2008 I did the entire outside of my CJ with Durabak (www.durabakcompany.com) There is about a sixteen colors with or without UV protectant. They have a smooth and a textured finish available. Very happy with it so far, about 1 year. I used Herculiner under the tub and in the interior. Herculiner will fade. They offer a UV protectant but only for the black. Link to comment Share on other sites More sharing options...
james750 Posted June 9, 2008 Share Posted June 9, 2008 As seen in my most recent thread, DO NOT USE PLASTIKOTE :mad: Link to comment Share on other sites More sharing options...
87ComancheLB Posted June 10, 2008 Share Posted June 10, 2008 I herculine the inside cab and nerf bars, prep is the key I didn't use scouring pad but coarse sandpaper 80 grit, wipe down with Xylol. Get one of those mixing tool attached to a drill, stuff is pretty thick can be diluted with Xylol and get rubber gloves if this stuff gets on your skin and it drys forget about removing it almost impossible, can be removed when still moist and with xylol. Link to comment Share on other sites More sharing options...
xjcrazy09 Posted June 10, 2008 Share Posted June 10, 2008 does the herculiner in the floorboard of you truck smell bad when it heats up? Link to comment Share on other sites More sharing options...
87ComancheLB Posted June 10, 2008 Share Posted June 10, 2008 It did in the beginning but after about 2 weeks the smell was gone. I notice while installing the AC I need to do the engine floorboards under the battery holder some surface rust already knock it down just need to add some more there I knew I forgot something. Link to comment Share on other sites More sharing options...
A-man930 Posted June 10, 2008 Share Posted June 10, 2008 I've had a kit waiting to be applied for around a year now, someone told me to use 80 grit paper as well... Link to comment Share on other sites More sharing options...
