reson46 Posted March 24, 2008 Author Share Posted March 24, 2008 I needed a place to mount the CB antenna that was out of the way and somewhere to put the spare. I had some left over angle iron from some other projects that I built this out of. Willy Link to comment Share on other sites More sharing options...
reson46 Posted March 24, 2008 Author Share Posted March 24, 2008 That's about everything for now. I didn't get a chance to start on the rock sliders, but that is next on the list. Willy Link to comment Share on other sites More sharing options...
500 MJ Posted March 24, 2008 Share Posted March 24, 2008 Great Pics, Thanks for posting them! Link to comment Share on other sites More sharing options...
Twisty Posted March 24, 2008 Share Posted March 24, 2008 Thanks for the pics of the doubler. Thats on my to do list this summer. Is the rear case a 23 spline case? Link to comment Share on other sites More sharing options...
reson46 Posted March 25, 2008 Author Share Posted March 25, 2008 Thanks for the pics of the doubler. No problem. Let me know if there is anything else you want to see. I've got several more pics that may be helpful. Is the rear case a 23 spline case? Yes, but he makes shafts for the 21 spline transfer cases too. As well as some GM spline counts. Willy Link to comment Share on other sites More sharing options...
reson46 Posted June 26, 2008 Author Share Posted June 26, 2008 I've been working on the rock sliders in my spare time. Besides paint the passenger side is done. We are having a new roof installed so there isn't much money left at the moment. Hopefully after the roof I'll be able to pick up the tube for the driver side. Willy Link to comment Share on other sites More sharing options...
reson46 Posted June 26, 2008 Author Share Posted June 26, 2008 While waiting for materials for the driver side rock slider I decided I had enough material to at least get started on the rear bumper. This is what the stock one looked like after the first wheeling trip. The passenger side bracket. The driver side bracket looks pretty much the same. I'll run gussets from the bumper clear up to just behind the cut out for the shackle hanger. Willy Link to comment Share on other sites More sharing options...
reson46 Posted June 26, 2008 Author Share Posted June 26, 2008 I'm using 2"x4"x3/16" rectangular tubing for the bumper. A couple of in progress shots of tapering the end. Test fitting the hole for the receiver tube. End of last night's progress. Willy Link to comment Share on other sites More sharing options...
reson46 Posted June 26, 2008 Author Share Posted June 26, 2008 Up next is cleaning off all the rust. Then I'll start welding everything. I'm also going to cut the lower rear quarter panels of the bed off. Then I'll run 2"x3" rectangular tubing from the bumper up to the rear tire. I'll also run a brace from the 2"x3" tubing to the front of the bumper bracket, probably in that open spot between the shackle hanger and large bolt on the front of the bumper bracket. Similar to what I did with my XJ. Willy Link to comment Share on other sites More sharing options...
reson46 Posted June 27, 2008 Author Share Posted June 27, 2008 The roofers finished the roof yesterday. :clapping: Image Not Found Image Not Found Willy Link to comment Share on other sites More sharing options...
reson46 Posted June 27, 2008 Author Share Posted June 27, 2008 I cleaned off the rust, welded the receiver tube in, and finished most of the welding on the tapers until I ran out of wire. Willy Link to comment Share on other sites More sharing options...
reson46 Posted July 1, 2008 Author Share Posted July 1, 2008 I picked up some wire and finished welding up the tapers on the ends. Even though I can almost guarantee I won't tow anything with this, I added a place to attach safety chains. If nothing else it helps support the receiver. Willy Link to comment Share on other sites More sharing options...
ejndssn Posted July 1, 2008 Share Posted July 1, 2008 jus wanted to let you know that ur mean with that solder iron and probably can do that in ur sleep great skill Link to comment Share on other sites More sharing options...
BREEZE1 Posted July 1, 2008 Share Posted July 1, 2008 nice!! :D Link to comment Share on other sites More sharing options...
reson46 Posted July 2, 2008 Author Share Posted July 2, 2008 The passenger quarter panel was removed last night. Willy Link to comment Share on other sites More sharing options...
reson46 Posted July 7, 2008 Author Share Posted July 7, 2008 I removed the driver side quarter panel. Welded the bumper to the brackets. Now I just need to wait until I get the rest of the tubing before I finish it. Willy Link to comment Share on other sites More sharing options...
reson46 Posted July 7, 2008 Author Share Posted July 7, 2008 Got a delivery today. :D Willy Link to comment Share on other sites More sharing options...
reson46 Posted July 28, 2008 Author Share Posted July 28, 2008 Worked on a few things as I have time over the past few weeks. Painted the passenger rock slider. Willy Link to comment Share on other sites More sharing options...
reson46 Posted July 28, 2008 Author Share Posted July 28, 2008 Also picked up the rest of the steel for the rear bumper and driver side rock slider. The passenger side of the rear bumper tacked in place. I had to modify the bumper mounting brackets and make the side support removable. I figured I probably would have to do something like this. There was just no way to get bumper on and off with the support tied into the mounting bracket. This is the passenger side support. Still have some work to do on the driver's side. Then I'll pull everything off, finish welding, and paint it. Willy Link to comment Share on other sites More sharing options...
reson46 Posted July 30, 2008 Author Share Posted July 30, 2008 Last night's progress. Passenger side. Rear. I filled the gap between the 2"x4" tube and body with some 1/8" plate. Another view of the passenger side. A couple of pics of the driver side support. This one from the rear. From the front. Willy Link to comment Share on other sites More sharing options...
reson46 Posted July 30, 2008 Author Share Posted July 30, 2008 I also picked up a WJ booster and master cylinder this past weekend that will find its way into the MJ. Willy Link to comment Share on other sites More sharing options...
reson46 Posted August 4, 2008 Author Share Posted August 4, 2008 Finished welding the rear bumper this weekend. Willy Link to comment Share on other sites More sharing options...
reson46 Posted August 4, 2008 Author Share Posted August 4, 2008 I also started working on winch placement. My wife doesn't want me to cut up the grill to fit the winch and I don't want it hanging a foot off the front, so it is going behind the front cross member. It's up against the steering box on the driver side and clears the fan on the passenger side by maybe a quarter of an inch. At the very least I need to notch the fan shroud, but, after seeing what hornbrod did, I think the clutch fan will be removed for a second auxiliary fan. One of the transmission cooler lines will also need rerouting. Sounds like a good time to add an auxiliary transmission cooler. :D Willy Link to comment Share on other sites More sharing options...
MiNi Beast Posted August 4, 2008 Share Posted August 4, 2008 :eek: reinforcement I hope? Link to comment Share on other sites More sharing options...
camjeep3 Posted August 4, 2008 Share Posted August 4, 2008 judging by the rest of the build i wouldnt worry to much. looks like he knows what hes doin sweet truck Link to comment Share on other sites More sharing options...
