JeepcoMJ Posted February 28, 2008 Posted February 28, 2008 I'm in the process of building an on board air system for it right now...will update with pics as it comes along. so far spent (at menards) $7 on a cheapo hose i can use offroad $35 on a pretty heavy duty air filter/oiler/pressure regulator system. $6 on the oil/water seperator $5 on some fittings it's meant to run : air tank/compressor, filter, regulator, oiler....with oiler being for the tools. I'm running it : filter, oiler, air compressor (a/c compressor), regulator, oil/water seperator doing it this way so that I can oil the compressor automatically once i've got the drip feed adjusted. still need to get the hardline for between the oiler and intake of the compressor (has to be hardline cause suction will cause it to go flat otherwise), and output to regulator line. I've got all the connectors I will need. for now, I will be running tankless. when I have the accessories in the bed all set up, I will plumb the truck for a tank.
JeepcoMJ Posted February 28, 2008 Author Posted February 28, 2008 got everything I need except for the pressure cutoff switch, and one 1/4x1/4 threaded adapter. here you can see how little room I have to work with Image Not Found but, on the bright side it's still easy to work with Image Not Found drilling out for 90 degree fitting Image Not Found first holes Image Not Found back of compressor Image Not Found with manifold mounted Image Not Found manifold. I have to weld plugs on the two open holes Image Not Found here's the completed setup Image Not Found air filter and oiler Image Not Found regulator, oil/water seperator, connector. haven't installed the connector/seperator yet because i'm not sure where they will be located. Image Not Found back of the compressor. as stated, i gotta weld the holes yet Image Not Found the braided line is actually water line. copper inside, stainless steel braiding. $3 each at 20" long, and they are meant to hold up to 2,000 PSI. we'll see how they work Image Not Found I do need to pick up a pressure cutoff switch before I can wire this all in. otherwise it's a pretty complete system
JeepcoMJ Posted March 1, 2008 Author Posted March 1, 2008 had my bro weld the manifold up for me, and started mounting up everything on a sheet of diamondplate Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found
JeepcoMJ Posted March 20, 2008 Author Posted March 20, 2008 ...it's even better right now, but i still haven't shelled out the $$$ for the pressure switch or unloader valve. i'm gonna try and use an old pressure switch i got layin here before i head up to your place this week... -Pat
james750 Posted March 22, 2008 Posted March 22, 2008 This is ur ac compressor?right? :chillin: Would a setup like this work to run an air locker such as arb?
JeepcoMJ Posted March 22, 2008 Author Posted March 22, 2008 yep. i'm actually working on it right now...i'm about done with the components, but don't want to bring the truck in the shop now that it's covered in snow...(i went to bed at 9am with no snow, woke up at 3pm with over a foot of snow)
89eliminator Posted March 22, 2008 Posted March 22, 2008 yep. i'm actually working on it right now...i'm about done with the components, but don't want to bring the truck in the shop now that it's covered in snow...(i went to bed at 9am with no snow, woke up at 3pm with over a foot of snow) working on your oba, and typing on the 'puter. your a good multi-tasker :D ... ...and you took more snow with you after you cut across my grass :roll:
JeepcoMJ Posted March 22, 2008 Author Posted March 22, 2008 yep. i'm actually working on it right now...i'm about done with the components, but don't want to bring the truck in the shop now that it's covered in snow...(i went to bed at 9am with no snow, woke up at 3pm with over a foot of snow) working on your oba, and typing on the 'puter. your a good multi-tasker :D ... ...and you took more snow with you after you cut across my grass :roll: was i that far off the driveway? oops...
89eliminator Posted March 22, 2008 Posted March 22, 2008 yeah you were, you jerk :mad: j/k, no biggie :D
JeepcoMJ Posted March 22, 2008 Author Posted March 22, 2008 weeelll. finished the unit today. turned out well...now i just have to tape all the threads and put it together permanently, then mount it all in my truck it turned out pretty compact as well Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found i'll have to get an unloader valve at some point, and I'll throw a new pressure regulator in it soon as it arrives. tossed an old one on it for now...not even sure if it works. but. i'm happy with it so far.
hick92 Posted January 24, 2011 Posted January 24, 2011 i aint sure if this will help but my buddy made a a/c pump to compress air for his airtank
JeepcoMJ Posted January 26, 2011 Author Posted January 26, 2011 i deleted all the pics. maybe I'll get around to putting the new stuff up...idk. meh. there's enough OBA write ups out there... :cheers:
comanche87 Posted October 5, 2011 Posted October 5, 2011 Oh man. I was hoping to check the pics out to get more ideas how i want to make mine have on board air
MiNi Beast Posted March 13, 2022 Posted March 13, 2022 On 1/25/2011 at 8:33 PM, JeepcoMJ said: i deleted all the pics. maybe I'll get around to putting the new stuff up...idk. meh. there's enough OBA write ups out there... :cheers:
