lawmanbsi Posted January 22, 2008 Share Posted January 22, 2008 I have a trail master 3" lift installed in 1987. rear sits a bit high and always has. I just got a set of acos. If I were to get rusty's 4.5 soa. would I need additional parts for the front to accomidate the lift combo. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted January 22, 2008 Share Posted January 22, 2008 Rusty's 4.5" MJ leafs are for SUO, not SOA. If you ran the 4.5" leafs SOA you'd be at like 11" of lift in the rear... Link to comment Share on other sites More sharing options...
lawmanbsi Posted January 22, 2008 Author Share Posted January 22, 2008 I was thinking it used stock hiegth rear springs. Let me rephrase that so it makes sence. If I got a 4.5 for the front and used the acos to level the front would I have trouble with the additional lift due to the acos. Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 22, 2008 Share Posted January 22, 2008 well yes, you would have net +5'' and then youd be riding dirrrrtyy Link to comment Share on other sites More sharing options...
LocoJeeper Posted January 22, 2008 Share Posted January 22, 2008 I was figuring on doing the same thing (the ACOS) if my 4.5" RE springs in the front don't end up level with the SOA in the rear. My leafs are pretty flat, so I hope to be fine. But will toss in a pair of ACOS to level things out if need be. Keep in mind though that the ACOS lift it a minimum of 1.75" on top of whatever the coils do. Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 22, 2008 Share Posted January 22, 2008 alright so then its like 6.5" or better, once you get to that high you a bunch of things to look into. Link to comment Share on other sites More sharing options...
johngus Posted January 22, 2008 Share Posted January 22, 2008 Once you get above 3" you will need to consider other parts. Things like an adjustable track bar and longer lca's at a minimum will be necessary. It will be near impossible to properly align with the stock parts. Link to comment Share on other sites More sharing options...
mjeff87 Posted January 22, 2008 Share Posted January 22, 2008 Once you get above 3" you will need to consider other parts. Things like an adjustable track bar and longer lca's at a minimum will be necessary. It will be near impossible to properly align with the stock parts. X2 I just SOA'd mine with a rebuilt set of 4WD leafpacks (mine was a 2WD originally, so the 4WD packs netted an inch by themselves). Ended up at almost 5.5-6" in the rear with a set of new Mopar spring pads. I used ZJ coils up front plus a set of ACOS thinking that would match the rear, but it didn't....had a good 1" rake, and that was with the ACOS fully extended which I was not comfortable with. Ended up pulling the ZJ coils back out and installing a set of 5.5 TJ coils....left the ACOS in but removed the adjustable disc and used the factory isolators on top. In hindsight, I could have left the disc in but just spun the whole way up, acting like a 1/2" spacer of sorts, and it woulda worked out fine. I ended up with about a 3/4" rake which doesn't look dumb (IMHO) and is all good because I still use my MJ from time to time as a pickup truck, and with a load in the bed it levels out nicely. As far as +3" in the front, you need to start looking at adjustable control arms to set pinion angle, and a longer trackbar (adjustable), longer swaybar links, brakelines, etc...... Jeff Link to comment Share on other sites More sharing options...
Renegade Posted January 23, 2008 Share Posted January 23, 2008 I have the Rusty's 4.5" with ACOS(used to level it out as well) I found out real quick you need adj control arms to properly locate the front axle & maintain castor angle. I went with R.E arms & they are stretched to the MAX. It looks great but rides rough due to the extreme angle of the arms. I actually had to clearance the lower shock mounting plates to avoid contact with the arms during droop. Rusty's adj arms have a nice bend that adds a bunch of clearance if you choose to go that route. I need to look into drop brackets since mine is a 2by that only gets road driven. Long story short, I'd keep the 3" coils if you want to run the ACOS. Either way, don't forget about longer shocks, brake lines, adjustable track bar.... Link to comment Share on other sites More sharing options...
lawmanbsi Posted January 23, 2008 Author Share Posted January 23, 2008 I'm trying to fig out my game plan for the rebuild. I think I'm going to keep it simple. Reuse the susp I have and add the acos to level it out. If it was easy to get more lift I would. plus after all is said I can add the lift later. Its looking like I'm going with fiber glass 3" baja bed sides and fenders so more lift won't be needed. Link to comment Share on other sites More sharing options...
Renegade Posted January 23, 2008 Share Posted January 23, 2008 If you do get the ACOS you'll like them. Very nice unit. Link to comment Share on other sites More sharing options...
lawmanbsi Posted January 23, 2008 Author Share Posted January 23, 2008 I've had the acos for 3 months. My house cought fire just before halloween. we got back into the house a couple weeks ago. haven't had time to install them yet. my garage is full of stuff that was damaged in the fire and was told not to throw anything away untill the insurance is settled. I have to replace the head gasket in my blazer, so I can park the jeep. which is being held up because of the garage . I'm going to start my project thread sunday with my plans for the rebuild and pics Link to comment Share on other sites More sharing options...
DrThunder Posted January 25, 2008 Share Posted January 25, 2008 i run RE 4.5 springs in the front with soa in the rear with xj shackles which actually lower it one inch and it still has an inch or so rake Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted January 25, 2008 Share Posted January 25, 2008 NICE looking MJ man!!! Nice picture too!! :D :D I just today got a set of BDS 4.5" coils to replace mine with a too light spring rate. Thanks for posting the pic!!! CW Link to comment Share on other sites More sharing options...
mjeff87 Posted January 25, 2008 Share Posted January 25, 2008 I'm thinking about a set of XJ shackles for mine as well, just to level it a touch more. Nice MJ Doc.... Jeff Link to comment Share on other sites More sharing options...
Pete M Posted January 25, 2008 Share Posted January 25, 2008 Shorter shackles can limit your suspension travel. Just an FYI. :D Link to comment Share on other sites More sharing options...
DrThunder Posted January 25, 2008 Share Posted January 25, 2008 Shorter shackles can limit your suspension travel. Just an FYI. :D i was worried about that but am not having any issues with my shackles, i even took a video i was showing another site when i was building to see if it would be an issue, this is my truck soa no shocks with me jumping on it to see it travel. at full stuff the spring is pretty much flat and the shackle just starts to limit travel Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 27, 2008 Share Posted January 27, 2008 isnt the shackle sosposed to be 90 with the ground when no extra weight is added? Link to comment Share on other sites More sharing options...
DrThunder Posted January 27, 2008 Share Posted January 27, 2008 i'm not worried about it, if i put a longer shackle on to make it more vertical i will be way to high, i am not a fan of anything over 5 cause imo it's really not needed and you end up being more tipsy. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 27, 2008 Share Posted January 27, 2008 HHA don't look like your shocks are doin all that great of a job...or you weigh like 300 lbs lol. (no offense if ya do ;) ) Link to comment Share on other sites More sharing options...
DrThunder Posted January 27, 2008 Share Posted January 27, 2008 this is my truck soa no shocks with me jumping on it to see it travel. at full stuff the spring is pretty much flat and the shackle just starts to limit travel like i said in here, no shocks Link to comment Share on other sites More sharing options...
TNT Posted January 27, 2008 Share Posted January 27, 2008 isnt the shackle sosposed to be 90 with the ground when no extra weight is added? If you want it to ride like crap you do. His angle is about perfect. I wonder wow far forward it goes at full droop. I run a lift shackle with the body mounting hole forward. I have 12" of travel no problem. If I had a short shackle or it was at 90 degrees it would limit my droop. Here is my shackle at rest. As you can see my springs are quite arched and provide about 3" of lift. They are Stanley replacement springs. Image Not Found Link to comment Share on other sites More sharing options...
