Vibration over 45 mph
I have a vibration over 45 mph
I have replaced tires  i have had the wheels balanced twice replaced sway bar links shocks all the brakes
ball joints appear to be good and tight Tie rods are tight
1990 Comanche 4.0 2wd no modifications at all. Some people tell me to replace the steering stabilizer then when i look on line it says that would not cause a vibration.
looking for recommendations please
Steering stabilizers DO NOT remove vibrations.  They merely reduce them.
Pete M raises some good questions about/where the vibrations are felt.
Based on the speed you stated, it sure sounds like a tire balance issue, but answering Pete’s questions will give some clues as to the source.
I agree that a detailed description of the vibration would help.
Since you have had the tires balanced, that's likely not the issue.
Things to check:
1.  Ball joints.  Get the tires off the ground and really move the tires around.  Use a pry bar if you need to.
2.  Steering components, specifically tierod ends.  At the steering box, at the joint where the two sides meet, and out at the knuckles.  Check that the nuts are tight and there is no excessive play in the joints.
3.  Bushings.  All 4 control arms and the track bar.  Check bolts are torqued to spec and that bushings aren't worn.
4.  Steering stabilizer.  It doesn't hurt to have a fresh one if it's worn, but it won't cause or solve vibration by itself
Check the track bar. Any play in the joint, the bushing, or the axle-side mounting hole will cause shimmies and wobbles. Remove an end and give it a thorough inspection. You won’t always see play in the ends if it’s still in the vehicle and under load.
One of the best ways to check for steering system looseness is to have a helper sit in the vehicle with the engine off and rock the unlocked steering wheel side to side until they feel the force to turn the wheel get high.  This essentially takes all the lash out of the steering system.
while the guy in the cab is doing that activity, you climb underneath and check each joint one at a time.  The way you check the joint is both visual and by feel.
the “by feel” part involves grasping the individual joint by hand, trying to encircle both halves of that steering linkage connection with your hand and fingers. You are attempting to feel for any relative play between the two parts of that particular steering linkage connection.
this test only works on the steering linkage and on the track bar connections.  The test for control arm looseness is only really feasible with a BRIGHT flashlight and visual inspection, looking for cracks in the rubber and/or permanent rubber deformation.
well it brought to light a couple things
is it possible that the arm coming off the steering box could be worn?
its a solid piece and i can't see how it would wear out
also there is a little play in the arms that connect to the tie rods but definitely not much
find it hard to believe that little play can cause a vibration?
Any play in the steering linkage is unacceptable.  The parts affected should be replaced.
2 hours ago, terryt said:
nothing is worn excessively but when it hits 45 it vibrates
i have had the wheels balanced twice new tires shocks brakes it steers great no play in the wheel
i definitely feel it in the wheel
Something is worn more than you think it is.
There should be zero play in all 4 steering joints.  None.  If there is any at all, it's enough to induce vibration.
Same with ball joints.  Any play leads to vibration.  Even play that's hard to see.
Same with control arm and track bar bushings.  Worn bushings can contribute to vibration.
Could be all of it together.  Each part by itself may not be bad but all together, there's enough slop to cause issues.
If you haven't changed parts in 20 years, they're probably overdue.
