Cadens 88 MJ #6
  • Replies 55
Rear lift is in now time for the pita part. Got one inner trans crossmember support out gotta get the passenger side off tap some holes out and mount the long arm cross member on. Not excited to cut the lower control arm brackets off
41 minutes ago, 89 MJ said:
That trans crossmember looks like it hangs down a long ways.
Might also want to update your signature haha
It's not as bad in person. It's got a built in crossmember drop instead of the normal t case drops
6 hours ago, Gjeep said:
Nice find on those seats and door panels -- that's a one year at best Jeep offering. Late '87 Laredo with black interior/ 'luggage' fabric. Only seen these once before in life. Will look good. Congrats
Thank you. They came out of a very base wagoneer it was a odd ball for sure.
Had the belt get thrown off two more times because it was not tightened from the parts store so tightens it replaced both idlers and warrantied my fan belt now it's fine fan belt wise. Got a little death wobble but it was just the new track bar coming loose again will be re tighting all new parts tommrow.
