87MJTIM Posted November 9, 2024 Share Posted November 9, 2024 I know that Jeremy has retired from his radio repair business for health and job reasons. I have searched for info on the 'net about installing aux and/or BT to old AMC/Jeep radios. Is there a site that has a detailed write up on how to install/modify old radios for aux/BT. I searched on CC but could find written instructions or a parts list. I found a YT video on installing aux, but is was from '22. While that helped visualize the process, I need written instructions (cookbook) to perform the task. Thanks in advance. Link to comment Share on other sites More sharing options...
89 MJ Posted November 9, 2024 Share Posted November 9, 2024 @Minuit talks about it some in this thread: Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted November 12, 2024 Share Posted November 12, 2024 I would be more curious about adding USB, myself. Link to comment Share on other sites More sharing options...
87MJTIM Posted November 12, 2024 Author Share Posted November 12, 2024 In the DIY section, "What Minuit knows about...", Pete linked to a YT video showing someone performing the steps. In that video, you can see an instruction sheet that was downloaded from Jeremy's website - now defunct. I reached out to him - Doug - on his YT channel to ask if he still had the instruction document. He replied with the pdf attached!!! He also provided links to the harness wires and pins. Those links are still in the DIY thread. I looked the website (digikey.com) for USB type harness. The USB wire configuration uses 5 wires, while the one Jeremy used is only 3 wires. Since I am not an electronics expert, I don't know what the two extra wires control and how they interact with USB plug. I have an adapter for my iPhone that uses an 8mm male pin to the phones plug in port. However, a blue tooth dongle would be sweet. Does anyone know what the two extra wires control (both black)? Link to comment Share on other sites More sharing options...
schardein Posted November 12, 2024 Share Posted November 12, 2024 26 minutes ago, 87MJTIM said: He replied with the pdf attached!!! He also provided links to the harness wires and pins. Those links are still in the DIY thread. I would appreciate having a copy of the PDF if you don't mind sharing. Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 12, 2024 Share Posted November 12, 2024 Please post the pdf here. Link to comment Share on other sites More sharing options...
87MJTIM Posted November 12, 2024 Author Share Posted November 12, 2024 Here it is 52381847_AUX-C1Instructions.pdf Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 12, 2024 Share Posted November 12, 2024 Thanks! Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted November 12, 2024 Share Posted November 12, 2024 Does anyone have a pdf editing software? I think we should respect jeremy's privacy and edit out the address from the PDF and then re-upload it. Just sayin. Link to comment Share on other sites More sharing options...
FXWorks Posted November 12, 2024 Share Posted November 12, 2024 52 minutes ago, Salvagedcircuit said: Does anyone have a pdf editing software? I think we should respect jeremy's privacy and edit out the address from the PDF and then re-upload it. Just sayin. Here's a version with the warranty and contact pages removed. 52381847_AUX-C1Instructions_contact+warranty_removed.pdf https://stirlingpdf.io is a free PDF service. You can also download the software and self host it yourself as well (this is how I've changed this file). Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 12, 2024 Share Posted November 12, 2024 USB audio is typically a digital signal. You would need to use a digital to analog converter as you’re looking for an unbalanced analog stereo signal to provide the radio’s pre-amp. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted November 12, 2024 Share Posted November 12, 2024 13 hours ago, ghetdjc320 said: USB audio is typically a digital signal. You would need to use a digital to analog converter as you’re looking for an unbalanced analog stereo signal to provide the radio’s pre-amp. So a USB port would need to pass through the converter before reaching the rest of the board? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 13, 2024 Share Posted November 13, 2024 1 hour ago, Spinnakerblue89 said: So a USB port would need to pass through the converter before reaching the rest of the board? That’s correct. There are a huge variety or usb digital to analog converters available and they typically have a 3.5mm unbalanced stereo output that will then be wired to the board inside the radio. Once you have an aux input on your radio, you centrally connect all sorts of devices to that which in turn can interface with the music source via USB, Bluetooth etc. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted November 14, 2024 Share Posted November 14, 2024 Granted I'm okay with a soldering iron, I even have a decent setup form Hakko. I would rather spend that time doing something a little more meaningful like service, tune-up, brakes, whatever. I still have the old MJ radio though, and it does work. Link to comment Share on other sites More sharing options...
87MJTIM Posted November 15, 2024 Author Share Posted November 15, 2024 After reading and re-reading Jeremy's instructions, I went to get YouTube certified to add blue tooth to the radio. Jeremy's instructions and several YB videos showing how to add the wiring, add a blue tooth board, and providing power to the BT board. Jeremy's instructions will eliminate the AM band. Not too bad. I don't listen to AM radio anymore. With his method, I need to adapt the 3.5 mm plug to the port on my iPhone. Several of the other videos involve tapping into either a cassette or CD player. Again, I don't listen to tapes or CDs anymore. However, both require having a cass/CD in the player to active the BT to broadcast to the phone. One more wrinkle is using my phone to make/receive calls. My aftermarket unit is BT and has a microphone for calls. Link to comment Share on other sites More sharing options...
