CoMANches60 Posted December 7, 2023 Share Posted December 7, 2023 Trashing the ecm renix on my 88 comanche.is there a drop in after market distributor recommended.msd doesn’t have one. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 7, 2023 Share Posted December 7, 2023 4.2L parts. Or you could go HO Link to comment Share on other sites More sharing options...
89 MJ Posted December 7, 2023 Share Posted December 7, 2023 I’ve got a DUI HEI distributor on the 4.2 in my Eagle. Well worth it, IMHO Link to comment Share on other sites More sharing options...
CoMANches60 Posted December 7, 2023 Author Share Posted December 7, 2023 Found an hei at team performance says it will fit amc 232,242,258 4.2l.not sure about this company.wondering if anyone has ever tried there products.sent an email but no reply yet Link to comment Share on other sites More sharing options...
89 MJ Posted December 7, 2023 Share Posted December 7, 2023 1 hour ago, CoMANches60 said: Found an hei at team performance says it will fit amc 232,242,258 4.2l.not sure about this company.wondering if anyone has ever tried there products.sent an email but no reply yet Here is a link to exactly what I have. I've put about 6,000 miles on mine and it was used when I got it. I've had to replace the ignition control module, but that's it. I do not know how many miles the unit has on it, but it has been pretty great. And most of the parts are shared by GM vehicles with an HEI distributor. https://www.summitracing.com/parts/dui-40620bl?rrec=true Link to comment Share on other sites More sharing options...
CoMANches60 Posted December 8, 2023 Author Share Posted December 8, 2023 3 hours ago, 89 MJ said: Here is a link to exactly what I have. I've put about 6,000 miles on mine and it was used when I got it. I've had to replace the ignition control module, but that's it. I do not know how many miles the unit has on it, but it has been pretty great. And most of the parts are shared by GM vehicles with an HEI distributor. https://www.summitracing.com/parts/dui-40620bl?rrec=true Link to comment Share on other sites More sharing options...
CoMANches60 Posted December 8, 2023 Author Share Posted December 8, 2023 Tried the summit link but check fit link on that site did not cover my 4.0 242 Link to comment Share on other sites More sharing options...
89 MJ Posted December 8, 2023 Share Posted December 8, 2023 4 minutes ago, CoMANches60 said: Tried the summit link but check fit link on that site did not cover my 4.0 242 The distributor will be the same between a carbed 4.0 and a 4.2, I believe. You’ll want one for a 4.2 I think @89eliminator has an MSD setup on his truck, maybe he can shed some light. Link to comment Share on other sites More sharing options...
neohic Posted December 8, 2023 Share Posted December 8, 2023 I can confirm that a 4.2 HEI distributor will fit in a 4.0. I’ve got this setup in my CJ. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted December 8, 2023 Share Posted December 8, 2023 I also ran a carb on the 4.0 in my Eagle with all stock 4.2 liter ignition. It should all swap between the 2 motors. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 8, 2023 Share Posted December 8, 2023 Grab an HEI distributor from a 250 ci Chevy six cylinder. Remove the drive gear and install one from an AMC V8. Done. Link to comment Share on other sites More sharing options...
NC Tom Posted February 3, 2024 Share Posted February 3, 2024 On 12/8/2023 at 7:01 AM, cruiser54 said: Grab an HEI distributor from a 250 ci Chevy six cylinder. Remove the drive gear and install one from an AMC V8. Done. So, Crusier54, what is the advantage of dropping/replacing the Renix ecm and adding the HEI distro? Link to comment Share on other sites More sharing options...
cruiser54 Posted February 4, 2024 Share Posted February 4, 2024 That isn't what I was referring to. I was referring to the 258 used in the eagle with a carburetor. Link to comment Share on other sites More sharing options...
