1992 Jeep Comanche "Maria"
  • Replies 110
11 hours ago, WranglerMangler said:
That will definitely impede air flow!
Be sure to do the Cruiser54 ground upgrade while your there too. Makes a big difference in fan performance
I thought that upgrade by Cruiser54 was for Renix only?
11 hours ago, MariaManche said:
Think it’s “mostly” Renix tips.  All grounding  upgrades apply to all MJs. I do to as much as possible from his list to my HOs, seems to make the trucks much happier.
I put together a parts list of what I need for the 8.8 swap. I will also need to re-gear the front dana 30 to 3.73.
Does anyone of recommendations on 3.73 ratio ring and pinion for the Dana 30?
rear axle swap 8.8 New rotors/pads
XJ leaf shackle
1" spacers
1280 lb leafs
Diff cover
leaf/shock mount kit
yoke adapter
Dana 30 3.73 ring/pinion
I’ve also had good luck with Yukon gears and axle shafts. I have a set of very beat on D44s with Yukon R&P + Rear shafts that I’ve never had any problems with. (35” tires)
My friend spun his Yukon pinion and broke teeth in a D30 front with 36” tires, so they do have their limitations.
  • 4 weeks later...
Comanche Update
I should have taken more pictures of the process but I completely dissembled the dash to clean and fix wiring issues. Most of the wiring was in good shape but some had chew marks exposing the conductive copper. I used liquid electrical tape to fix most of these, but for one I had to cut out the bad and solder/heat-shrink.
Blower motor was re-installed after deep cleaning that area of the engine bay. Painted my fuse box metal bracket and got the wiper fluid and puke box reservoirs looking like brand new.
On my first test drive, I turned on the AC and the motor blew strong briefly and then shut off. I am guessing I blew a fuse but I have not dove into that yet.
I drove the Comanche for about 80 miles and made note of action items to fix. There is an extremely annoying rattle that I need to locate and it still smells terrible even after all my cleaning efforts. I am going to try an ozone machine off of amazon to fix this now that I think all the mouse remains are gone.
It is extremely nice having the original radio working.
  • 1 month later...
Comanche Update
This has to be the last mouse nest...... There is basically no where else for one to hide.
While I was taking out the wiper motor and wiper arms, I noticed there was a lot of slop in the arms. This makes me think that this might be the culprit for the very annoying rattle noise behind the dash. I plan to replace the wiper arm bushings and try to correct the slop before reinstalling.
I have been taking the Comanche out to National Forest for some turkey hunting this spring. I do not want it wasting away in the garage like it lived its previous life.
  • 2 months later...
Wow a nice red 92 !
keep up good work !
detail king sells an enzyme that eats bacteria of urine, vomit etc.
if you haven’t already bought gears, I would recommend 4:10’s or even 4:56 if going stay with 35” tire.
Lots of gear -vs- rpm calculator’s online.
On 8/3/2024 at 12:26 AM, Red Mistress said:
Wow a nice red 92 !
keep up good work !
Thanks! I’m going to look up detail king
Per Pete’s advice, I dug a little further to find where the rust causing water was coming from….. found more rust.
Just got in some C2C floor panels to help with the patches. I don’t think I need to do a complete floor install.
anyone have advice on removing the rubber sealant goo that covers the floor board.
IMG_4834.jpeg.463837a132e1aa7bedee1397971e788a.jpegIMG_4833.jpeg.11eed51bed166e8c6eeaa37360ef0d54.jpegIMG_4835.jpeg.73dd1b2644220361f9f9eda2d8f3d400.jpeg
I used a set of wood chisels to get that stuff off. If you are lucky, most of it is hardened and comes off somewhat easy. It gets messy when it has the consistency of chewing gum on a hot sidewalk. Then its time to break out the acetone, wire brush and brake parts cleaner.
  • 3 weeks later...
25 minutes ago, MariaManche said:
Can anyone tell me how to remove this stud? It holding up my removal of the top uniframe support. I have seen pictures of it out and in.
That is an important stud that holds in the seat. To remove it, apply some PB blaster, grab a map torch, heat it, apply some vise grips and twist. It should hopefully come out.
If it snaps (which mine did) you'll have to weld some nuts to whatever bit is left and use an extended length wrench to get it out. It took 2 weldments to get that stud out.
Thanks for the advice!
I cleaned up the stud with a wire brush on a die grinder and sprayed a liberal amount of Kroil on the top and bottom side. I’ll see if she breaks tomorrow after work. IMG_5122.jpeg.44e0f4a029dc13a6bb0c637c663ce2f1.jpegIMG_5120.jpeg.b668cfc56bb3c53440b2b51ccec79a8b.jpeg
